Question about Delta Home
I installed the stem units for a three handled shower/faucet for my bathtub. While the hot water flows correctly, the cold just dribbles. Does it have anything to do with how the stems are oriented? I have no instructions for the system was installed before I moved in...I have no previous experience with this...please help!
  • Cornelius Badie Nov 12, 2010
    I'm sorry, but this is not even close to the type of faucet I just replace...there was no leak, I just had to replace the extenders attached to the stems that held the handles (Delta Model# RP18627). When I replaced the assemblies, that is when the problem started. There is no installation data on the website, so I am at a loss...This stuff was never cover in carpentry class...lol...Unfortunately, the system has been discontinued. I'm beginning to think they don't even make 2 handle systems where the faucet are installed in the wall...by the way, the stem model number is RP1740.
  • Cornelius Badie Nov 17, 2010
    That was it...I stuffed a rubberized rag into the pipe so I could run water in the house while I found the replacement parts. A piece of it became lodged in the line leading to the spout...Thanks...
  • 8,197 Answers
Welcome to fixya!
I see that you just replaced the stims of the faucet for the tub. There is another part that you need to also change it is caled the faucet seat. It is located it the valve body. You will need to get a seat wrench like on this linkbelow. You can get it at any hardware store.
http://www.google.com/products/catalog?q=seat+wrench&hl=en&prmd=ivs&resnum=1&wrapid=tlif12893669085721&um=1&ie=UTF-8&cid=15000375337516058701&ei=Vy7aTNuCEZH0tgPPj4W3Bw&sa=X&oi=product_catalog_result&ct=result&resnum=2&ved=0CGkQ8wIwAQ#
The reason why you need to change the seat is because the seats get a chip in them and that is where you are gitting the leak from. Here is what the set looks like out of the valve. You can also get them at any hardware store. Make sure that you take the seat with you to the store sence there is about 20 diffrent ones out.
http://www.google.com/products/catalog?hl=en&q=faucet+seat&um=1&ie=UTF-8&cid=5992378774709349018&ei=8S7aTLKDDIy8sAOvtNHMBw&sa=X&oi=product_catalog_result&ct=result&resnum=4&ved=0CH0Q8wIwAw#
Here is how you replace the seat on this link below. fig 3
http://www.doityourself.com/stry/leakywasherfaucet
Good Luck
Posted on Nov 10, 2010
  • Jyackle5
    Jyackle5 Nov 12, 2010
    If you have replaced the stem and you did not flush out the line before you put the stem back in you might have some debris that is blocking the flow. I have seen this in my 18 years of plumbing repairs.
    Good Luck
We have no hot water coming out of our bathtub faucet. We took it all apart and water is only coming our of the cold side of the pipe
there is probably a shutoff on the rough-in valve in the wall. Sometimes the seal in that comes apart and blocks the water. Get new stem for valve. Unscrew the nut, replace stem, tighten nut. Clean inside valve before u put new one in.
Oct 10, 2015 | Delta & Single Handle Shower Faucet
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
We recently installed a Moen single handle faucet in a refinished shower after having a plumber replumb the front of our house. Handle appears to be properly installed. Now there is no hot water or even...
u need to adjust the scald protector all single handle units are shipped in cold position for safety reasons if have paper work for handle it explains how to adjust if not unscrew handle and remove on handle / valve stem will see a red and a blue plastic clips pull back clips and turn slightly and push back do this till desired hot and cold setting are to your liking replace handle and your done
Dec 17, 2010 | Moen & One Handle Tub & Shower Faucet
No hot water
need to adjust anti-scold when unit shipped is set for cold if u have install paperwork that has info on how to adjust if not remove handle and on valve stem will see blue and red plastic clips slid them forward and adjust till hot water is adjusted to liking
Jul 25, 2010 | Moen & One Handle Tub & Shower Faucet
We installed two new single handle shower faucets with both hot and cold supply lines pressurized to each of the faucets. The problem is that no hot water will come out of either faucets. Their seems to be...
Sounds like the valve is defective. The supply to the stems was not bored out at the factory giving you a valve that is essentially pretty on the outside and solid on the inside. To test it, uninstall the valve. Remove the stems. Then try running a pipe cleaner though the valve from the supply side and see if it stops before the stem.
Aug 15, 2009 | Moen & One Handle Tub & Shower Faucet
Moen Kingsley roman tub- no/slow hot water flow
sounds like you may have a little debri on hot side stem or kinked hose between valve and spout turn off water to house remove handle pull bonnet and remove stem turn water back on with stem removed see how water flow is be careful turning water on you could make a mess i am assuming the low pressure is in shower only
Apr 13, 2009 | Danze D302521 Antioch Roman Tub Faucet...
Low flow hot water in Delta Shower
If your water heater is old or has been recently replaced, it will slough off debris that will get caught in the hot water supply side of the faucet. You have to disassimble the faucet and use a dental pic to remove the debris from it. This is a real common occurance. You can also try to flush out that side by removing the parts and then slowly turning on the water without the parts inside. Be careful not to flood your bathroom when you do this. But usually you have to dig it out. I have spent as high as 3 hours digging the liner from the dip tube of a water heater out of a faucet.
Apr 05, 2009 | Delta & Single Handle Shower Faucet
Only hot water, no cold water.
The cartridges in the single handle units are prone to display this issue in hard water areas as mineral deposits such as calcium build up on the stem. The stems also have small rubber band like rings - for lack of a better term- that break apart and can clog the ports on the side where the are on. New stem should resolve the issue totally unless you have had a pipe break or other construction to the plumbing system recently. Thanks for using Fix Ya.
Mar 01, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Home Logo
222 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
