Question about Safari 669416 In the Garden Magnetic Sculpture Pack of 3
Why my 1991 gmc safari shake to much when I'm waiting for the light but no in N or P? Is weard to me cause as soon I shift to D it shakes to bad, Please if you can Help me giving me some Ideas. Thank you.
  • 528 Answers
First I think I would check for any disconnected vacuum lines along the intake ( on top of the motor). The best way I know of is to get a can or 2 of carb cleaner and put the little red hose on the tip. Start the car with the hood open and begin to spray carb cleaner along the lengths of vacuum lines in 1 second bursts, listening for the engine to race and watching carefully where you spray. I would also have a fire extinguisher handy - just in case! If the engine races, look where you just sprayed for a cracked or split line or a line off or a vacuum cap missing. If, after covering all of the lines you still haven't found the problem, then I'd check the spark plugs and spark plug wires for operation and replace if necessary.. If you have a distributor cap, I would inspect the cap and the rotor underneath the cap for wear and build up and replace if old or worn. There are other components that could easily cause your problem but they are more involved to inspect and diagnose. If the problem persists after the above procedures then I may suggest taking it to a shop since you could throw a lot of money at this vehicle and still have the problem.
Good luck!!
Posted on Nov 10, 2010
Why is My Van Shaking while stopped?
Define the issue a bit Further. does check engine light flash while stopped? check the basics is there air restriction and when where plugs last changed?
Sep 17, 2016 | 1999 GMC Safari
Service engine soon light is on showed p0160 replaced an checked for bad wiring to the mas air sensor still rough idle in gear n now want to shake when it shifts into overdrive it shakes
MOST LIKELY A BAD O2 SENSOR...Potential causes of an P0160 code include: Holes in exhaust near post cat o2 sensor Bad Bank 2, position 2, o2 sensor Wiring problem, melted harness, broken connectors, etc. Bad PCM
Apr 16, 2015 | 1996 Chevrolet Suburban
It shakes a lot when I'm stop at a light also it takes awhile to shift gears
Your clutch has probably been worn out as far as the shifting of gears go. Think about replacing it.
Feb 01, 2012 | 1991 Honda Accord
Had the spark plugs and plug wires changed on my 1994 GMC Safari minivan, and now it runs very rough. If I stop, the engine shuts off. Backfires a lot also. The whole van shakes bad going down the road....
If your Safari did not expecience these systoms prior to you changing the plugs and ignition wires, then you may have crossed two or more of these wires when they were repalced.
Feb 20, 2011 | 1994 GMC Safari
2000 gmc safari and the front seems to be left tire is shaking so bad its hard to drive
could be wheel bearing but theese vans are know to have idler arms to wear out and also front shocks so check theese and replace also make sur to get a new alignment
Feb 16, 2011 | 2000 GMC Safari
I have a 91 gmc jimmy 4wd and the vaccum line that goes on top of the engine block under the breather fell off and i cant find it now were and the jimmy shakes like everything is that what it could be and...
If it shakes try replacing the distributor cap, the pin in the center wears down and jumps causing eratic engine shake (get the genuine GM one it seems to be more precise and smoother running engine) also make sure your spark plug wires aren't broken, or breaking.
May 13, 2010 | 1991 GMC S-15 Jimmy
When i stop it shakes on gear
i would have the transmision looked at, sound like a lock up tourque converter or overdrive shift problem.
Nov 29, 2009 | 1995 GMC Suburban
I HAVE A 1991 TOYOTA CAMRY XLE WITH OVER 250K MILES ON IT, AND AT LOW SPEEDS THE TRANSMISSION WILL VIOLENTLY START SHAKING CAUSING MY WHOLE CAR TO SHAKE AS WELL
Holy **** you need a new transmission or check the fluid in it. Cus that shaking means the trans is locking up and doesnt want to move get that checked out soon. Or the mounts could be gone also. But either way thats not safe. Hope that helps
May 02, 2009 | 1991 Toyota Camry
1991 GMC SIERRA Shaking in the drivetrain
crankshaft balacer going bad,can cause the crank to break if left unchecked
Jun 29, 2008 | 1991 GMC Sierra
Safari 669416 In the Garden Magnetic Sculpture Pack of 3 Logo
70 people viewed this question
Top Safari Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Safari Toy Expert? Answer questions, earn points and help others
