I have a Fisher Paykel Pride 5.5 smart drive. It fills very slowly on the cold or warm water cycle. and then stops half way and beeps at us. If we forward to the next stage, it also fills slowly and beeps at us in the spin cycle. Should i get a mechanic in to look at it. Peter.
  • 25 Answers
CHECK THE WATER VALVE ON THE BACK , U MAY BE CHANGE IT.
Posted on Nov 10, 2010
Cold water not pulling into Fisher & Paykel 5.5kg Smart Drive Pride.
Either the cold water inlet solenoid has failed or there is a fault with the electronic control module, Unfortunately the only way to find out is to replace the cold water solenoid and see if it works, if it doesn't then the electronic control board is faulty.
Mar 16, 2017 | Fisher Washing Machines
Fisher & Paykel Kelvinator Smart Drive 601. Machine does not complete full cycle. Stops at most stages and beeps. Seems to have trouble with water intake. Hoses have good water pressure when...
the magnetic switches may be warn. in hard water areas they can block up and stop working. you may need to change them or take them out and stick them in some vinaga and see if it will soffen the hard crust off the inside of them out.
Oct 06, 2013 | Fisher and Paykel Washing Machines
Fisher and Paykel Washing Machine model mw512
this sounds like the motor controller cant start the motor. I would be looking at the motor controller itself.
when it's filling with water, does the bowl go around slowly?
Sep 11, 2013 | Fisher and Paykel Washing Machines
I have a Fisher and Paykal Smart Drive 053 washine machine. It has just started doing the following: Start load - Cold, warm or Hot and any size Fills intermittent. will fill for a couple of seconds...
Hi just read your posting.When the machine stops and starts does it beep and show an error code.This error code will be a series of lights that light up and the machine will beep.On the wash progress line of lights which lights are lit when the machine beeps,Is it the 1st and 6th or the 4th and 8th etc.Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Jun 05, 2011 | Fisher and Paykel (IWL12)
Received washing machine with no instructions,favourite program show preference for warm water wash,when I go to use cold wash it fills very slowly and then beeps show warm water light flashing I need to...
You MAY have a faulty cold valve (Not unusual) Or low water pressure. If the machine will fill ok on 'hot' but has a problem on 'cold' then you probably have a faulty 'cold' valve.
Do not change wires to 'hot' valve, as there is a difference..
Good luck....Nomess
Aug 04, 2010 | Fisher and Paykel Fisher & Paykel Washer
Starts and stops
A failed inlet valve is not uncommon in F&P machines. The hot valve is different to the cold one, so don't exchange them. Not a big job for a tech to do in-laundry. Good luck....Nomess
Jun 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
F & P Smart Drive Model MW0I5K - BEEPING
If the washer is also filling slowly it's likely to be the hot or cold water solenoid (either one or both - not that an expensive a repair)
Jun 27, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
Jan 05, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
F&P Smart drive 9
I had the same problem.
You probably only have cold water connected and you need to "program" it for cold water only.
By default it expects both cold and hot water connected and even though you can select "cold" it will still error if not hot water supply is present.
Call Fisher & Paykel customer care and they will tell you how to re-code it for cold only.
Oct 05, 2007 | Fisher and Paykel (IWL12)
Washing Machines Logo
407 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
