Drier of Washing Machine of Model New BPL BS 50 not working.
5 Suggested Answers
Drummernick
  • 440 Answers
SOURCE: renew washing machine front door seal
ye sthey sell those local maytag store ok slips in and round
Posted on Feb 03, 2008
  • 1462 Answers
SOURCE: Diplomat washer drier
all you have to do is:
select half load
set drier timer to required time. set main timer to dry program
i suspect you are not pressing half load button - this is essential
Posted on Jul 20, 2008
  • 1606 Answers
SOURCE: Bosch washing machine WFT 8010
Some dryers have a "fluff" or "no heat" setting that spins the dryer with the heaters turned off. Check to make sure your cat didn't step on this button : ).
The most common failure modes include the main temperature regulating thermostat, overheat thermostat or thermal fuse, and heater elements. If you have a blown thermal fuse, check to make sure you don't have a lint buildup in the vent ductwork, especially right at the blower outlet. I've also seen problems with broken heater wiring and burned-out contacts in the heater control selector switch. The bottom line is that if gets to this point, you'll need to find the wiring diagram hidden inside the control panel, get an ohmmeter or continuity tester and start tracing the heater wiring.
Posted on Nov 18, 2010
  • 6277 Answers
SOURCE: I AM HAVING A LG
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained probably over many years.
Manual
You will need to type into your search engine/web browser '(make model number) washer technical manual' and you may be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct but they often only supply to their registered engineers ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Jul 11, 2011
Electronic board for AGI SS 50 whirlpool washing machine
find the part number for the board and go on ebay to look for a new or used one boards our usually expensive so i would look there first
Nov 20, 2014 | Whirlpool Washing Machines
Awz 412 washing machine/dryer.
With a washer and drier thay do , a separate drier would be better for you
Dec 13, 2017 | Whirlpool Washing Machines
Machine sliding off its base...
yu need to make sure you have alevel and firm base for the machine also the base should be secured to the machine
Apr 12, 2010 | Kenmore Elite 45986 Front Load Washer
Water not hot on hot temperature setting
BS ....on the back inside the washer are two solenoid operated valves that control the hot and cold water flow. your hot valve has ceased to function...and needs replacement.  also make sure your hot water valve is open fully and that the screen inside it isn't clogged.
Mar 29, 2009 | Kenmore 22422 Top Load Washer
Model widl 126s wash/drier. module blown up new module cost minus eprom what is an eprom anyway! is £110 how can they charge nearly half the price of a new machine? price check at comet for later...
i agree - an absolutely crazy situation. however be wary about replacing the module. they can blow up because of a fault on another part like the motor short to earth
Aug 28, 2008 | Indesit Washing Machines
select half load
Jul 20, 2008 | Washing Machines
Drier not working
take top off. you will see drier manifold going across top of machine with stats mounted on it. one or more of these stats is resetteble ie has a little button in the middle. press to reset. some hotpoint have a thermal fuse mounted on the manifold so if present, check this for continuity as well. with top still off, put on dry and check fan working as well.
if you get it going and fault reoccurs, then there is a blockage in the drier duct
Jun 22, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
98 people viewed this question
Top Washing Machines Experts
