Question about Denon AVR-587
I have a Denon AVR-587. It has worked fine for 2-3 years, but ever since I tried to connect it to a different set of speakers, it cuts out after a few minutes and I hear this loud clicking sound coming from the receiver as the sound cuts in and out.
There is a short either on the speaker wires to the speakers or the speakers are defective (some sort of a short or too low of resistance). Lastly, check to see if a stray strand of wire is not touch the left and right terminals. Any short in the network (wire, lack of insulation, staple, screw, etc. ) will cause the system to clip.
Posted on Jan 08, 2011
I have connected the audio from 3 devices into the 3 optical inputs on my Denon AVR-3300. Audio for each device plays perfectly through main speakers but not through the multi-room output (which goes to...
the unit is ok. User manual on page 42 says that the digital sources can not be output trough multisource output.
Try to use VCR-1 VCR-2 audio output jacks instead.
Sep 24, 2011 | Denon AVR-3300 Receiver
How can i resetting my avr 587 to the factory default. I can't get it to work correct now. volume comes on wide open when i turn it on.
Assuming you mean a Denon AVR 587,
1. Turn the unit off.
2. Press and hold Speaker A and B buttons at the same time.
3. Still holding Speaker A and B buttons, press the Power button to turn the unit on.
4. The display should flash on and off at 1 second intervals.
5. Release the Speaker A and B buttons.
Jan 28, 2011 | Audio Players & Recorders
Denon avr-587
Make sure that the volume is not muted or too low on the TV...the TV volume output to your receiver will be performing the function of a pre-amp to your receiver. Then select the appropriate input on the receiver that you have the TV audio connected to.
Jul 17, 2010 | Denon AVR-587
My very old Denon AV Receiver (DRA-55V) works fine except that one of the channels sounds 'gated' or thuddy and staticy...music is heard (in all sets of speakers and headphones) but quality in one channel...
check your speaker A - B channel push-button switchces. They tend to get worn and contacts internally corroded after all these years <!-- from fixya rte -->
Feb 21, 2010 | Denon AVR-587
I am trying to connect my new PS3 slim to my Denon AVR 590 and some odd reason I can't get any video signal from my Receiver... Something I am doing wrong?
Double check your inputs on the denon some are assignable, Check cables for looseness hdmi cables are prone to this since they are digital. make sure tv is on the right input and if it is try changing it to a different input "sometimes inputs/outputs go bad"
Feb 18, 2010 | Denon AVR-587
Denon 528 amplifier cuts out after a few minutes
disconnect the speakers and see if amp will stay on. if this the case maybe suspect one of the o/p amps
Feb 08, 2010 | Denon AVR-587
Denon AVR-587 Television input stopped - no sound
try plugging another device into the tv input and mank sure you have the input mode is set to auto if you still have no sound those inputs are gone
http://www.usa.denon.com/ArchivedAVReceivers.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=AV&archivedModel=AVR-587&imageField.x=106&imageField.y=8
Feb 08, 2009 | Denon AVR-587
How Do I Connect My Dell Laptop to a Demon AV Receiver
use a 1/8in stereo to two male RCA plug to connect from your computer headphone out to an input on the Denon such as AUX or CD
Jan 25, 2009 | Denon AVR-587
Denon avr 2802 can't get subwoofer to work all else fine
in the Denon setup under speaker configuration set the sub to LFE+Main
Jan 02, 2009 | Denon AVR-2802
Denon avr-1403/483
Denon AVR-1403/483One of the speakers when connected trips the units power off.
Disconnected it and it works OK without that channel. Connected a different speaker and wire to that channel and it does the same, trips power off. It's acting like a when two wires are shorted. This is not the case as I have tried different wires and speaker. Not sure whats going on. Presently running system without that channel. Hope someone has an idea.
Oct 19, 2008 | Denon AVR-1403 Receiver
Denon AVR-587 Logo
222 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
