Question about Vector Power On Board High Intensity Discharge Spotlight
Need a replacement charger for SLH100P spotlight power on board
4 Suggested Answers
  • 973 Answers
SOURCE: replacement 6v charger for Garrity spotlight
Contact Garrity at http://www.garritylites.com/contactus.html
Posted on May 25, 2010
  • 973 Answers
SOURCE: Power On Board 3 Million Rechargeable Spotlight
Vector is now owned by Black and Decker since 2006, you can order one at their website, you will need to enter the model #, here is the link http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Posted on Jun 17, 2010
Testimonial: "Thank you so much!! I do appreciate it!"
CarlGlas
  • 283 Answers
SOURCE: I have a Vector HID
The battery needs replaced. In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service. Or, you can order a replacement battery from: www.batterymart.com/p-6v-4_5ah-sealed-lead-acid-battery.html
Posted on Aug 12, 2010
I have a victorlite 1.5 million candle power spotlight lost charger but I have a 12 volt 1000ma- will that work??
If the voltage and tip polarity of your replacement charger matches the charging port on your spotlight, there's no reason why it shouldn't work as a substitute for your original charger. Note, however, that if your original charger was more powerful (say, 1.5 amps instead of the 1-amp charger you have here), it will take noticeably longer to fully charge your spotlight than the original charger took. it's not a problem if the original charger had a lower mA rating than the replacement in your hand--the spotlight will sip an appropriate amount of juice from the charger.
Jul 13, 2011 | Vector 1 Million Rechargeable Spotlight
Looking for a 120V to 12V charger for a Professional"s Favorite 17.5 million cp spotlight.
You should be able to use any AC adaptor that puts out a 12 volt DC current and has correct polarity. Based on the estimated size of the battery powering your spotlight, you probably will want a charger that provides at least 1000 mA of power--the charger that came with my ThorX 10 million cp spotlight puts out 1500 mA to charge the two batteries in that light. A lower amperage rating will increase the amount of time it takes to charge your light, but it should still work.
You can find a replacement charger at Radio Shack, which sells chargers that can be fitted with a variety of different tips. However, you might be able to find a cheaper universal charger with a tip that works at a discount store like a Walmart, or you might get lucky at a thrift shop or second-hand store and find a 12v charger that will work with your light. 12 volts is a common output for a lot of different devices, so it shouldn't be hard to track a replacement down. Just make sure you have the adaptor tip polarity correct, or else you could make your battery explode if you try to charge it with reversed poles.
May 25, 2011 | Camping, Backpacking & Hiking
I need a charger for my Power on Board Sport Spot.
BLACK AND DECKER I THINK BOUGHT OUT VECTOR - BELKIN MAKES UNIVERSAL AC/DC POWER ADAPTERS MODLE F3A114 IS THE ONE I USE - HOPE THIS HELPS! MATTHEW
Jan 11, 2011 | Vector 20 Million Power Series Spotlight
Need ac charger for vec 137co spotlight
Radio Shack sells AC/DC replacement power adapters that will work. Also RV places such as Boat and RV found local or online. Google Boat and RV and they have chargers there for about 12.00 - 20.00. Hope this helps! Matthew
Jan 08, 2011 | Vector 2M Pwr Rch Spotlight
What tip polarity do I use to connect an after market charger?
The short answer is "The tip should be set to positive (+).
I found an old Vector VEC127Y Spotlight. It appeared to be in perfect condition but the battery was dead and there was no charger. I was able to buy a replacement battery at BatteriesPlus for $21 USD. Here is the link for the battery
REPLACEMENT VECTOR VEC127Y BATTERY
I also purchased a Universal A/C adapter to use as a charger at BatteriesPlus for $17 USD. Their site does not list it yet but here is the manufacturers link. Please note the original battery was rated 6Ah. The replacement is only rated for 5Ah. Which means one less Amp hour (Ah). Which means a shorter run time, after charging, than the original battery had. Otherwise they are equal.
UNIVERSAL AC ADAPTER
I installed the new battery. I set the AC Adapter to 6V and installed the largest of the seven adapter tips that came with the charger, with TIP set to be positive (+). I opened the battery compartment of the spotlight and disconnected both the red (positive +) and black (negative -) battery leads from the battery. I then plugged the adapter tip of the Universal AC Adapter into the spotlight and plugged the AC Adapter plug to a power outlet. With a multimeter I tested the polarity of the spotlight battery leads while charging. I was able to confirm that the Adapter TIP should be set to positive (+). After reconnecting the spotlight battery leads and setting the AC Adapter to charge, I have a perfectly great spotlight in full working order.
Dec 02, 2010 | Vector Spotlight - 1 Million Candles...
I have a Vector HID Spotlight Power on Board SLH100P and I'm trying to recharge it. When you plug in the charger the led lights flash and click really fast. What could be the problem? Thanks for your...
Aug 04, 2010 | Vector 1 Million Rechargeable Spotlight
I am looking for the AC adapter?
Try a radio shack or electronics store. Take the light with you to insure you get the correct charger
Jul 16, 2009 | Vector Power On Board High Intensity...
Charger
call 952-884-9191 its dewalt and black and decker factory service they bought out vector.
Jan 11, 2009 | Vector 2M Pwr Rch Spotlight
Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Sep 07, 2008 | Vector 2M Pwr Rch Spotlight
Vector Power On Board High Intensity Discharge Spotlight Logo
292 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Lawrence Oravetz
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
