Question about Philips DVDR3435V/37 DVD Recorder/VCR
My dvdr3435v shuts itself off within seconds of power on. Any ideas?
LG 42CS560-UE LCD TV turns off by itself Power Supply is New
You must accidentally setup the auto sleep function within 3 seconds interval. Go to the setup page to re-configure no auto sleep interval.
Jul 22, 2014 | LG Televison & Video
When I turn my projector on within seconds it turns itself off
Are the fans all starting up? The symptom you describe is often associated with a faulty fan. Also could be a failed lamp, as the projector will shut down if the lamp does not strike within a defined time, although in this case the 'lamp' light should come on
Mar 31, 2014 | Sony VPL-CS7 Multimedia Projector
The VCR shuts off after just a few seconds of playing or rewinding or fast forwarding. The tape goes in, and when you push play (or any direction), the unit will try and play it and then it will shut the...
There is a part that is called an idler wheel assembly that is critical for play, rewind, and fast forward, and may have stopped working. The second possibility is that the drive belt that runs the idler assembly has broken or come off.
Jan 01, 2011 | Philips DVDR3435V/37 DVD Recorder/VCR
1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Dec 21, 2009 | Panasonic AG-1980 S-VHS VCR
Tv shuts off immediately
check first for the contact point of your control panel button maybe the tact switch is shoted specially when your always using remote control for function operation.second check power supply for leak capacitor or change in value,check also the photo coupler for leak test or change in actual.
Aug 01, 2009 | Mitsubishi VS-5043 50" Rear Projection...
Kenmore Elite QuietPak 2 powers up and shuts off within seconds
I need the serial #, to better assist you
Thank you
May 12, 2009 | Kenmore Dryers
Philips DVP 3150V
saida horizontal com deficiencia faz com que a fonte aciona circuito de proteção.
Feb 09, 2008 | Philips CCB092AT 9 in. TV/VCR Combo
PUSH POWER AND SHUTS OFF WITHIN SECONDS AUTOMATICALLY
just had this tv fixed for this exact problem-it cost 577 bucks to fix- some sort of control panel that had corroded
Jul 05, 2007 | Mitsubishi WT-46807 46" Rear Projection...
Open Questions:
Philips DVDR3435V/37 DVD Recorder/VCR Logo
61 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
