Question about Sanyo DS32830H 32" TV
Won't stay on
The tv had been stored in the bedroom for about one year. Decided to use it and it turned on fine for about 15 minutes. Then it made a loud motorboating noise and shut off. It would not turn on again despite repeated attempts for about 5 minutes. When I tried to turn it on after that time it made the fluttering or motorboating sound and shut off before a picture came up. This happened several times and I quit doing it. Inspection of the boards revealed no obvious problems (cold joints or burns). My thought is a capacitor and/or voltage regulator breaking down. Any suggestions on where to look?
Thanks
Eric
  • zathoraus Jan 12, 2009
    I have a Sanyo 32" DS32830H MFG. May 3 2003. I need to find out what the part number is for the "Item" on Power board: 4B10B09400 in soldier slots: T402H1-11 and T402H13. When I power up the TV that "Item" makes a high pitched noise and then powers off. I probally need to replace it. so I need to find out where to get one and what it is.
Sanyo tech service helped.
Posted on Jun 21, 2008
Toshiba 32A42/32A42A. Just moved tv to bedroom, worked great for 2 days, now the picture has vertical lines. Turned it off for 15 minutes, picture came on, 10 minutes later lines appear again. Anyway to...
It sounds that there is any loose solder terminals at the main board, especially with the vertical scan output section circuit. It will be best to contact any service technician to get it repaired. Gopakumar Gopalan Google
Mar 09, 2014 | Toshiba 32A42 32" TV
Tv stays on for 15-20 minutes and then picture blacks out, Can't turn back on. Unplug and plaug in again but still only last 15 - 20 minutes. new lamp, no difference.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jun 05, 2017 | Hitachi 62VS69 62" HDTV
Philips 32" tv won't stay on
Quite possibly one of the heat sinks has come loose or a power supply cooling fan has failed.
Have you tried blowing it out using canned air?
Nov 01, 2017 | Philips 32PFL3504D 32 in. LCD TV
N64 No Picture on Vizio TV
Well it sounds like a coincidence then. Or if it's working on one tv and not another tv then you need to try a new av cable to see if it makes a difference.
Oct 13, 2012 | Nintendo 64 Console
Samsung TV DLP
Disconnect everything from the TV so no more wires are attached to it like cable or DVD or gaming console. Unplug the TV from the wall for over 2 minutes. Then plug only the TV back into the wall with nothing plugged into it, if the TV does not stay on then you have a defective TV. You might try moving the TV to a different part of the house to a plug on a different circuit/breaker like a bedroom to verify this.
Jan 22, 2012 | Audio Players & Recorders
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
XL-2100U lamp cycles on and off
Hi
I recently had a similar problem after replacing my lamp the set would work for 22 mins then go into standby for 30 sec then come back on, then repeats, I decided to experiment with the lamp housing, I removed the new lamp, unscrewed the top of the lamp that holds the actual bulb then switched out the main housing (bottom part) with the original housing, that seemingly has corrected my problem, you may want to try if the replacement lamp did not come from Sony...good luck
Sep 10, 2008 | Sony LAMP BLOCK XL2100U Projector Lamp
Powers off after 15 seconds to 1 minute
solder issue at the flyback. try resoldering the flyback
May 17, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Problem with tv turning off by itself.
I had a friend with the same problem. He had to clean the components and fans in the set. The accumulated dust had caused the set to run hot and a safety switch was the tv off. He purchased a few cans of compressed air and, as he blew the components and fans out, used a vacuum to capture the blown dust. Good luck.
Dec 27, 2007 | Samsung HL-S4266W 42" HDTV
Remote
this is from your producer: Product Description ? BASIC OPERATION OK ? everyone knows what a handheld remote control unit does for your home electronics. You can control your basic four (4) components: TV, DVD player, VHS player, Cable or Satellite tuner. Setup is simple for these basic 4? put in the batteries, look up the manufacturer of your component (Mitsubishi TV) and note the possible 3-digit ?program codes?? turn on the component, press the remote control?s PROGRAM button until the light stays red, press the component button (i.e., TV), enter in the ?program code?, and press the ?power off button? ? if the component (i.e., TV) turns off: you are programmed! If the component (i.e., TV) doesn?t turn off, then repeat the sequence using another of the manufacturer?s program codes until it does. Easy ? took me about 3 minutes to program my old Zenith TV (in the bedroom), my SONY DVD player, and my Mitsubishi S-VHS player. No problems at all. HOWEVER, in case you do run into a component for which the ?program codes? don?t work? you can go through a sequence to self-identify the coding. While I won?t go into it here, it is only slightly more time consuming than the other method. As my codes worked fine, I can not address this aspect, so I won?t make a claim we didn?t test.
Jun 06, 2007 | GE HO97685 Remote Control
Sanyo DS32830H 32" TV Logo
150 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
