Question about Panasonic TH-42PX60U Television
I found the location of the fuses...but no numbers on them...where would i go to purchase something like this for the PANASONIC TH-42PX60U
    President:
  • Panasonic Master
  • 1,779 Answers
The Amp rating is usually stamped on the board very close to the fuses. If they are white in color then they are called ceramic fuses, but still have an amp rating. If they are Pico fuses they also have ratings that are close to their location on the board. DO NOT go above the amp size it calls for. If the new one blows then you have a related short to that particular rail. Have it serviced.
Posted on Nov 10, 2010
Replaced 2 TH8AH blown fuses. led flashes 10 times
Fuses do not blow (more than one) for no reason---which fuses and where?
10 blinks is usually power supply board but can be something connected to it.
May 22, 2012 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
Need service manual for Panasonic th-42px60u
Had this problem been solved?
Here is a link where you download the operating manual and other manuals that you need for this TV
http://www.generalmanual.com/Televisions/Panasonic-TH-42PX60U-Plasma-TV.htm
Jun 25, 2011 | Televison & Video
PANASONIC TH-42PX60U 42 - half of screen not working
I had the same issue. I am going to replace my scan buffer boards. The upper half of mine works but the lower half is black so I would replace the lower Scan buffer board but in case of future issues I have ordered both upper and lower for $44.
The scan buffer boards are fairly simple to locate. Open up back of tv there are two biffer boards identical. The item or product code on them contain letters either SU or SD (Scan up and Scan down)Look up tv parts and item code you will find a place to order or just get the 1 800 number from tv manufacturer.
Jun 18, 2010 | Panasonic TH-42PX60U Television
TH-42PX60U wont turn on. Blinks 10 times. replaced the power supply board, but the same issue.
What I'm learning is there are several models of Panasonic TV's that have a video card that doesn't play well with HDMI applications and the end result is, you need to call this number and not only make arrangements to replace the bad board,but also this!
Your model doesn't show below,but I'd certinly inquire about the necessity of a "Firmware" update!,,,Panasonic knows FULL WELL they have a HUGE problem here!
Hope this helps!
At panasonic.ca I found the listing for the fw update under customer support-important notices
If you own a plasma TV with model and serial number within the range specified below, please contact our toll-free VIERA Concierge hotline service at 1-866-330-0014. A VIERA product expert will arrange an in-home software update for your TV at your convenience.
Model Numbers Serial Number Range
TH-42PZ77U
TH-42PZ700U **71250001 ~ **80189999
TH-42PZ700UA
Jan 28, 2010 | Panasonic TH-42PX60U Television
Panasonic plasma hdtv will not power on--no blinking LED, simply no LED. Other objects plugged into same surge protector are fine; no evidence or suggestion of a power surge.
The power supply board itself maybe the main problem inside the TV. Or, it maybe something simple like a blown fuse. Replacement fuses can be found at Radio Shack or some other electronic supply store.
If it turns out the TV keeps blowing fuses, the main power supply may need to be replaced. You can find replacements at a good price at Shopjimmy.com
Sep 12, 2009 | Panasonic TH-42PX60U Television
Our panasonic th-42px60u will not turn on. It went out during the middle of watching and will not turn back on.
Un plug it, let it set for 5 min or so then plug it back in. If it's still out, remove the back panel and check the fuse near the AC input. If you need more help, post a comment and I can help some more.
Jul 08, 2009 | Panasonic TH-42PX60U Television
TH-42PX60U red light blinks 10 times wont come on
On a Panasonic TV the 10-blink error code can sometimes be caused by low voltage running through an HDMI cable, particularly from a Media PC or some video game consoles. Try disconnecting any HDMI cables and unplugging the Television for 30 seconds, then power it on without the cables attached.
If this works, connect the cables to the front panel (usually HDMI-3) which uses a different controller board.
Dec 08, 2008 | Panasonic TH-42PX60U Television
Panasonic TH-42PX60U HDMI stopped working
Please unplug TV from AC outlet and replug it after 5 minutes then check HDMI port.
Nov 28, 2008 | Panasonic TH-42PX60U Television
Panasonic TH-42PX60U Television Logo
278 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
