Question about Panasonic Televison & Video
Panasonic Tau Model CT 34 wx52 turns on, then right back off, stays off, wont turn on again. sometimes leaving it unplugged for a while allows the process to be repeated, but never stays on, fuse was fine, but replaced anyway, of course to no avail
  • 556 Answers
SOURCE: Panasonic CT-32HX42F Powers down by itself
it is due to plug or socket loose or sparking in that area. if it is ok then it is due to some component failure in power supply of tv. as per schematic is concern please go to. www.serviceinfo.com go in search & give model no.it is freely available.
Posted on Oct 06, 2007
Bappa170873
  • 505 Answers
SOURCE: Philips/Magnavox TV, model MS3250C321 shuts off randomly.
TV shutting off automatically means its a problem with the Lamp. Contact Pioneer or any local tech shop or Best buy and get the same replaced.
Turning off after specific time : Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
Posted on Oct 17, 2008
SOURCE: panasonic tv has blown second fuse in a week
You have a Voltage regulation problem.
Posted on Mar 15, 2009
  • 8457 Answers
SOURCE: I have a Panasonic TAU CT-27SC14J TV lost sound
Ur video/Audio board have a short or lose a connections.Must take it aparts retighten everythings,might even resoldiers the parts.
Posted on Aug 19, 2009
  • 88 Answers
SOURCE: i have a old tv 36 inch panasonic ct-36d30 my tv
sound like yoke short problem. replace same yoke as possible . good luck!
Posted on Apr 29, 2010
Panasonic HDTV 10801 BBE TAU
Unplug it for a few seconds and
plug it back in if this doesn't
do it the call in a technician
may be HV or PWR Sply problem
Nov 29, 2007 | Panasonic CT-32HXC14 32" TV
My panasonic tau ct-34wx52 tv shut off by itself, now only clicks
Its power supply regulator section circuits need to to be troubleshooted.
Apr 26, 2012 | Televison & Video
24" Panasonic Tau... about 9
Tv is old the tv CRT-(tv tube) it CRT Yoking circuitry not good as before.The tv deguassing coil in not eleminating all the interference of the tv functions anymore.Move the tv unit to the right or to left like about 3 or 4 inches either sides will help for this problems.
Apr 18, 2011 | Panasonic CT-24SL13 24" TV
Panasonic 32" GAOO just atarted doing this...Turn
The Panasonic Gaoo sets were top of the line in it's day, the problem you are describing is a vertical deflection issue caused by bad solder joints and a few parts. I recommend a tv technician to fix the set.
Jan 09, 2011 | Panasonic CT-34WX50 34" TV
I have 36" Panasonic CT-36SX12 TAU series. I had it repaired less than 3 years ago .and the same problem happened again As soon as turned the TV off it wouldn't turn back on .I was told this was the...
I would check the remote control by taking it out of the room first. If that is not the problem, it is likely to be a dry joint in the power supply that is "arcing" and causing this problem.
Re soldering the heavy components on the power supply board may fix it.
WATCH OUT FOR CHARGED UP CAPACITORS - THEY ARE LETHAL WHEN CHARGED!
Oct 16, 2010 | Panasonic CT-36SX12 36" TV
I dont have a remote for my tv and it wont turn on manually the led light blinks 9 times and stops and starts again what should i do?
The blinking lights are a service code. You should first try to unplug your TV and leave it unplugged for at least 4 hours... then plug it back in again.
If the blinking light is still there and no picture, time to have the TV serviced. Good luck!
Oct 10, 2010 | Panasonic CT-34WX54 34" TV
PANASONIC 36" TAU --- NEED HELP
Sounds terminal. Companies build things with "planned obsolescence" in mind. In other words. You buy a TV today, and the warranty says it's good for 4 years. 4 years and 3 months later, it dies.
I hope someone else can help you.
Good Luck!
Apr 01, 2017 | Panasonic CT-36D32 36" TV
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
Picture tube doesn't turn off
The power relay driver or the relay itself is bad. Its sticking closed so the voltage is there for the power supply but the micro has turned off the tuner.
Sep 15, 2006 | Panasonic CT-27G23 27" TV
Televison & Video Logo
59 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
