Question about Kenmore HE2 Plus Front Load Washer
My washer will spin but it won't spin fast, even though it is on the high spin. What could be wrong?
    Problem Solver:
  • 8 Answers
Change belt or tentionroller some are adjustble
Posted on Nov 10, 2010
Diagnostics ok but only spins slow
Water pump screen is plugged. Will not drain properly even though it goes into high spin.
Mar 14, 2014 | Kenmore HE3T Washer
My front load washer won't spin fast anymore, any solutions out there?
A leading cause of clothing coming out very wet(not spinning on high speed) is over sudding (too much detergent being used) to see if that is the case start the washer without clothes and see if there is build up of suds (there should be NONE) to clean over sudding run a cold water wash and add a cup of white vinagar that will clean the build up of suds
Jul 18, 2011 | Washing Machines
Good evening, My Roper washer RAX4232PQ0 will not spin...it seems to drain OK but won't spin...can you offer any help? Thanks!
I am thinking if all works good except won't spin, it is your lid switch. Under your washer lid you will notice a peg of some sort that when lidnis closed goes into a slot/hole and that triggers the spin cycle. That is in lamens terms know as a safety idiot switch. It is designed so when the washer is spinning at those high speeds,na child or not to smart adult does not open lid and put hand in while spinning. SO, if switch goes out, of course it won't spin. Switch is cheap , under 20 bucks at any appliance parts store, and they even can tell you at store how to putnin yourself by showing on one of there washers on display. Let me know if I nailed it!! Thanks Mike
Jun 09, 2011 | Roper RAX4233PQ Top Load Washer
Washer is not spinning fast - so the clothes are more wet when done
sounds like washer is load sensing either overloaded or unbalanced when it decides to low spin insteasd of high spin dose it stop for second rotate 3 times and change direction 3 times the just spin slow.... if so either u have misloaded the machine by overloading orthe clothes are unbalanced in load may need add a towel or something to balance the weight evenly in the tub
Jan 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Washer Tub banging on fast spin
there are some springs that help hold the tub even as it spins also make sure that the washer is level check front to back side to side and corner to corner if it is unlevel they will be out of balance in high speed spin
May 07, 2009 | Kenmore 23822 Top Load Washer
The machine goes crazy when it's on the extended spin (fast spin). If I set it to "gentle spin, would it disengage the fast spin? Whirlpool didn't know the answer!
Even with a good level machine these are very heavy units containing 3 concrete weights. The floor is a direct contributor to vibration and yes it;s worse on the Ex spin with a higher spin speed. If it's on a wood floor even in a new home that can cause this issue. One way to make sure the machine is ok is to put it on a concrete floor, level it and hit the high speed spin with a wet load. Not a easy thing to do but one way to confirm it.
Even a normal spin is enough spin speed to extract enough water. Stick with that!
May 05, 2009 | Whirlpool WFC7500VW Washer
Washer started smoking
You might have overloaded the machine and the belt will smoke;the machine will still work,the items still might be wet due to the fact the machine couldn't spin fast enough.
May 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore HE2 Plus Front Load Washer Logo
60 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
