Question about APS997A PRESTIGE 4 Button Remote Start Security System
I have an Audiovox prestige car alarm Model No. 5BCR05. The lock & unlock buttons have stopped working, battery is new.
5 Suggested Answers
reynosaelect
  • 165 Answers
SOURCE: I need the diagram of alarm Prestige model: APS95BT3
go to google and write this> audiovoxtechservices press enter,and in that website request a password to get the instalation manual
Posted on May 11, 2009
  • 151 Answers
SOURCE: I have an Audiovox Car APS95BT3 Transmitter with 3
here is a link that should help you.
http://audiovox2.info/docs/voxx_mob/man/APS95BT3_DOC_TPG.PDF
Posted on Dec 28, 2009
SOURCE: I bought a car with this starter (below)and no one
I'm not sure about trunk but to start the engine press twice green buttun and engine should start and to shutt it off press green button once.
Posted on Jul 22, 2010
logosc75
  • 625 Answers
SOURCE: how to disable or reset a Prestige car alarm.
The valet switch,on the newer Prestige alarms, is a push button LED or, it's incorporated into the antenna. In both cases, turn the key to the on position, then press and release the valet switch. The alarm will respond with two chirps confirming that it is disarmed. You may now start the vehicle. After you successfully disarmed the alarm, turn the key to on position, press and hold the valet switch for approximately 5 seconds, the LED will come on solid. Turn the key off.The alarm is now in valet. You can take it out of valet in the same manner.
Posted on Oct 29, 2010
Prestige APS787C wont start car
Try reprogramming the remotes: Turn ignition on, press and release programming/Valet button on antenna three times. You should here a short chirp, press the lock button on one remote. You should here a long chirp. Press the lock button on the other remote, you should here a long chirp. Turn ignition off. Test system.
Feb 11, 2013 | Prestige Remote Start
I need to re-program the remotes to my alarm. It is a prestige aps255a. Just to lock and unlock all the doors. To arm and unarm is already programmed.
Huh? Pressing the lock button arms the alarm AND locks the doors. Pressing the unlock button disarms the alarm AND unlocks the doors. If this is not happening either there is an issue with the wiring from the alarm to the car or, with the vehicle's door locks.
Apr 20, 2011 | Audiovox APS255A Car 2 Prestige Platinum...
I have a honda pilot with the prestige car starter and the panic alarm keeps going off when I open the door. I can not get it to stop so it has to go through its 2 minute cycle. any ideas on how to get...
That is your factory alarm. I will assume that this Prestige unit is a remote starter with keyless entry...and you are using the Prestige unit to unlock the doors. Apparently, the unlock wire is connected but, the factory disarm is not. You can turn off your factory alarm by unlocking the vehicle with the key.
Jan 25, 2011 | Prestige Remote Start
I have a new prestige car remote installed recently and i have a problem how to shut off the alarm coz the installer did not or forgot to give me the manual. When i start the car remotely i press the...
You did not mention the year/make/model of your vehicle but, the issue appears to be the factory alarm. The installer failed to make the connection. If you intend to make the connection yourself I would need information pertaining to the vehicle. The (-) pulse before start wire for Prestige remote starters is black with a blue stripe. It is in a 4 pin connector at the module. This wire can be used to disarm the factory alarm before the remote start sequence.
Jan 23, 2011 | Prestige Remote Start
I have a prestige alarm system on my car. my car won't start
there may have been a starter kill relay wired up to this when the alarm was installed, contact the busness that installed it to find out if one was put in and how to bypass it
Feb 15, 2010 | Prestige 2 Button Remote Security System...
Would you recomend the Audiovox Prestige APS901N for my '06 Chrysler T & C mini van?
IF RANGE IS NOT IMPORTANT I SUGGEST A AUDIOVOX AS9076N . ITS AN ADD ON REMOTE START WHERE YOU WOULD PRESS
LOCK
THEN UNLOCK
THEN LOCK AGAIN ON YOUR FACTORY REMOTE AND THIS WOULD START THE CAR.
I BELIEVE THE IGNITION KEY HAS BUILT IN KEYLESS ENTRY BUTTON ON IT ALREADY. SO WHY CARRY ANOTHER REMOTE?
MOST OF AUDIOVOX MIDRANGE SYSTEMS HAVE THIS OPTION FOR ADD ON REMOTE START SYSTEMS WHERE YOU CAN USE THERE REMOTE OR TIE IT IN WITH YOUR EXSISTING REMOTE.
OTHER UNITS WILL HAVE DOUBLE LOCK OPTION TO START CAR. OR TRIPLE LOCK OPERATION.
Dec 24, 2009 | Prestige Remote Start
No remote for alarm
until you get a working remote, you should unplug that alarm
Dec 14, 2009 | Prestige Remote Start
I just got a prestige pager alarm for my car. how do i set the time on the pager remote?
hold down the F button 3 seconds then hit it again to advance to the clock mode, use the lock and unlock buttons to toggle the feature up and down. regards, martin @ lessco electronics
Nov 20, 2009 | APS20B Prestige Keyless Remote Alarm
Instructions manual
Need to know how to wire the door locks on 5 wire reverse polarity vehicle
Feb 10, 2009 | Audiovox Prestige Code Alarm Remote Alarm...
APS997A PRESTIGE 4 Button Remote Start Security System Logo
584 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Glen Weitzdoerfer
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
