Question about Epson Office Equipment & Supplies
Says there is a paper jam and there isnt - Epson Office Equipment & Supplies
  • Epson Master
  • 17,130 Answers
There is an in-detect sensor, usually an opto-coupler triggered by a soft lever, make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull.
Since this seems to be the fault of the paper detect activated falsely in the transport system , the mechanism must be taken out to confirm if there is any chances of physical blocks. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the lever and made it stay or maybe some dirt accumulating on the optocouplers like some jammed paper/glue in the opto-couplers.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper. Reset once you are confirmed of the physical condition. now use a multimeter and check as the paper is inserted that the lever moves and the opto-coupler is activated.
You must be able to trace the signal/voltage change in this period while the paper was inserted to the opto-coupler, if there was a change then the sensor works and the fault is much deeper but if it does not you will need to change the sensor.
Posted on Nov 10, 2010
2 Suggested Answers
  • 1382 Answers
SOURCE: paper jam
To fix this kind of error, remove the ink cartridge and turn the printer upside down and gently shake it.Check if anything comes out.If nothing goes, or you can't hear anything rattling around, get a piece of card stock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there. Open up the printer and clean the insides with a soft cloth and a brush. That should remove all the bits of paper inside.The teeth on the roller sides may have some dirt stuck on them which does not allow the rollers to roll freely and hence is as bad as paper jam. The idea is that the rollers do not roll whether because of paper or some dirt on the roller teeth. They have to be cleaned.
Thank you !!
Posted on Jul 14, 2010
Jam in tray 2 bt there is not paper jams
There may be paper remnants left over from a prior feed jam. Please click the link below and select printers - jams and feed issues to find more info.
HP Color LaserJet 1600 Printer
Aug 21, 2014 | HP Color LaserJet 1600
Says paper jam but there isnt one
off your printer and manually feed paper by turning roller as guide, observe if sensor key freely move when paper pass, some sensor key stock when forcefully remove the jam paper inside.
Apr 05, 2010 | HP LaserJet 1020 Printer
Canon PC735 copier, paper jam light keeps coming on but there isnt any paper or anything blocking the machine. Tried resetting but nothing has worked. What can I do?
My canon copier pc735 says we have a paper jam- but it does not. We just replaced the cartridge and it wont work. I had them send me a new cartridge, but its the same thing- paper jam. Help!
Oct 10, 2009 | Office Equipment & Supplies
Paper jam, but no paper..
could be a hard ware problem..check your warranty
Apr 12, 2009 | HP Officejet 5610 All-In-One InkJet...
Problem with paper jam, but no paper..
1) there should be problem of interference of another signals.
Error message "paper jam"
u need to remove the fuser and remove the paper in it, put fuser back in the reverse
Jun 04, 2008 | Brother MFC-8440 All-In-One Laser Printer
Paper jam
unplug printer from wall and plug back in somtimes this forces trapped paper out of machine as it wrams up.
also remove paper drawer to make sure paper isnt trapped in this area
Dec 06, 2007 | Canon imageCLASS D780 All-In-One Laser...
Paper jams
Fan your paper.
Fan:
Meaning take the paper in your hand and wave it around or page thru the papers, This puts air between the paper to prevent jams.
Make sure you do not over due the paper in the tray. Try lighter paper weight.
Nov 13, 2007 | Lexmark E234 Laser Printer
Paper Jam
you may have broken the paper sensor lever or all of the paper isnt out
Nov 07, 2007 | Dell 922 All-In-One InkJet Printer
32 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
