Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
The tv powers up comes on but the picture is small and looks as if its really faded out around the edges
  • 134 Answers
Tube is shot you can try to take it to a repair shop but may cost you more that it is worth.
Posted on Nov 10, 2010
  • tnenergy1 Nov 10, 2010
    tube is shot? What exactly is the tube and who's got one for me for the cheap?Write up on service procedure would be cool,diagrams anything helps. THANKS
  • par sims Nov 11, 2010
    Its the main componet of the tv i was sayin that the tube is not goin to be cheap anywhere you go thats why fixing it may be more than its worth? Of course thats my opinion just getting on the net just typing in color tube for your type of tv may turn up something it may be worth a shot.
No Picture but has sound, picture comes up small pixels then fades out
You have a weak power supply,replace the bad electrolytic caps,or replace power supply.
Dec 27, 2010 | LG RM-32LZ50 LCD TV
Tv says fan 2 going out ! Picture is starting to fad away!
If the picture faded away on the order of 10-20 seconds (and if it comes back, also comes up to full brightness in same time frame - possibly with the persuasion of some careful whacking) AND with NO other significant changes such as size, focus, etc., then take a look in the back of the tube for the filament to be lit - the orange glow near the CRT socket. If there is none, then you probably have a bad solder connection on the circuit board on the neck of the CRT. Look for fine cracks around pins on that board. Try prodding it with an insulating stick to see if the picture comes back. Resolder if necessary. Dirty or corroded CRT pins/socket contacts can also do this - remove, inspect, clean, and replace the neck board. It is probably not a bad CRT as the filaments are usually wired in parallel and all would not likely go bad at the same time.
However, if only a single color fades in and out, then a bad connection inside the CRT is a distinct possibility - look for only one of the filament's glow to be coming and going. This is probably not worth fixing.
If the picture faded away with other symptoms, then there is probably a fault in the video amplifier/output one of its power supplies - still probably a loose connection if you are able to get it back by whacking.
Good luck
May 26, 2010 | Televison & Video
Faded and bright
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | Philips 60PP9352 60" Rear Projection...
When initially powered up the picture is normal after a few minutes the picture fades and exhibits curvature along the edges. The picture also no longer fills the screen to the edge. If it gets warm...
Power off after warming up and picture fading problem:
CHECK C2B1 100 UFD 16V OFF PIN 2 IC202 ON THE MAIN PCB.
BTW, on most Hitachi circuit boards there are small green lights in the circuitry that show if a section of the set is working. Also,there are small protection fuses that look like resistors on the board around the power supply transformer. Check to see if any of those are open and it will lead you to the trouble spot. More than likely on that set it is convergence, vertical, Cold solder in horizontal (FBT or H.Drive xfmr.), cold solder at vert. output, regulator i.c., or audio out. Make sure you check the fuses that go to the convergence amps and look for discoloration on resistors surrounding conv. STKs. These are prone to change in value or burn up. Hope you have some luck solving this, Russmann.
Aug 24, 2009 | Hitachi 65SWX20B 65" Rear Projection...
Rear Projection TV -- Bright spot with yellow edges on TV screen
if it is a panasonic pt-50lc14 then you will need a new bulb. you can find them online, do a yahoo or nextag search for the ty-la 1000 bulb and you can find them for around $100...
Mar 11, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Picture has a red "haze"
the color in my tv is a little faded when theres dark scenes on cant really see picture. Red and Blue really fade into picture
Feb 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Arc or hump on bottom left of tv and color is faded bad.
Your convergence Ic's have gone bad. Most likely a few small resistors with them. It's really not a job you should try and takle if you haven't done it before. Not a major deal for a svc co.
Feb 05, 2009 | Philips 60PP9202 60" Rear Projection...
Dark black spots around the edges of LCD TV
this issue is tape from the edge of the panel falling onto the screen.You will have to remove the cabinet and the panel from the bezel(front cabinet).remove the screws from the lcd outer edge. Take of the tape.Be very carfull of the ribbon cable that goes to the lcd controller and to the lcd screen itself. They break easy. If you do , its over. you will need a new panel. to much money and work. best to leave it alone.I have fixed it several times for people with warrentys. It is just anoying but will not hurt your tv.
Aug 28, 2008 | Memorex MLT3221 32 in. LCD TV
32 inch rca color
If this is a 32 inch TV then it is a standard picture tube set. If the colors have suddenly gone out of whack, and the set has not been dropped or had any large magnets near it recently, it means that the degaussing thermistor has come loose from its legs. This is very common in the RCA regular picture tube sets. If you look in the back of the set you will see a large black coil of wire wrapped around the edges of the picture tube, with 2 white wires going down to a jack on the main PC board. Right next to that jack is the degaussing thermistor, which looks like a small silver disc, like a nickle, with 2 legs loosely soldered to its sides. One or both of those legs are probably loose, and if you are very careful you can solder those legs back onto the thermistor. If you do not have experience soldering small parts, allow a qualified tech to handle it for you.
Aug 26, 2007 | RCA HD61LPW175 61" Rear Projection HDTV
TV picture problems
this modle has a bad solder connection near the horizontal o/p transistor that causes the picture to fade in & out.the bad solder connection is on a small coil. the coil winding is typically red. looking at the back of the tv, the flyback has the rid wire going to the top of the tube, the horizontal o/p transistor is to the left & in font of the flyback, it's attached to an aluminum heatsink. directly in font of this heatsink is the coiul you are looking for, it should have a location id of L14XXX or L4XXX if I remember corectly. good luck.
Dec 08, 2006 | RCA F27440 27" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
