Ihave benkin wireless card though I have inserted the card and installed it is not being connected
  • tim brauer
    tim brauer Nov 10, 2010
    is this a usb wireless card?
    Habit-Forming:
  • 146 Answers
When you insert the card and it installs the first time make sure you use the windows wireless zero configeration option and let it finish then it should auto detect from then on rater then using the third party software that comes with it
hope this helps and good luck with the problem and by the way don't forget to vote for this solution
Posted on Nov 10, 2010
New built computer with motherboard Asrock Z77 extreme4. I inserted a pci wireless adapter tp-link wn851n into the pci slot of the motherboard. I turn on the computer, install the drivers, but the...
need to look at the device drivers, windows 10 is righ click on windows logo and click on device manager and check its there. if its not the check on the motherboard info to see if there is a jumper you need to adjust for the motherboard to recognize it.
Aug 04, 2017 | Computers & Internet
How do I change from wired hookup to wireless? Bob
Instructions
Things You'll Need
Broadband modem
Router compatible with modem
Internal or external wireless network adapter
Phillips screwdriver
Suggest Edits
  1. Prepare the Network
  • Purchase and setup a wireless broadband router by interfacing it with your wired computer. Choose a router that is compatible with your broadband modem and that supports the wireless network type you desire.
  • Enable WPA or WPA-2 security, and change your router's default password. Give your SSID or wireless network a memorable name.
  • Connect your modem to the WAN (wide area network) port on your router.
  1. Install an Internal Card
  • Purchase a wireless network card that is compatible with the router you purchased and with your computer. For example, if you bought a 802.11 b/g router, do not purchase an 802.11 n adapter.
  • Shut down your computer. Remove all cables and peripheral devices.
  • Remove the left side panel while facing the front of the case. You may need to remove screws or to manipulate latches and notches. Consult your case or computer manufacturer's documentation if you are unsure of how to remove the panel.
  • Clip the metal part of the anti-static wrist bracelet to a metal object, and ******** the bracelet.
  • Locate an available PCI or PCI-Express slot. Unscrew the screw that secures the slot cover that corresponds with the slot, then remove the slot cover.
  • Line up the wireless adapter's pins with the slot. Insert the card until it clicks into place. Do not force the card into the slot, or you may damage the card's connectors. If you feel resistance, remove the card, line up the card with the slot again, and reinsert.
  • Secure the card with the slot cover screw. Reattach the side panel, and replace any screws you removed earlier.
  • Reinsert all cables, and plug in all peripherals. Boot the computer.
  • Allow Windows the opportunity to detect the card. It should automatically install the drivers for the card. If you have updated drivers, insert the disk and install according to on-screen instructions.
  1. Install an External Card
  • Boot up your computer.
  • Insert your external wireless adapter into the appropriate slot. For example, if you purchased a USB slot, insert it into a USB port.
  • Complete Setup
  • Double-click the network icon in the task bar.
  • Highlight your wireless network. Windows will display the name you entered when setting up your router
  • Click the "Connect" button.
  • Enter and verify the security key you created when setting up the router. Click on "Connect."
If you have further query then try to let me know. Thanks for using FixYa.
Aug 27, 2011 | Cisco Linksys Wirelessn Router Black...
Dear Sir, There is no provision of fixing my laptop to a wireless router.Can anybody advise how to convert this laptop to enable getting wireless connection of internet?
There's a lot of available wifi adapters out there that you can just plug into your laptop's usb port. You can try looking them up online or in computer shops.
Jul 29, 2011 | Computers & Internet
Hello sir ihave a dell computer.but dsl dont work on it.so i put lan card in place of modem area then dsl works.but the own place made in my cpu where the dsl wire is inserted dont work. i installed all...
did u connected it well..
cos there are two wires to be connected
i also installed a new hard disk
and forget to insert a small cable to it
tell me if u did it great
check it if u did
co some times system dont take it once
May 16, 2009 | Dell Computers & Internet
How do i get an internet connection using belkin wireless g plus mimo notebook card
1) Install the wireless card on your laptop computer (driver)
2) Run wireless utility (windows - Control Panel)
3) Select your wireless network (wireless networks availables) and connect.
If your wireless network have a wep key you need to know that in order to get connected.
To do that you need a wireless router connected to your modem or a wireless modem
Be sure first to have that installed first.
If you have more questions please let me know to help you out better with this issue
Nov 07, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Insatlling wireless in a samsung v20 laptop
Here are a few examples of the type nof card you'll need to connect wirelessly:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2030260034+1178314606&name=802.11b%2fg+PCMCIA+Wireless+Adapter
You can buy PC-Card (PCMCIA) wireless cards at most any computer electronics store/website.
Install the driver, insert the card, then configure the wireless connection.
Jul 10, 2008 | Computers & Internet
Acer 4315 install wireless key
what do you mean wireless key ? is it wireless usb ? or wireless card ?
did you buy it from acer ?
if it is wireless usb adapter, just plug it in the usb port and install the driver for that usb.
if it is wireless card (acer). Open the back of your laptop, you can see the slot. just insert your wireless card in to the wireless slot and attached the both wireless antena (is should be black and white)
May 03, 2008 | Acer Aspire 5100 Notebook
Wireless connection
before you insert the card to the slot run the cd thats comes with it and install the software. after installation of the software insert the card. if it is properly installed, you will see a single computer icon on your task bar click it up and search for a network.
Feb 11, 2008 | Computers & Internet
Setting up a wireless connection between my linlsys pcmcia card and my 2 wire gatway
first insert your pcmci linksys card into the laptop, you would find a found new hard ware screen, insert the setup disk, and then follow the steps, automatically your card would be installed, once the installation is done, the wireless adapter , would detect wireless signal, try connecting to the wireless network.. if it asks for any key, look at the bottom of your 2 wire router you would find a 10 digit number, enter the number as the number as key code or password, automatically you would get connected.. if case if you have any problem , revert back ..
Nov 19, 2007 | 2wire HomePortal® 1800HW Router...
Computers & Internet Logo
18 people viewed this question
Alun Cox
David Payne
David Payne
