Question about Little Tikes Toys
How do I disassemble the lil tikes Slide and Hide unit? I cant begin to pull it apart and am afraid to use a sledgehammer on it, but am tempted right about now. Please help. Thanks, Nancy
4 Suggested Answers
SOURCE: Disassembly of Little Tikes Wave Slide playground
Hi there! On putting together my daughter's hide and slide (not having ordered it or seen it before) followed the instructions and managed to put the bottom step inside the frame instead of outside. Of course other half only noticed it once I had put the top step in - so to take it apart you will need the following:
Two long heavy duty flat bladed screw drivers and a lot of muscle!
First take the top platform on one side and disengage the two tabs on one side. Then insert one of the srewdrivers under the red locking tab and push up - the plastic will distort however, returns to original shape with judicious use of a heavy hammer. You will need to use the second screwdriver to disengage the clip in the tab and then twist the platform out of the frame to release the second. Repeat for the other side. The bottom platform is a just a reversal of the installation to release. I haven't moved the slide but as this is a 'gravity' fix should release with a bit of 'persuasion'. As these things are not designed to be taken apart after assembly they are frustrating to take apart - but with a little flex and muscle it can be done. Hope this helps.
Simon
Posted on Aug 02, 2009
SOURCE: We have a 'Little Tikes Hide and Slide' and we
The key is the red locks on each side of the climber wall. Be careful not to force the red locks open because it WILL cause them to tear on the seam.
I used two big flat screwdrivers and another pair of strong hands. What I did was I inserted the screwdrivers in between the outer part of the red lock and the yellow wall, leaving just enough gap between the screwdrivers for a hand to slide in. Then pushed the screwdrivers outward as lever to loosen up the lock. Then my husband finished the job by inserting his hands between the gap created by the screwdrivers and pull.
I hope this is helpful for you, as I know I'm better in demonstrating than describing.
Posted on Apr 24, 2010
SOURCE: I am trying to disassemble a hide and slide from l...
I need to know how to get the red brackets off. Did you ever figure it out???? lynse_k@rogers.com
Posted on Apr 18, 2011
Help! I have a Little Tikes outdoor play set with
I am looking for a replacement tunnel for ours. Would you be willing to sell the tunnel??
To take apart...Start with the slides, remove the rods first. Then select any exterior panel corner and pull up on one side and push down on the other. The tabs just slide, there is no hardware to loosen. Hope this helps.
Jul 18, 2009 | Little Tikes Endless Adventures Playcenter...
We have a 'Little Tikes Hide and Slide' and we need to take it apart. How do we do this (without breaking it)?
Jul 10, 2009 | Little Tikes Toys
The key is that one side/side combination must be done 1st then the others are easy. On ours I think it is the yellow/orange combination. Just try all the combinations. One works pretty easily, the others do not. We struggles too until we found the right combination. good lluck
Jul 09, 2009 | Toys
The drivers door keeps coming open. I'm afraid our gson will fall out! A door lock is mentioned on the Little Tikes website but I don't see a lock on the used one i just bought. Duct tape looks pretty...
It sounds like it was installed incorrectly to begin with. What modle do you have? You can call Little Tikes and request an assembly guide and that might be able to tell you if the first person put it together correctly. You can then take it apart and reassemble. Otherwise, let us know exactly what you have and we can provide further help. Good luck. 1-800-748-2204
Jul 01, 2009 | Little Tikes Cozy Push and Ride Car
LG Dehumidifier 3 years old stopped circulating resulting
Approached unit with air of trained appliance repair professional. Found Chinese-made product of vastly inferior quality, began series of tests, moving on to systematic disassembly finally sledgehammering the unit thence noting it failed to improve performance. resolved to not buy junk made in China or elsewhere. I've been "fix-ya'd" all right! Over and out.
Jun 13, 2009 | LG Dehumidifiers
Disassemble
This is very difficult to do and most electronics service centers will even recommend sending the unit to Pioneer. You'll not only have to remove the outer case from the hide away unit, but you'll need to take out the main circuit board as well. You may also be able to find someone selling just the hide away unit on ebay too.
Aug 10, 2008 | Pioneer AVIC-N1 Car DVD Player
Toys Logo
3,130 people viewed this question
Top Little Tikes Toys Experts
 Russ Hill
Russ Hill
Brett Duxbury
Brett Duxbury
Bill Boyd
Are you a Little Tikes Toy Expert? Answer questions, earn points and help others
