Question about Sun E2900 Server (E294P16GB1200)
Am getting the following error messages when booting e2900 CPU Board V3 at /N0/SB0 Device poll caused: sun.serengeti.FailedHwException: (SdcAsic)Asic.getTemp: Path broken between CBH and SDC: SB0.sdc.10
  • alberto_asab Nov 17, 2010
    Thanks. We removed one of the memory card and the server is back online without any error message again. But we didn't swap the card to the other slot so we re sure whether it is CPU/Memory board which is faulty or the memory chip.
    Yes it was
  • 13,433 Answers
You are getting a hardware failure notification, which was caused by trying to get the temperature of a processor. The cpu board has a problem.
thats as much as I can translate from the error message.
With all due respect, with a 12K - 20k or how ever much it cost you, you can afford to get a professional repairer or contact sun directly, you are at a user to user helpsite, the cheapest possible support.
It is so extremely unlikely that you would find someone with direct experience with this machine from this website.
Posted on Nov 10, 2010
  • Ekse Nov 17, 2010
    I see, I'll take a note for future reference if I ever see this problem again. Thanks.
    Anything else I could help you with?
As i power on my ricoh mp2000le this is the error i saw. sc 829 code 301 detail ac000000. whats the meaning and solution?
here are some reasons.
1.Self-diagnostic Error: Optional RAM
The optional RAM returned an error during the self-diagnostic test
Resolution - ( Replace the optional memory board
- Controller board defective.
2.Charge roller current leak
The polling module detects a current leak of the charge roller. Causes as follows' • Defective charge roller
• Defective high voltage supply board
• Loose connection of the PCU.
Feb 26, 2015 | Ricoh Office Equipment & Supplies
Unformatted disk error message
Make sure your storage settings have not been altered. A dying battery on the units man board can cause this.
May 18, 2014 | Yamaha Disklavier Control Unit Dkc500r
Dell Optiplex 330,won't boot memory parity error, tried new bios battery, new ram stick, still won't boot,actually had two at same time the other I ran a advanced diagnostic test said hard driv
I found this
Customer's Optiplex 330 did the same thing today; no beep codes (due to lack of on board speaker). Solid/orange light on front of case indicates board or cpu. I isolated every component not soldered down (RAM, HDD, Optical, etc). Considering all the fans and lights on the MoBo were functioning, and no physical damage to the CPU was apparent, and the BSOD presented the "memory parity error; system halted" (meaning it's memory, graphics memory, or cpu and we've eliminated possibly CPU and RAM) my conclusion is that the problem resides in Graphics memory failure. Considering the error message is very vague and generally insists "motherboard", the gpu in an optiplex 330 is integrated ON the board, lumping it all together.
and general memory parity fail information
memory parity error fix Google Search
Nov 22, 2017 | IBM ThinkCentre Computers & Internet
USB ports not working, slow computer
The error you are getting is the USB port driver. I suggest disconnecting ALL of the items you have connected to ALL of the USB ports and rebooting. If the computer reboots normally, go back and install ONE and ONLY one USB device. Restart your machine. If it boots OK, shut down, remove that device and connect another one, restart again. Do this for EACH of the USB devices until you find one that causes the computer to boot slowly and/or generates the error message. That one is the culprit and needs to be repaired before reattaching to your system.
If, however, after removing all of the USB devices initially and rebooting, you still get the error message, then you have a USB driver problem. You will need to remove the USB driver and reinstall from a known good location (like HP's website) to fix the driver problem.
Jan 07, 2010 | HP Pavilion a1210n (ED895AA) PC Desktop
PC won't boot up. Thinking the CPU may be bad. How can I test the CPU output?
turn it on and hold the shift key while it trys to boot,or ctrl key if that dont work.
Sep 20, 2009 | eMachines T1440 PC Desktop
System boot problem
This is possibly a bad hard drive. If you know the manufacturer of your hard drive you can download diagnostic tools from their site, burn to cd and run diagnostics to check the drive for errors or failure.
Apr 11, 2009 | ASUS A8N-SLI Premium Motherboard
Shutdown requested due to temperature problem-E2900
Dear,
Open the front cover and make sure all the fans are working well. If not relplace it. Check the room temperature, it should be below 20 Degree C
Apr 04, 2009 | Sun E2900 Server (E294P16GB1200)
CMOS checksum bad 0085
the problem might lie in the fact that the mother board and cpu cannot be handled at the speed
or it requires the jumpers to be set by so that the cpu can be clocked properly if you got a mother board spec guide follow the guide for *********** board to set up 3.2
you might also have to set the bios to the cpu speed cause if mother board doesnt do jumpers no more the setting would be in bios
hit the delete key direct are power up this will take you to bios
its not the battery
Jun 05, 2008 | Intel Motherboard
MIDlet suites
On games and Apps on my Motorola V3 Razr I keep getting the message "No Installed MIDlet Suite", How do i fix it?
Nov 16, 2007 | Motorola Mobility RAZR V3
Sun E2900 Server (E294P16GB1200) Logo
1,086 people viewed this question
Top Sun Computers & Internet Experts
Robin Hill
Robin Hill
k24674
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
