Question about Electrolux ICON Designer E30SO75ESS Oven
To self clean the Electrolux oven do I need to spray the walls first with a cleaner before I do the self cleaning mode?
SOURCE: Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
Posted on Dec 25, 2007
  • 905 Answers
SOURCE: I have an electrolux icon
yes, if the humming is not the loud sound then the fan may need some lubrication or if it is tripping the circuit it will need replacing , but if it seems like it is a viberating noise from the fan , then it could be that its bearings are bad , but the whole fan motor would still need to be replaced , but if it sounds like it just may be a loose fan motor , then tightening up the screws on the motor would stop the vibrating sound and or the fan blades from scraping metal( another sound you may be hearing )
Posted on Dec 24, 2008
SOURCE: I cannot get my Electrolux
I finally figured it out! The rack supports actually come out also. Not just the sliding supports, but the whole metal part with all the supports on it. At first I thought they were bolted in, but I read somewhere that they come out, too. Upon further investigation, I found the rack supports just slide into the side walls at 4 points. I had to use a little force to pull them out, but they came out and my oven is self-cleaning as I write this. I just thought I would share in case you or others haven't figured it out yet. Now I will just have to see how hard it is to get them back in....
Posted on Feb 21, 2009
SOURCE: Electrolux Icon Oven won't self clean - "Remove Racks" displayed
I was getting the remove rack error until I finally figured out what it wanted me to remove. When you say you removed the rack supports, do you mean just the sliding parts or the whole side metal rack support? At first I thought they were bolted in, but I read somewhere that they come out, too. Upon further investigation, I found the rack supports just slide into the side walls at 4 points. I had to use a little force to pull them out, but they came out and my oven is self-cleaning as I write this. I just thought I would share in case you or others haven't figured it out yet. Now I will just have to see how hard it is to get them back in...
  • 44 Answers
SOURCE: How to clean the inside of the glass door of Electrolux Wall Oven
Hi
open door and along top you will see 2 screws undo but hold door at same time then just lift out and clean.
hope this helps
Posted on Mar 21, 2009
Self oven cleaner
Hi Debbie, this is AP
I understand you are having trouble getting the self-clean mode on your Electrolux ICON wall oven to start. On this model, E30EW86GSS, you must remove the rack supports in order for the self-clean mode to start. To remove the oven rack support for
a self-clean cycle, pull up the support to disengage them from the brackets. If the rack supports are not removed, the self-clean cycle won't start. If you find that this does not resolve your concern and you following the self-clean instructions precisely I would recommend contact a local authorized technician to inspect your wall oven. I you need assistance locating a technician please visit the manufacture website for additional information. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect if you have additional information regarding your question.
Thanks,
Mar 18, 2014 | Electrolux E30EW85GSS Oven
My oven show lock sign and i can not open it
If its a self cleaning oven it might be in clean mode. It usally takes 4 hours to clean. If its been more than 4 hours, it might be an electronic issue. Try unplugging it for about 5 minutes and plugging it back in.
May 23, 2011 | Electrolux 30" Built-In Single Electric...
Hi, is this oven self cleaning or can I use chemical cleaners to get the oven clean, especially around the fan? B x
Hi, W/D here.
Ovens just love for you to use the self cleaning feature on them. This gives them all kinds of excuses to lock up, fail components and have other components become "unpredictable". Self cleaning takes the oven to extremely high temperatures to incinerate the baking residue. This also uses a high amount of energy. My best advice is to clean the oven with the spray cleaner whenever possible, and to avoid the self cleaning feature altogether. Use normal precautions with the spray, following the directions on the can. This will do the job just as well, and takes much less time. Just make sure that the product that you use says "safe for self cleaning ovens", and you'll be fine.
Best regards, --W/D--
Feb 17, 2011 | Ovens
Tried to clean single Electrolux wall oven. The cycle began, the door locked and then the oven shut down with the door locked. I shut off the breaker for 10 minutes and then back on, no change. I checked...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jan 20, 2011 | Electrolux ICON 30 in. Double Wall Oven
How do set the self cleaning option on the Electrolux icon oven
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Jan 05, 2011 | Electrolux Ovens
I've tried cleaning my hotpoint self cleaning oven, but its not cleaning ,so what can I use to clean it ?
Just purchase a good oven cleaner, generally available at most supermarkets, they can be a spray type cleaner, or a gel that you brush on, personally, I prefer the spray on type of cleaner.
Nov 14, 2010 | Hotpoint Ovens
How to self clean the oven?
Get some easy off oven cleaner and go by directions. Using the self clean function damages expensive oven controls. My opinion. Electrolux stove service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 13, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
How do I clean oven
Hi
These are the things you will need to clean your oven.
Oven Cleaner, Soft Rags, Sponges, Oven Cleaner and a Sponges.
Remove oven racks and place them in soapy water to soak.
Preheat oven to 200 degrees.
Turn the oven off and spray the inside with oven cleaner.
Allow to sit for 10 minutes.
  • Read more: How to Clean an Oven | eHow.com http://www.ehow.com/how_2017_clean-oven.html#ixzz0v7mMYimF
    Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
    Dry with a soft cloth.
    Thanks.
  • Step 4 Allow to sit for 10 minutes.
  • Step 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • Step 6 Dry with a soft cloth.
  • Read more: How to Clean an Oven | eHow.com http://www.ehow.com/how_2017_clean-oven.html#ixzz0v7lkil29
  • Step 3 Turn the oven off and spray the inside with oven cleaner.
  • Read more: How to Clean an Oven | eHow.com http://www.ehow.com/how_2017_clean-oven.html#ixzz0v7lanRHk
    Jul 30, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Electrolux wall oven not heating after self cleaning -- fan is going -- but it is not heating
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    May 17, 2010 | Ovens
    Electrolux ICON  Designer E30SO75ESS Oven Logo
    41 people viewed this question
    Top Electrolux Ovens Experts
    Steve Allison
    Steve Allison
    John Tripp
    John Tripp
    Are you an Electrolux Oven Expert? Answer questions, earn points and help others
