Question about GPS
Where is the fuse box in a millard caravan 84-85 limited thanks melissa
2 Suggested Answers
MrScary66613
  • 1990 Answers
SOURCE: fuse panel
The easiest Way to find this Fuse is to Get a Flashlight and Hold it Behind or Under the Fuses in the Panel to see if they are Blown. It is there.
Posted on Jan 22, 2009
How do I put away the double bed in my 1989 Millard pop top caravan as it was down when purchased
Hello, Kay -
If you are in Australia and have not yet contacted the caravan manufacturer, Millard, this it the link to the Contact Us web page for Millard Caravans:
http://www.millardrv.com.au/contact.aspx
Added:
Copy and paste this web address for the Milliard Caravan Owners Forum into your browser address box:
http://candm.com.au/forum/viewtopic.php?f=9&t=1601
Most likely another caravan owner can explain the procedure to you.
Note: You will need to register (free) first in order to post on that forum.
Jan 08, 2018 | Cars & Trucks
Where is the horn fuse on a 1999 grand caravan
The horn fuse is in a fairly large black fuse box under the hood on the driver's side. There are two tabs at the rear of the box that you pul towards the front of the van to release, then lift the cover by rotating it up and toward you. On the inside of the cover you will find a "map" of what each fuse controls.
Anytime you have an electrical issue with this vehicle, you should check this box first. For instance, I went and bought new headlights when what I really needed was one of the headlight fuses found in this box.
The fusebox under the dash only has about 10-12 fuses in it, and they are not the ones that will usually blow, so check under the hood before you twist your back out trying to get to the interior fuse block.
One last tip: a pair of needle-nosed pliers or an actual fuse puller is recommended, as finger space is limited around some fuses.
Hope this fixes it!
Cheers!
Jun 20, 2014 | 1999 Dodge Grand Caravan
Need written instruction for melissa and doug deluxe magic kit
Go to the Melissa and Doug website and download the PDF file and print it out also if you wish. The set doesn't come with instructions inside the box... Perhaps they figure that children will go ripping through the box and discard it?!
Best regards
Britgal in PA
Dec 26, 2010 | Melissa And Doug Deluxe Magic Set
1996 dodge caravan 3.3 wont start. it turns over but doesn't spark. What might be wrong with it? Do I need to replace something? Thanks.
take a test light check all your fuses under hood fuse box and inside fuse box, check for blown fuse/fuses
Feb 09, 2010 | 1996 Dodge Caravan
Adr 6/00 wiring diagram
Check with your local dadge deaers parts department. They shouldnt have a problem printing it out for you.
Aug 30, 2009 | 1997 Dodge Caravan
Fuse box diagram 2006 3.3 l caravan
On this website you find fuse box diagram and description for Dodge Caravan (2005 - 2007)
Dodge Caravan 2005 2007 fuse box diagram
Mar 15, 2009 | 2006 Dodge Caravan
Fuse panel
Jan 22, 2009 | 1998 Dodge Caravan
GPS Logo
42 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
