Question about GE Dishwashers
I have a G E dishwasher modle# gsd2000jo1ww Serial# lh793556b I cant get it to work everything hooked up but will not turn on.
    Problem Solver:
  • 10 Answers
Make sure the circuit breaker for the dishwasher is on in your house. Next, open the door and look around for the latch at the top. This presses a switch that tells the dishwasher it is closed, allowing it to start. If the latch is bent or the switch is broken the dishwasher will not work. Also you can take apart the panel at the bottom and check to make sure the wires are properly connected (always disconnect power at the breaker and if you dont know what you are doing do not mess around with electricity).
Posted on Nov 10, 2010
Kenmore elite clean lite is flashing won't shut off.unit won't work modle #66516912001 serial#fk4402228.it flashes 7 times over and over.i shut off all power turn back on still flashes .i replaced...
that's a sensor issue...something is truly unhappy..kenmore is the least likely to have a service manual online. maybe if you call Sears service, they'll at least give you a hint as to what's up with that..
Mar 15, 2008 | Dishwashers
Bosch logixx multi programable
On the inside of the door, on the right hand side on mine. They can be hard to get to if you have your dishwasher mounted in a corner setup.
May 22, 2014 | Bosch Dishwashers
Dishwasher will not start.. heat dry with lock icon is lit up and cant cancel
Hold the heat dry/ lock button down for atleast 10 seconds. That should turn the option off. If that does not work then turn the breaker off for atleast 10 minutes then turn the breaker back on,. this will reset the dishwasher placing everything back to the original settings.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 17, 2012 | Frigidaire FDB520RH Builtin Dishwasher
My modle number is aruf 036-00a-1 my serial number
MY MODLE NUMER IS CPLE42-1 SERIAL NUMBER IS 010940037
Aug 04, 2010 | Goodman CKL36AR36 Air Conditioner
Dishwasher is 4 months old and leaking during washing and rinse cycle.
Call a repiar shop.. Give them the modle & serial. They can find out if its in warrenty aany might be able to fix it for at no cost to you.
Jul 08, 2009 | Dishwashers
Won't stop cleaning to go to dry
I have not worked with this Kenmore model, but:
It would be good to check the heating element to make sure it has not failed. Some dishwashers will wait forever for the water to come up to temp before it goes to the next cycle.
If the heating element checks out:
-IF it has a knob/dial that you turn to start the dishwasher on any cycle, that timer/controller has most likely failed.
-If your dishwasher does NOT have a dial as described above, then the main controller card (PCB) has most likely failed.
May 05, 2009 | Kenmore 16072 - Multiple Color Built-in...
Phillips magnavox
Could be an open internal fuse or power supply failure
Mar 18, 2017 | Philips Televison & Video
LG DISHWASHER WORKS BUT VERY NOISY MODLE:LD-2040WH
The main water pump on this model does not last long. The water seal between pump and motor starts to leak that result in the adjacent motor bearing corroding and eventually failing, resulting in excessive noise. Later the water leak becomes so bad that it triggers the "E I" water leakage display and prevents it from completing the program. The pump and motor is sold as one unit and the whole unit must be replaced. I have tried to replace the faulty bearing and repacked the rubber seal with silicon grease but with no success. If anyone have repaired the water seal successfully please let us know.
Jun 15, 2008 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
180 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
