Question about Royal Office Equipment & Supplies
I have a Royal orca 9512X and the plastic part situated under the shredder which when pushed by the waste basket depresses the plunger that places the shredder on active mode broke off, it is replaceable by removing two screws. Where can I buy this part?
    Genius:
  • 1,218 Answers
For replacement parts contact Royal at 1-800-524-0799.
Posted on Nov 10, 2010
  • Anonymous Nov 10, 2010
    For parts contact Royal at 1-800-524-0799.
What kind of oil is used on the royal orca 9512x?
The shredder does not use oil. The noise probably relates to something jammed in the shredding mechanism or one or more damaged shredding elements.
Mar 01, 2015 | Royal Office Equipment & Supplies
I have a Royal Orca 9512x paper shredder. When I use it , it makes a very loud ,metallic squeeking sound. How can I correct this? It shreds fine. It's just noisey.
To fix this get some dry Graphite spray lube....
Spray graphite
Spray this on the cutters and sides of the cutters to lube the cutters and bearings....this will stop the noise...and prolong the life of the machine...
heatman101
Jun 18, 2011 | Royal 15MX Shredder
I have an older royal orca 9512x shredder that I purchased at staples....recently it wouldn't work...I found out that the plastic switch that triggers the shredder fell off ...a small projection of...
screw a small screw into the piece in the back right corner of the basket that the shredder fits on. This will adjust to the height needed to make the shredder run.
Jun 17, 2011 | Royal 15MX Shredder
Royal Orca 9512x shredder will not run. I have checked the fuse and it is good. Cleared a paper jam and still wont run forward or reverse.
If motor wont run at all then probably the pcb is blown...call Royal at 1-800-524-0799 for parts and prices.
Sep 15, 2009 | Royal 15MX Shredder
Royal Orca 9512x was moved to another room and now it won't turn on. A square piece of plastic fell into the basket. But we can't tell where it came from. Not sure if that's related or not.
Make sure that switch on back right foot is setting down on paper bin. It makes the contact that turns all on. I also had to use swithc cleaner from Radio Shack to clean my main swithc on top control panel.
Jul 12, 2009 | Royal 15MX Shredder
Wiring toggle switch royal 9512x
Did you get wiring diagram for Orca 9512X shereder swithc.
Wiring is as follows.
Looking down on switch from the back with the forward facing the feed. and control on top
Top left has two yellow wires one to bottom right of switch other to control box/board
Top right has orange going into control box/board
middle left has black going to motor
middle right has red going to motor
bottom left has smaller red going to control box/boafd
bottom right has yellow from top left.
Hope this helps. I'm still trying to find a manual for mine.
Jun 10, 2008 | Office Equipment & Supplies
Royal orca wont forward will reverse shredd.
May have paper bits jammed above fixed curved metal surface that spiral cutter slices against.  Need to spend time removing built up material with stiff wire or flat tool.
May 04, 2008 | Office Equipment & Supplies
629 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
