Question about Dometic Rooftop RV Air Conditioner
Neither fan or compressor will com on
Checked fuse on circuit board it was blown, replaced it and the breaker tripped and blew the new fuse on the circuit board. Trailer was not moved worked fine the week before. Also tried the furnace and it will not work either.
  • sweating17 Jun 24, 2008
    Thank you for your help with my air conditioner I very much appreciate it. I am going to buy a new unit.
  • 828 Answers
You have a short circuit in the system at some point. A blown fuse on the circuit board indicates a short in the control circuit. Tripping of the breaker indicated a high voltage draw from the compressor. Check the compressor motor terminals with the wires removed and the power off. Use an Ohm meter from a terminal to ground. You should have no reading. If you have any reading the compressor motor is shorted out and the compressor is done.
Posted on Jun 20, 2008
York affinity 9.s series, year 2008. I have not used my furnace since last winter (approximately 7 months ago). I went to start it up this year for the first time and it will not start. Upon inspecting...
Fuses will blow if there is an overload.
Breakers only trip if there is a short to ground.
Since you replaced the fuse and it blew and tripped the breaker , I would check for a wire problem. Also check the elements that rodents haven't built nests ect...
Nov 12, 2014 | Heating & Cooling
Tip
Fuse blown or breaker tripped
Due to short circuit or burnt wiring in air conditioning. It may happens due to high voltage or undersized wiring. When fan motor or compressor grounded, then it will trip the breaker or blow the fuse.Fuse wires should be 3 times amps of actual running amps.Breaker should be same. If your a/c model current is 8.3 amps, breaker/fuse should be 25 amps.
on Jan 10, 2011 | Heating & Cooling
Tempstar Air Conditioner wont come on
Sounds like you need a new contactor in the condenser. The low voltage is grounded. Remove the low voltage (likely 2 wires) at the condenser and wire nut the wires leading inside. With an insulated screwdriver manually push in the contactor and be sure both compressor and fan run. Then replace fuse and turn power on to air handler with a call for cooling. Obviously the outdoor unit won't run because you unhooked the low voltage but if fuse doesn't trip then it's likely the contactor. Good Luck
Apr 10, 2017 | Heating & Cooling
My jmc7000 jenn-air blew a circuit breaker. No power to the unit. There is power to the recepticle. I'm wondering if it blew a circuit breaker, does that mean the problem is most likely a big problem...
Yau say a few conflicting things. First you wonder if it blew a breaker, and then say you have power to the receptacle. If you have poer to your receptacle your breaker if not tripped. There are NO breakers Inside of the Microwave. Only 1 time fuses. So, if your init is dead it has probably blown a fuse inside of the unit. If that is the case. Probably shorted HIgh volt capacitor would be my first guess. If it is jsut dead. it can be other things than just a blown fuse. bad thermal protectors, bad low voltage transformer on main circuit board. Burnt wires. Anything that will cause it to lose power inside the unit. From bad parts to bad connections.
Aug 16, 2017 | Jenn-Air JMC7000 Microwave Oven
Wine cooler not working - checked all fuses and found the fuse on the circuit board had blown.Changed that fuse- reconnected and the fuse blew straight away what do I do next?
If the fuse blew immediately..then there is a hard short somewhere in the circuit...if you have an ohmmeter you will need to check the compressor, fan , and whatever type of controller for a short circuit
May 09, 2011 | Refrigerators
I have a Amana PTAC model PTC123A50AC never had any problems until this a.m. walked into office were installed no heat. Breaker tripped, reset breaker, nothing. Checked outlet, getting power. Any idea's?
To all friends! Whenever you find breaker tripped or fuse blown, it's an indication some device/s are in problem.
To get tripped breaker:
1. Condenser too dusty- clean it.2. Fan motor or compressor grounded-Replace. 3. Compressor high amps due to capacitor weak-replace capacitor. 4. Burnt wire-rectify. 5.Short circuit-rectify.
Jan 11, 2011 | Amana Heating & Cooling
I have a Samsung Ductless Air Conditioner. It wil...
i think there is a short circuit in the fan or compressor even in the board.loop check it & say how many amper is there?
May 21, 2010 | Samsung AS18A6RB Air Conditioner
Fuse blows. Drawing too much current ?cause.
Wow, I've never heard of a microwave having a circuit breaker on the main board.
I would suggest that you test the capacitor and the high voltage transformer.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
Nov 09, 2008 | Microwave Ovens
13500 unit will not come on year 2000
Assuming you have central air (controlled by a wall thermostat), chances are the control unit in the A/C was hit by the thunderstorm. These are fairly common to be ruined by power fluctuations and bad weather as is the control unit in the refrigerator. The controls unit "runs" both the cooling and heating. If you ever notice right before your furnace turns on, there is a clicking noise in the A/C. Thats the control unit. It tells what "system" to turn on They are not cheap. They are about $150-200. The best thing you can do is unplug your unit when not in use. I have replaced TONS of control boards, etc. because people leave their unit plugged in and they have been hit by bad weather. Good luck and happy camping.
Jun 18, 2008 | Dometic Rooftop RV Air Conditioner
Bulbs and bottom pcb blew, replaced but still not working
the start and run capacitors of the compressor can go short circuit and cause a big spike that can blow the bulbs, trip fuse etc. Inspect the capacitors for splits etc, you may well find that the start cap has blown and so there will not be enough current to get the compressor running.
Mar 18, 2008 | Zanussi ZX99 / 5 Bottom Freezer...
Dometic Rooftop RV Air Conditioner Logo
165 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
