My panasonic washing machine model: NAF60GT malaysia Problem: when i try to wash, sudden the all lights on the control panel are blink. I can not off these light on the control panel, so i switch off the plug.Please tell the troubleshooting & how to solve it. Thanks.
I have misplaced my instruction manual. I need instructions for the NA-F60GT
Posted on Sep 18, 2012
SOURCE: The water inlet does not stop during the entire
Its simple..just follow step by step as below:-
  1. Switch off and unconnected both power & water supply.
  2. Lay the unit with the back side facing up.
  3. remove the back & bottom panel
  4. you will see the valve on the bottom tub.
  5. Unscrew the valve cap.
  6. Dismantle the valve by release the connector between steel bracket & hook (white plastic 'T' shape) using small 'playar'
  7. Then you will see a 20 cents coin ( keep into your tabung gajah)
  8. Use the old toothbrush to clean the black rubber valve.
  9. Assemble everything.
  10. Thats all.
Posted on Jun 25, 2010
  • 410 Answers
SOURCE: wash cycle pause, flashing panel
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer or dryer ID doesn't
mean much to me. I came to fixya looking for a
schematic for an really old AM/FM radio and
discovered that more than 4,700 people were asking
for help with a washer repair. I recently had a washer
repair of my own and found an excellent video which
showed me how to take my machine apart. This
video made it possible for me to do my own repair. I
was so impressed with the video that when I saw all
these people needing help, I wanted to tell them
about it. If you have a top loader (washer) of the
direct drive type, this video might be a Godsend for
you. If you look at the back of your washer and the
panel is solid (no small inspection plate to remove)
chances are you have a direct drive and this video
is just what you need. You can see this video at
www.acmehowto.com You will probably need
more help in determining what the problem is and
how to fix it. If your repair problem is a washer or
dryer I suggest you go to www.applianceaid.com
where they have very good trouble shooting and
repair information on most washers and dryers.
I think you'll find what you need there. Don't worry
about the timer, they hardly ever go bad. Good
luck with it. If I have helped you, please rate my
advice on fixya.
Posted on Nov 29, 2009
  • 177 Answers
SOURCE: 2 problems with speed queen washing machine
The motor is not starting this is the humming noise not a good sound, try it in spin to see if the motor runs in this direction. You may have a motor issue because of the water leaking on the motor?
Now that you have the front panel removed you can look for leaks, you will need a flash lite, start a cycle on the small setting and look for where the water is coming from. If it is coming from the center of the tub above an aluminum case which is the transmission you need a tub seal, if the water is coming from somewhere else it could be a pump, or hose, or ?
Posted on Jul 16, 2008
SOURCE: my washing machine and dryer is not working. Where
check the required voltage i think your voltage is different than usa it could be as simple a switch i would look on the back of the machine to see what voltage it operates on and call an electrolux dealer
Posted on Apr 12, 2010
  • 6277 Answers
SOURCE: wash & spin blinking with
Because you have not told us the make and model I am having to guess what might be wrong and it could be one of many things ;-0(
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 31, 2011
Red indicator light on the cycle dial stuck blinking
Chek that the door lock is activated if not replace the door lock the other possibility is the anti flood device is activated so chek for a leak in the bottom of the machine
Jul 06, 2014 | Whirlpool duet Washing Machines
Hi am using whirlpool 650d washing machine. Today i turned on the machine, it blink a code t5c and suddenly the machine turned off.please say what i have to do!
This is a list of fault codes for whirlpool machines. I don't know if it is complete, but if you scroll down the page you will come to the duet sport washers. Those maybe the codes you'd use. However nowhere in the list is a code that matches yours. Try unplugging the machine, opening the control panel and give all wires and connectors a wiggle. It is also likely that Whirlpool taped the codes to the inside of that panel or on a bottom panel of the machine. If the code doesn't go away give me the full model number. You can usually find it around the inside of the loading door or back of machine at the top. Hope this helps.
Jan 23, 2013 | Washing Machines
We bought electrolux washing machine ewf 85761 in penang malaysia, before we brought on board ship test is done on the store,the washing machine is in good condition..Then we brought the washing machine on...
Just as a wild guess, the control circuit in the washer may not work with 60 Hz shipboard power. The motor probably is not affected. You must be getting awfully tired of hauling that washer back and forth!
Sep 07, 2012 | Washing Machines
All Cycle Lights on with one blinking sometimes working often not working.
1) tight the connector wires very well and clean with spray contact, of course unplugged the machine
2)resolder all point from the board for colder joint
3) Try again.
4) If the problem persist the problem is the board defective.
5) Call some service tech.
God bless you
Jun 19, 2012 | KitchenAid KUDS301V Dishwasher
Blinking lights, unresponsive
I went to the Maytag site looking for a manual. None existed for my model, but I looked up won't start under the FAQs. The advice said to push the cancel button twice. My model doesn't have one, so I just started at the left side of the control panel and pushed each button twice. pushing the dry button twice made the lights stop blinking. i pushed the wash button and the unit started.
May 08, 2009 | Dishwashers
Turn on ok. Press start and spin light blinking and beeping.
Several problems were found
1. the touch panel PCB board had tracks which were damaged by moisture and had it repaired for $50 (Aus); this affected the advance function on the washing machine.
2. Controller motor was replaced with a rebuilt one (since the touch panel kept on shutting down).
3. Make sure that the wire holding the harness reed switch is tight (this I think controls the level in the washing machine).
Apr 13, 2009 | Fisher Washing Machines
Kitchenaid Dishwasher Control Panel lights - some don't light up
control panel light all of a sudden do not come on and my unit wont start model kud101fl
Jan 13, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
The machine doesn't work
Is your load within capacity. See that it is. Press and hold 'spin' & 'dry' for 5 or 6 seconds to unlock controls. Try the machine on a normal cycle once, see if it works.
Apr 14, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Washing Machines Logo
655 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
