Close paltalk check your internet connection or modify your firewall settings how can i fix it
3 Suggested Answers
SOURCE: paltalk program
i want to unblock yahoo im on cisco asa 5510
Posted on Jul 16, 2009
SOURCE: Paltalk tells me I have a connection failure, and to check my internet connection or modify firewall protection to allow a connection to paltalk
then by all means take that good advice
solution based on available data
Posted on Jun 20, 2012
I can't connect in my paltalk
Sounds like you need to adjust your firewall settings to allow paltalk to access
Mar 19, 2011 | Computers & Internet
I need help a fire wall setting to connection to paltalk
To open Windows Firewall, click Start, click Control Panel, click Network and Internet Connections, and then click Windows Firewall. If you use the Advanced tab to turn off Windows Firewall for one or more individual connections, the Windows Security Center will report that the firewall is off, even though the firewall is still turned on for other connections. Also, on the General tab, Windows Firewall will still be set to On.
Hoped this helped change your settings :)
Mar 18, 2011 | HP Computers & Internet
Where do i enter my code #
Hello.
Not certain of your question, but first, set up a single PC to connect to the SG565 unit. Information is entered from that PC.
The initial steps are:
1 Connect your administrative PC to the SG unit:
- If you are setting up the SG560, SG565 or SG580, attach your
PC's network interface card directly any network port on switch A
(A1 - A4) using the supplied network cable.
2 Modify your PC's network settings to enable communication with the
SG unit. Click Start > (Settings >) Control Panel and double-click
Network Connections. Right-click Local Area Connection and
click Properties.
Note: If there is more than one existing network connection, select the
one corresponding to the NIC to which the SG unit is attached.
3 Select Internet Protocol (TCP/IP) and click Properties. The
Internet Protocol (TCP/IP) Properties dialog box is displayed.
4 Select Use the following IP address and enter:
- IP address: 192.168.0.100
- Subnet mask: 255.255.255.0
- Default gateway: 192.168.0.1
5 Select Use the following DNS server addresses and enter
Preferred DNS server: 192.168.0.1
6 Click OK and Close
Hope this helps.
Jan 20, 2011 | SG565 (SG0186US) Firewall
How to enable internet on Dell Precision M4400
fistly confir that which antivirus u use.
if it norten, thn follow these step.
Scan for Internet-Enabled Programs and Apply Firewall Rules Using the Interface
  1. Double-click the icon in the system tray to display the Norton Internet Security window.
  2. Click to select Status & Settings and double-click Personal Firewall to display the Program Control screen.
  3. Click the Program Control tab:
    • If the Manual Program Control list is empty, click Program Scan to look for programs that use the Internet.
    • If the Manual Program Control list is not empty, click all the check boxes and press Delete and then OK.
  4. Click the Program Scan tab to display the Program Scan window.
  5. Click to check the scan boxes under choose the drivers you want to scan.
  6. Click Next to allow the Program Scan to list all the Internet-enabled programs found on your computer.
  7. Click All to select all or check the box next to each program name to select the programs that you want to create firewall rules for and click Finish.
new_note.jpg Note: All the programs that you select appear in the Program Control dialog box. In almost all cases, you do not need to modify the Internet Access or Category options. If you do need to modify these options, click the triangle to the left of the option in the Internet Access column and select the change.
  1. Click OK to return to the Norton Internet Security main window.
  2. Re-enable Norton Internet Security and launch the program that is having difficulties accessing the Internet.
  3. If the application now works with your Internet connection, you have successfully created firewall rules for the programs you selected.
    If the application is still not working with your Internet connection, proceed to Check if a rule in Norton Internet Security or Norton Personal Firewall is Blocking Internet Access
Nov 17, 2009 | Dell Precision M4400 Notebook
Sir i cant access yahoo on my system can you provide me any suggestion
I have 3 suggestions: 1. Go to Messenger>Connection Preferences> then, you choose either connection directly to the internet or connect via a proxy server, and then choose type of internet connection>OK>Sign in again... let's try this, may be you can solve this problem. OR 2. Check your internet connection, may be your connection encountered problems...or i think better you should check your firewall settings. I think you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to sign in your yahoo messenger, check it out, may be it blocked your yahoo messenger from sign in. OR 3. Open your Internet Explorer>Go to File>Then, 'uncheck Work Offline', make sure your Internet connection is not working offline. Then, close Internet Explorer, try to sign in your yahoo messenger again. I hope these can be helpful! Try these! Good Luck! Hope it was helpful!
Jun 11, 2009 | Yahoo Messenger
81003004 problem
go click preferences->click connect directly to the internet (again..even though it has been already chosen)-> choose your connection and connect..i guess it will work..it worked for me..try it!
Nov 02, 2008 | Microsoft Windows XP Home Edition
Paltalk
check if you have firewall software and disable it temporarily then try again
Dec 25, 2007 | Computers & Internet
Computers & Internet Logo
130 people viewed this question
David Payne
David Payne
