Question about Xerox WorkCentre M20i All-In-One Laser Printer
Workcenter M20i Printing Problem
The printer in the office has a problem. It prints fine on the right side of the page but the left side has spots where it isn't printing the document completely. I changed the print cartridge and I'm not sure what else to do.
  • Anonymous Aug 27, 2008
    Hi we are having some problems with our printer ..the paper keeps getting jamed what do I do?
    President:
  • 2,072 Answers
If the issue is only when you are copying, the scanner needs to be cleaned.
If the defect is on both copies and prints, and fax if you use it for that, then your problem is either the drum or toner cartridge or the laser is dirty.
I am not sure when you say you changed the print cartridge if you mean you just changed the toner cartridge or the drum cartridge.
Posted on Jun 17, 2008
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
Dec 25, 2015 | HP LaserJet 2840 All-In-One Printer
Booklet layout
Is page on printing on the left hand side or right hand side?
<a href="http://stashbox.org/77137/printing.png">http://stashbox.org/77137/printing.png</a>
<img src="http://stashbox.org/77137/printing.png">
Jan 31, 2008 | Dell 922 All-In-One InkJet Printer
How to print a configuration page on a m20i
We encourage you to use our knowledgebase, MRC Smart Technology Solutions is here to help! We offer a program to cover up to 3 printers of any manufacturer for an entire year!
We can solve your problem!
Email patrick@mrc360.com for more info.
Solution : Print a Connection Page (Network Connectivity Report / Configuration Page) NOTE: Print the Connection Page to locate the TCP/IP Address for the WorkCentre.
  1. Press the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
  2. Press the [Up or [Down] arrow button until 'Reports' is selected, and then press the [Enter] button.
  3. Press the [Left] or [Right] arrow button until 'Connect Page' is displayed, and then press the [Enter] button to print the report.
  4. Press the [Stop] button to return to the Standby mode.
http://www.support.xerox.com/support/workcentre-m20-m20i/support/enus.html
Oct 13, 2014 | Xerox WorkCentre M20i All-In-One Laser...
Ink spots on envelopes
Hi rebecca,
Go To Below official Hp Printer Forum Page For Your problem And Solve Your Problem Black ink stains envelopes when printing HP Support Forum 955951
Feb 24, 2014 | Canon PIXMA MX340 Wireless Office...
I am trying to print a booklet 2 pages per sheet double sided. Printing is OK but spacing is no good for the binding when the pages are cut in two. What instructions should I give the printer to allow...
Hi
By spacing, I assume you mean the margins at the centre.
The default margin settings are not the same for the right and left hand side of the page, so the printing on the reverse side is offset from the printing on the first side.
The right margin is always wider to allow for punch holes in file paper.
It is not the printer settings you need to adjust, it is the page layout of your word processing software.
Adjust the margin settings manually. In MS Office 2007:
Page Layout > Margins > Mirrored Margins.
Hope this helps.
Aug 24, 2011 | Canon PIXMA MP610 InkJet Printer
Not printing right side of page
Check the page format and margins.
Page format should be A4 or letter. Margins should be set to lower.
Nov 29, 2017 | Lexmark Optra S 1620 Laser Printer
XEROX workcenter M20i prints codes at bottom of page
someone has gone into diagnostics and enabled Status Print Engine
Fix
1. press menu/exit key
2. enter # 1931 in that order
3. engine test(diagnostic) should be displayed
4. use arrow keys to scroll to, then select engine test(status print)
5. press enter
6. press the "2" key on numeric keypad to disable (status print)
7. machine will revert to Ready to Copy
8. power off and then back on the M20
9. Your done.
May 02, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Envelope Printing on HP 5610
Installed SR-3 from Office Word. It did the trick.
Mar 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
Xerox WorkCentre M20i All-In-One Laser Printer Logo
153 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
