Question about Kenmore 31912 Progressive Direct Drive Bagged Upright Vacuum
Dirt sensor in my kenmore progressive upright is now always on "red bars" meaning lots of dirt. because of this the vacuum is working much harder than it needs to. to clean the sensor i took the bag off and wiped out the area where the bag is joined to the vacuum. i even used dry q-tips to try to clean off the sensor. the bag is less than 1/2 full. still red bars. any suggestions to that i can do to fix the sensor light?
  • 7 Answers
SOURCE: Kenmore Progressive 36932 Upright Vacuum
It's located inside the vacuum kind of behind the where the dirt is collected. You can open and clean but this is probably not necessary. You probably vacuum very fine dust that is hard to remove from the system.
Try replacing or cleaning all filters and letting the vaccum run for a few minutes without moving. Agitator off of course.
Posted on Dec 05, 2008
  • 208 Answers
SOURCE: repair chewed vacuum cleaner cord
take to an apliance repair shop or if your inclined repair it yourself by replacing the cord
Posted on Jun 21, 2009
  • 715 Answers
SOURCE: The brush isn't turning on my Kenmore progressive
replace the belt
Posted on Nov 05, 2009
VacuumRepair
  • 438 Answers
SOURCE: roller on upright vacuum is not spinning
Any time that a vacuum's roller brush stops spinning, this means that your belt has either stretched so much that it's fallen off of the motor, or that your belt has broken.
Here's a very helpful video on how you can replace the belt on your Oreck. This will give you step by step instructions on the belt change.
If you need to purchase a new belt, here's a direct link to a 3 pk. of belts that are used on your Oreck XL upright on our website:
http://www.govacuum.com/oreck117.html
I hope that this video repair was helpful to you! Please be sure to rate my repair helpful by clicking the thumbs up icons in the top of this repair page.
Thank you,
Chris J.
GoVacuum
Posted on Apr 07, 2010
  • 20 Answers
SOURCE: 25512/ 25513 Progressive Canister Vacuum: HI, we have a kenmore progressive canister vacuum ...
cord bad at male prongs, or fuse near motor blown.
Posted on May 06, 2010
Where is the "dirt sensor" in the upright
If you look at the rear of the machine you will see where the hose attaches to it's fitting. At the bottom of the hose connector you will see a "bump". This is where the dirt sensor microphone is located. To cure a sensor stuck on red, remove the entire rear panel, and you will see the mike. Push around it's edges with a small screwdriver to firmly seat it, and your sensor should work properly. It may not seem as if you're doing anything, but it usually works.
May 06, 2011 | Hoover U6630-900 WindTunnel Bagless...
Kenmore InteliClean 116.35923502 Two, I believe unrelated, problems. 1) The InteliClean sensor lights stay amber and red even when the machine is in the upright position and the suction line is...
I had the same problem with the amber inteliclean light continually on. I found the problem to be in the plastic housing that connects the suction hose to the back of the upright section. You have to remove three screws and gently pull the hose housing off the vacuum. Inside I found a hairy clump that was caught on the inside of the hose. The optical "dirt sensor" is just inside the fitting on the upright section. When dirt or other stuff blocks the optical path of the sensors, the amber light will illuminate. My vacuum had an uneven cut on the hose which caused a snag point for hair, dirt and debris. Once this was removed, the vacuum worked like new.
Regarding the roller, this unit has an integrated motor in the roller. I would guess that you will need to take it apart, and hopefully only clean it up. If you need bearings, that will likely be expensive.
Dec 24, 2010 | Kenmore Progressive Bagless Upright with...
The red sensor light is stuck on red. I have cleaned the filters. What might be the problem?
a common problem with this unit is that the sensor will clog up with dirt and debris and will give a false reading to you. my best advice is just to ignore the sensor light... mostly because your machine is running and it will not affect the performance of the machine. Next time you have the unit in for a service, let the repair person know and they should be able to clean it for you.
Good luck.
Mark
Nov 09, 2010 | Kenmore 31912 Progressive Direct Drive...
Sensor
There is an optical sensor inside the port where you attach your vacuum bag. Take the bag off and take a clean soft cloth and wipe inside the port to remove dirt from the sensor. Don't wet it! Do this every time you change your bag and you shouldn't have a problem.
Nov 08, 2008 | Kenmore 31912 Progressive Direct Drive...
Kenmore bagless upright Model # 116.35726401
There is actually an internal fuse in the vacuum. You may have blown this. The circuit board connected to the ON/OFF touch pad may be bad too but probably unlikely. There is also an overheat sensor that trips the vacuum off when it gets too hot. This could be bad preventing it from coming on too. All of these solutions, require you to open the vacuum to fix.
Sep 25, 2008 | Kenmore Progressive Bagless Upright with...
Dirt Devil upright vac
It could be a broken handle release, but it also could be the the clamps where the handle asm, and the base hold together came use, this will cause this problem on some Dirt Devils. The top has to come off to check this out.
Jul 13, 2008 | Kenmore Progressive Bagless Upright with...
Jun 21, 2008 | Kenmore Progressive Bagless Upright with...
Kenmore Progressive issue
I started by replacing the bag. No change.
I opened the bag compartment and noticed that the dirt sensor went to clean, but only when the compartment was open.
I cleaned out the foam filer at the bottom of the bag compartment. No change.
I took off the air outflow filter and cleaned it (Should have replaced it, but don't have a spare right now.). No change.
Unscrewed the hos from the back of the vacuum. The dirt sensor again went to clean.
I had isolated the problem to the hose. I hooked the hose back up and the dirt sensor went to dirty again.
The problem was that the hose was dirty on the inside. To clean the hose, I stretched it out little by little and banged it a little to loosed the dirt with the vacuum running. After the hose was cleaned, the dirt sensor had no problems.
May 25, 2008 | Kenmore 31913 Progressive Direct Drive...
Kenmore Progressive Bagless vacuum cleaner
Check down by the brush roll to see if the inlet is clogged. This type of problem usually means there is a clog. But you do have a year's warr. on this, if you can't figure it out, then take it a Sears repair shop.
Jan 15, 2008 | Kenmore Progressive Bagless Upright with...
Getting suction to use attachments
When the vacuum is in the upright position, it should give you suction thru the hose.
Dec 02, 2007 | Kenmore 31913 Progressive Direct Drive...
Kenmore 31912 Progressive Direct Drive Bagged Upright Vacuum Logo
224 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
