Question about Epson Stylus CX6600 All-In-One InkJet Printer
Please help THERES NEW CARTRIDGES IN THE SYSTEM AND ITS PRINTING STREAKY AND  BLURY AND WORDS ARENT TYPED PROPERLY..PLEASE HELP...THANK YOU
    Genius:
  • 1,447 Answers
HI-
Pls try to run head cleaning cycles from your computer, if you have a windows xp computer, go to control panel, then printers and faxes and if you see a printer icon for your cx6600 rightclick on it and go to printing preferences then click on maintainance tab and click on head cleaning, do it thrice and if the output is still the same then chances are the nozzles are clog, you can send it over to a servicer or you can call epson so that they can give you discount on the next printer that you will get from them, best i got. Thanks for using fixya!!
Posted on Jun 17, 2008
Black ink on my Brother MFC-420CN is faint and streaky
You said you replaced the cartridges. Were they Genuine Brothers' Cartridges?
My Brother MFC-240C, does not like Generic Printer Cartridges. That sounds like your problem. Also I had with Brother's was problem with Color. Color that should be Yellow, will turn out Green, or Blue Green, etc. The Generic Cartridges, also printed lines thru the words. That's what the Companies do., so they can keep selling the ink cartridges.
Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY, or Take them to have them filled.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for the PRINTERS.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 03, 2010 | Brother MFC 420CN All-In-One InkJet...
C5150: All color prints are extremely streaky and
This happened to me. It was caused by a bad "oki compatable" color cartridge. One time it ruined my drum. It was always the yellow color. Decide which cartridge is printing streaky. Remove it, bang it on the inside of a large plastic garbage can. Clean it. Reinstall it . If it still prints streaky throw it befor you ruin the drum. Replace it.
Nov 07, 2009 | OKI C5150n Led Printer
Poor print quality- streaky lines across the page
The problem might be with the type of paper you are using. Some printers require different paper types. Check the manufacturers website to see what kind of paper you need.
Jul 08, 2009 | HP DeskJet 845c Printer
Streaky printing
At most cases of printer, especially which have done refill at cartridge, print quality is poor or streaky. Many factors influencing this printed result. To overcome print quality is poor, maybe following tips can usefull to prevent printed pages are missing lines or streaky.
First step is ordinary to be done many people when print quality is streaky that is doing cleaning. To get good printed result, sometime this facility is used more than once.
Use Ink Refill with Quality Nicely
For printer have refilled, sometime the quality of printing is also influenced by ink. If will fill your printer again, use ink which the was quality of nicely. I have tested some refill inks at cartridge which have been ascertained still nicely ( sorry: I do not want to publicize result of this attempt). In the reality result make me surprise, there ink of refill making the printed quality is crummy. To choose ink refill read following tips :
  • See viscosity of ink, every merk of ink refill have difference of viscosity. Don’t use Ink refill too jell. Difference of this viscosity is no measure reference viscosity of ink from factory maker of printer
  • Don’t fear to try some inking merks. Done this, you’d find refill ink fitt with your printer. I now only using one merk of refill ink ?.
  • This suggestion of forum, but I still not yet proved. May believe or not. Good ink aroma of soft usually.
Change Original Cartridge
This is last choice. A lot not like to do this ways, because price of original cartridge still costly. Alternative, you can use compatible cartridge which the was price of cheaper than original cartridge. At newest printer, usually there are two until four cartridge in one printer. And price four same cartridge almost at the price of printer even there are some costlier.
Let me know !
Thanks
Fame !
Apr 02, 2009 | Canon PIXMA MP130 All-In-One InkJet...
HP7660 Photosmart Printer
It comes with HP #57 (C6657 A)—Tri-color print cartridge and HP #56 (C6656A)—Black print cartridge and the 56 must always be in there (the black one) but acceptable replacements for the color one are as follows: HP #58 (C6658A)—Photo print cartridge I suggest for the best photos use 58 and 56.
Feb 28, 2009 | HP PhotoSmart 7660 InkJet Printer
Printing color pictures are streaky
The easiest way to do this if you have not got the software loaded for the printer, is open a document in word for instance, go to File>print and when the print window opens, go to properties, and see if there is a utility tab, if there is click on it and select clean nozzles.
Also have you tried looking under programs, if there is a program for your printer the maintenance tools should be there
Nov 25, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Printing inkless printing
Gecko17 How old is your cartridge? is there is enought ink to print your document? If so then... Take out the cartridge carefully from your printer without touching any contact points, heads etc. Clean the head's of your printer cartridge carefully by using head cleaner fluid. After that, reinstall your cartrige and please try to print again. If this deosn't solve your problems, you may need to replace your cartridge with new one. thanks
Aug 30, 2007 | Lexmark Z600 InkJet Printer
Epson Stylus CX6600 All-In-One InkJet Printer Logo
43 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
