Question about Dell 948 All-In-One InkJet Printer
Dell 948 keeps jamming under the cartridge carrier. i keep clearing it but it jams every time I print.
  • Dell Master
  • 4,338 Answers
Clean the carriage rail. This is the round chrome piece that the carriage assy that holds the cartidges rides on. Use a paper towel that is slightly moist.
Be sure to not force anything. Unplug the printer after you get the carts in the middle. Move them to one side and clean and then move them to the other and repeat.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 10, 2010
My printer will not print, keeps displaying ( clear carrier jam! ). How can I fix it?? Do I need to buy a new printer or is this an easy fix. I 've unplugged the printer and checked ink cartridges...
Turn the printer off and unplug it from the wall. Press and hold the power button for sixty seconds. Open the top of the printer to make the ink cartridge carrier accessible. Grab the ink cartridge carrier with your hand and slowly move it back and forth until it moves freely. Then plug the printer back in and turn it on. That should solve your issue.
Sep 25, 2011 | Dell V305 All-In-One InkJet Printer
I have a dell 948 all in one printer, clear paper jam then press check. There is no paper jam. I have follow instruction and site recommendation, ran printer software, problem still exist, please help
This is a known issue with Dell all in ones.
It's a problem with the power supply inside the unit.
If you were in the middle of a print job, though, and it jammed, do recheck as I've been caught out
with a paper jam where a tiny partical of paper was doing the jam. Look carefully before contacting Dell support.
Dec 31, 2010 | Dell 948 All-In-One InkJet Printer
My dell all in one 948 printer keep sending a msg that says clear carrier jam once the paper is half way finish alligning the new ink cartridges.
Hello there this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 16, 2010 | Dell 948 All-In-One InkJet Printer
Clear Paper Jam message on my Dell 948 nAll in One
press cancel button,, for 30 seconds, it will reset, either, press, on/ off button once.
Jan 17, 2010 | Dell 948 All-In-One InkJet Printer
I keep getting an error message that says clear carrier jam and then press the checkmark. However, there is no jam that I can see. Whenever I open the top of the printer the cartridges just remain stuck to...
lift the printer and shake to check if it sounds like a piece broken inside.. turn the printer off take the power brick out from the back.. manually pull the cartridge to extreme right then center.. check if cartridge is aligned correctly.. if nothing of this works.. contact dell for replacement under warranty.. if out of warranty.. inkjet printers cannot be repaired if broken.. u can buy a dell v313 of same quality for $59 with warranty..
Dec 22, 2009 | Dell 926 All-In-One InkJet Printer
Not working see bottom
Check your entire feed to make sure there is NO paper jams. Sometimes even the smallest little piece of paper can get jammed up and can e hard to see.
You can also check your manual for diagnostic mode and alignment print page.
May 13, 2009 | Dell 926 All-In-One InkJet Printer
Carrier jam on 926 dell printer
go to page 59 of the manual ("http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf" if you don't have it) look for code 1200 in the middle of the page. good luck!
Feb 13, 2009 | Dell 924 All-in-One InkJet Printer
Dell 942 carrier jam
This morning I replaced the cartridges in the Dell 942 printer, they jammed to the left which made a loud grinding noise and the cartridge jam error came on.
I solved the problem by turning the printer on with the top up which moved the cartridges to the right a little so I could reach back, push one down a little manually which freed them to move over to the middle.
Feb 28, 2008 | Dell 942 All-In-One InkJet Printer
Carrier jam on dell 924 printer??
I was able to fix this issue on my all-in-one 944 printer. What happened was that one of the ink cartridge lids had popped open. The hard part was that the carrier was stuck on the far left side, and I wasn't able to pull it over for easer access. However, I was able to fit a finger in and push the cartridge back down. Then when I turned the printer back on the error went away.
Hope this helps
Dec 13, 2007 | Dell 924 All-in-One InkJet Printer
Ink cartridge
Not quite sure what you mean but if it is stuck under the housing then that would give the error. Could it be that the cartridge wasn't installed straight and this has caused it to become jammed?
Oct 08, 2007 | Dell 922 All-In-One InkJet Printer
Dell 948 All-In-One InkJet Printer Logo
69 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
