Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
I'm trrying to turn on the sound on this pc. But it won't let me get into the control panel without an administative passcode. What do I do?
    Scholar:
  • 74 Answers
I'm assuming this is your home pc. If you have setup an account on the pc as a "user", then this will not allow you to install apps or enable/disable devices on the PC.
Log in to the pc with the administrator account or the main account that was created and then try again
Hope that helps
Posted on Nov 12, 2010
Where can I find the driver for a ONN wireless keyboard model ONA11H0087
So what do you need to do?
FIRSTLY check Control Panel->Administative tools->Component services and click "Services (local)", on the RHS look for "HID input service" under STATUS it should say STARTED, if it does im not 100% if this will help but try anyway. If it doesnt, this should work.
Go to START->RUN and type REGEDIT and navigate your way to the following:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\HidServ\Parameters
If there is a file called "ServiceDll" delete it (make a copy obviously and stick it on your desktop or something). Right click in the RHS of the page and create a NEW->Expandable String Value.
Call it "ServiceDll" (exactly as typed here without quotes), and make the value read "%SystemRoot%\System32\hidserv.dll" (without quotes). Now exit out of Reg edit and go back to Control Panel->Administative tools->Component services. Next to HID input service right click in the gap under STATUS and press START. Close properly and your volume should now work.
Good luck.
Jan 02, 2018 | The Computers & Internet
How can I remove administrator name?
Go to control panel, click on accounts and remove administer beware you will no longer be able to change any settings that require administer rights unless you re categorize another name as administrator.
Feb 01, 2016 | Toshiba Computers & Internet
Can I make a new password
Yes, you can
Use passcode with your iPhone iPad or iPod touch
Set your Passcode
    1)Go to settings > Touch ID & Passcode. On devices without Touch ID, go to Settings > Passcode.
    2)Tap turn passcode on
    3)Enter a 6-digit passcode
    4)Enter passcode again to confirm Change passcode or passcode settings
    To change your passcode or passcode settings, go to Settings. Touch ID and passcode. On devices without touch ID, go to settings > passcode.
Nov 19, 2015 | Cell Phones
I turn off my ipad passcode an it still comes on
Go to settings > passcode > turn passcode off ! At each stage you will be asked to enter passcode for security! After this is complete when you go to settings > passcode, you should see "turn passcode off"
Oct 22, 2014 | Apple iPad Tablets & eReaders
Ileft my computer at mothers house in va. a year agcant remember the passcodeo and now
you just press control+alt+del button same time two or three time you see another login promt try usename administator or admin without password if u not set password then system turn on if u set password then u put it
May 20, 2012 | Dell Inspiron 1200 Notebook
Mitsubishi wd62526 tv has a passcode on it that i dont know ;so is there a way to change it or reset it
Bypassing the V-Chip Lock After you set the lock, you need your passcode to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip Lock menus. If you forget your passcode, you can view the locked TV without entering your passcode. This is done by pressing the number 9 and QV buttons on the TV remote control at the same time, when your passcode is requested. This process temporarily unlocks the TV. When entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode. Press HOME to exit the menu.
Bypassing Front Button Lock If you have misplaced the remote control, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds
Aug 25, 2011 | Mitsubishi WD-62526 Projection TV
What is the code for my Mitsubishi WS-65511 rear projection TV remote control?
Hello
Lock menus.
buttons on the remote TV control at the same
you to enter a new passcode. Pressing HOME
at this time will cancel the entire passcode.
more than 8 seconds.
OK.
Feb 26, 2011 | Mitsubishi WS-65511 65" Rear Projection...
Passcode problem
Startup the computer in safe mode by pressing f2 when switching it on. You can disable the password through control panel user section when it final comes up. Or you can also do a system recovering in the bios setup...
Mar 10, 2010 | HP Compaq Presario V6000T PC Notebook
Okay just got this comuter from someone and i cant enter administ
It sounds like it used to belong to someone else. Go to Control panel and set yourself up a new account but make sure the account is set as administrator. Use your new account to add new programs and stuff. Problem solved.
May 04, 2009 | Microsoft Windows XP Professional With...
Volume controls
Just sorted it. The solution is a touch long winded but it worked for me.
Sorry for the delay in replying but i THINK have have the solution which I got of the Saitek forums.
I have had the same problem with VOLUME controls on two MS keyboards and a logitech, this worked a treat.
FIRSTLY check Control Panel->Administative tools->Component services and click "Services (local)", on the RHS look for "HID input service" under STATUS it should say STARTED, if it DOES im not 100% if this will help but try anyway. If it DOESN'T this should work.
Good luck.
Oct 09, 2008 | Microsoft K5100141 Keyboard
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
24 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
