Question about Garden
Need a manual for Ramset Dyna drill 321 (Hammer) Have a Ramset Bit stuck in the chuck. Chuck seems to be enclosed unsure how to remove or open chuck to remove bit. Drill bit is Ramset.
    Problem Solver:
  • 8 Answers
Take flat head screw driver put flat head driver in to gears on chuck hit screw driver with hammer counter clock wise
Posted on Nov 10, 2010
What type of drill bits ( masonary) does your Ramset dyna 321 hammer drill take
Posted on Oct 14, 2017
Bought a Bosch Drill. Chuck packed up after five months. Mega Mica Eastgate say chuck not covered?? Bought 2015/12/19 08:57:22 for R2999.00
not much can be done if the dealer will not warrant the chuck
if the bosch name appears on the chuck, call bosch direct and make a complaint but if it doesn't then get a new and better quality chuck and replace the chuck on the drill
remember that ordinary key operated 3 jaw chucks are not designed to used in a hammer operation continuously as that damages the screw mechanism of the chuck especially if the drill bit is over 5/16 drill size
if that is your operation, invest in a special masonry drill such as ramset or hilti or other makes of that sort
May 30, 2016 | Bosch Drills
Drillbit stuck
Can not see what model you have. Is it a keyless chuck or an SDS chuck? With a keyless chuck hold the machine in a vice by the drill bit. now tap the chuck with a hammer or pin punch & hammer. DONOT hit the chuck on the jaws gut on the rim around them. I have had success using this method. If it is an SDS type chuck pull the chuck cap up as far as possible along the bit them if there are any ring springs you will have to try remove them then slide the sleeve up the bit, now you should be able to remove any steel balls. If the bit does not come out now hold bit in vice as before and tap on tool holder.
Mar 02, 2014 | Bosch Drills
I have a DeWalt DW505 hammer drill. I was drilling into concrete and my bit came out. After several attempts to drill again, I noticed the drill chuck was not holding the bit. I opened the chuck all the...
Hi Ken, sadly it sounds like the chuck is past its best. The cogs inside the chuck have most probably worn. If you can get the chuck off try clamping it in a vice and use some pump pliers to undo it. Failing that you will need a new chuck which you may be able to get at a good diy store.
Sep 14, 2013 | Dewalt DW505 Electric hammer drills
I've just bought my b&d cordless 14v hammer drill but the instructions were just a few pictures. one of them was of an allum key in the chuck and hammer striking it but i dont want to damage the drill....
Hi. Try the drill at slow speed without any drill bit in the chuck. Look closely to see if the chuck wobbles off centre whilst holding the drill firmly. If it does then there is a good chance that the chuck is loose from the body. If it seems ok then next close the chuck (tighten it closed) to see if all the 3 jaws are lining up ok and open it again to see if the jaws retract back down the chuck smoothly. (jaws are the small parts inside the chuck that grip the drill bit) If the chuck it seems loose then you can use a long allan key to tighten it up which is inside the chuck. If the jaws do not operate properly then i would suggest taking the drill back to b&q for them to fix, or replace the tool as it should still be under warranty. Good luck
Jan 22, 2011 | Black & Decker Drills
A bit is stuck in the chuck of my Bosch drill
Hello. Wrap a towel around the chuck and use a pipe wrench or a pair of channel locks to put a little force on the chuck. J.
Jul 19, 2010 | Bosch Drills
I have a Black & Decker 18V cordless drill with keyless chuck. The spot where the drill bit fits is in the open position stuck and won't turn in either position. What am I missing how to unlock it?
Look at the three jaws in the chuck,if on is further out than the others the you need to tap ti back into place with a small punch and a hammer.If this does not work then you need to replace the chuck,remove the screw at the bottom of the chuck[where you put the bit],then you will need to to clamp vise grip on the chuck and with it pointed away from you hit the vise grips with a hammer with a sharp blow downward and it should come off.Hope this helps.
Jun 12, 2010 | Black & Decker CD9602SB 9.6 Volt Cordless...
Bit tighten stuck open
If you mean the chuck jaws seem stuck open, spray around them with some penetrating oil or spray like WD-40, RP-7 or similar and let sit for a couple hours... Then you can tap around the chuck body with a light hammer or spanner etc... just lightly tap... Then if the chuck has an arbor lock to prevcent it from spinning, be sure that is engaged then try to release the chuck jaws. Sounds like they are stuck open through tight friction or rusting on the inside edges (that you dont see). Be careful not to leave them in the fully open position when stored as this is exactly what can happen!
Mar 31, 2010 | Makita 6304LR 1/2" Chuck Electric Drills
Jaws of my Hitachi 18V cordless drill are locked shut
Other than two quick squirts of WD40 and nice new chuck key?
Apr 07, 2009 | Hitachi 18V Lithium Ion Cordless Hammer...
Matika hammer drill - bit stuck
The spade bit sold with the hammer drill was actually too large for the hammer drill. We found that the spade bit had over heated (not from overuse or heavy use as only two ladies were using the hammer drill) but because the bit was too large it put too much weight on the drill. The bit had to be removed from the chuck using a hammer and force causing a bearing to come out and the chuck now needs repair. Solution repair the chuck on the hammer drill and buy a lighter spade bit. Then continue jackhammering the cement out of the shower cubicle.
Mar 25, 2009 | Makita Drills
Chuck will not release bit
the Chuck should be 2 Part.
Use 2 pair of stillsons Or pipe wrenches, Tight On the 2 Chuck Parts, Crack in opposite Directions.
Alternative, Use Wrench On Chuck Jaw, Short sharp Blow With Hammer.
Mike @ compurepair.
Feb 28, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Garden Logo
844 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
