Washer I have a frigidaire washer that won't change cycles automatically. What could be the problem.
    President:
  • 1,294 Answers
Check out your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Some connect to sink, fine. Snaking out your standpipe would be good too.
If the above fails, check to see if your pump is blocked.
Posted on Jun 17, 2008
Clean tub options keeps blinking on affinity frigidaire fafs4474lwo model
Hello Jodi, thank you for your post!
Your Frigidaire washer (FAFS4474LW0) will automatically prompt you to run the CLEAN WASHER cycle typically every 50 cycles. If you wish to begin the cycle, press SELECT when prompted. This maintenance cycle uses hot water and two rinses to remove residue that may cause odor. For best results, I recommend to use the CLEAN WASHER cycle once a month
You may press the CANCEL button to manually perform the cycle at another time if you prefer. You can do this by following these directions:
    ·Rotate cycle knob to Rinse & Spin
    ·Then press the CLEAN WASHER option button
    ·The LCD screen will display "SYSTEM CLEAN"
    Hope this helps! - Z
Jul 19, 2014 | Frigidaire Fafs4474lw Affinity 3.81 Cu Ft...
I have a frigidaire gallery front load washer that won't start a regular wash cycle.When i select a regular cycle and pull up the start knob,the cycle light comes on and nothing happens.When i mov
Good Afternoon Leszek - Thank you for your question. Based on the symptoms you are describing it sounds like the unit has a faulty timer or a potential wiring failure. Try reprogramming the unit by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn on the unit. If issue persists, then at this point I strongly suggest reaching out to a professional that can accurately diagnose and repair the washer.
Jun 09, 2013 | Frigidaire Washing Machines
Frigidaire washer won't finish cycle
Hello Ellen Greer - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly, faulty pump or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Nov 14, 2012 | Frigidaire ATF6000ES Front Load Washer
I have a Frigidaire Gallery 13 cycle commercial HD super capacity washer and it will not change cycles automatically. Is this something I can fix myself?
Yes, you can fix this yourself very easy. You will need to replace the "timer". Here is the part you need to order. To install the timer, you will need to remove the back cover on the control panel and gain access to the timer. Then remove the knob from the timer and release the tab holding the timer in place. Slide the old timer out of the unit once the tab is released and unplug the wires going to it. Re-install with the new timer in reverse order.
Keep me posted!
Oct 31, 2012 | Frigidaire Gallery GLWS1339EC Top Load...
Detergent won't enter wash cycle
Clean the dispenser first and see if you noticed any blockages and then clean the unit itself in the dispenser area and use a little less than recommended and see if you notice any changes.
Jul 29, 2012 | Frigidaire ATF6000ES Front Load Washer
Washer will not spin The washer is a frigidaire front loader model LTF2140E53. will cycle through all settings, but will not spin. Cycle ends with clothes soaked.
I have thata probelm a lot too. I have read that the controls don't sense that the door fully shut. You might try slamming it shut, jiggling the door, poking in the hole where the latch goes. When mine won;t spin, slamming and jiggling works.
Jan 24, 2010 | Frigidaire ATF6000ES Front Load Washer
FRONT LOAD WASHER WON`T SPIN DRY AT END OF CYCLE
CLEAN OUT PUMP IS THERE WATER STILL IN THE MACHINE ,, OR WIERD NOISE ??????????
Nov 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
