SOURCE: head bolts torque settings
According to my haynes manual for G-S reg, 1989-1998 it goes as follows,
Stage 1:- Tighten all bolts by hand until bolt heads just contact cyl. head.
Stage 2:-Tighten all bolts to 40Nm or 30lb ft.
Stage 3:-Angle tighten all bolts a further 60 degrees.
Stage 4:-Angle tighten all bolts again a further 60 degrees.
Stage 5:- M12 x 140mm bolts ONLY angle tighten a further 20 degrees.
Hope this helps everyone, sorry it seems longwinded but that is how it's written in the manual.
SOURCE: Angle Torque settings head bolts
Use new bolts, tighten in the following stages
1. 20Nm
2. 100Nm
3. wait 3 mins
4. slacken bolts 1&2 retighten to 20Nm +110 degrees
5. carry out stage 4 for bolts 3,4,5 & 6
then bolts 7,8,9 &10
Sequence,
8 4 1 5 9
7 3 2 6 10
Bolts 9 & 10 are flywheel side of the engine.
SOURCE: Craftsman 3.5 hp portable air compressor keeps blowin head gasket
I would say the head or block is warped. Use Majic Marker to cover the mating surfaces , the head can be rubbed on a flat surface like a cast iron table saw to find the high spots, or the head can be rubbed on the block.
Careful work with a good flat file will remove the high spots.
The torque value sounds low even for an aluminum block, you could check with a small engine shop to get their opinion.
Place the crankshaft pulley bolt removal tool over the end of the crankshaft bolt. Tool will hold the pulley in place while you apply torque to the bolt with an impact wrench. Start the air compressor by plugging it in and turn it on. Set the pressure of the compressor on the highest setting. Attach air hose on the air compressor to the air inlet and the locking mechanism using the quick-connect lock on the end of the air compressor hose. Set the impact wrench to turn counterclockwise. Spray the crankshaft bolt with penetrating oil. Make sure you soak the bolt head in oil so that it is easier for the wrench to remove. Secure the socket end of the wrench to the pulley bolt and pull the trigger on the impact wrench. You might need to reapply penetrating oil several times during this process to loosen the bolt up. Eventually, the bolt will come off 215 lbs torque, and simply stated righty tighty, lefty loosy. Hope this will assist you.
