Question about Onkyo LS-V955 System
Home Theater ONKYO DR-S2.2 when you turn it on, start reading and turns itself off and flashing light
djhack
SOURCE: Onkyo TX-SV525 on and off
Look under the wide ribbon cable going to the front panel. There is a cluster of components on the main board that make 12V and 6V power for different things. There is a pair of 12 ohm and a 1 ohm resistor. These run very hot and over time will take out the motherboard underneath. If these resistors disconnect the unit will cycle on and off rapidly. I found this out when I was replacing the resistors and repairing the circuit board.
DJ...
Posted on Oct 18, 2007
bluenadas
  • 203 Answers
SOURCE: onkyo home theater
You have a blown amp or you have DC on your amps....
Repair center is your best option....
Posted on Nov 19, 2007
petraman7
  • 1175 Answers
SOURCE: How to set factory codes for remote
Have you tried the Onkyo website yet?
Posted on Mar 18, 2008
SOURCE: Problems with Onkyo DR-S2.2
I am trying to hook me DR-S2.2 receiver up with some existing speakers I found in my new house, but can't seem to get the center speaker to work. What mode does it have to be in so I can see if the center speaker works?
Posted on Jul 16, 2008
jacton2
  • 11 Answers
SOURCE: onkyo DR-S2-2
Have already posted this fix: Most common failure is the audio amp IC, reference # Q5001, which is an STK402-950 (Onkyo Pt. # 222123). Typically fails as a result of excessive volume levels or as a result of problems with the speakers or their wires. If you're technically inclined, the part can be had from various vendors & is fairly straightforward to replace once the complex disassembly required to access the PCB this IC resides on is accomplished, using standard soldering skills. A repair of this type by a reputable servicer may be more effective for non-technical folks, as typically can be accomplished for $200 or less, much less than replacement cost...
Posted on Oct 27, 2009
I have an Onkyo TX-SR501 reciever/home theater amp. The sound works fine in home theater mode, but no sound when FM mode selected, but fine in AM mode. Have checked Antenna.
Hi Anil, please make sure the the receiver is locked into the station. It should read FM Stereo when locked in. Thank you, Onkyo USA
Nov 23, 2016 | Onkyo TX-SR501 Receiver
At Houston Where can I buy Complete Home Theater Packages on Affordable price?
HI, please check out BestBuy for Onkyo home theater systems. Thank you, Onkyo USA
Oct 21, 2016 | Onkyo Audio Players & Recorders
Will only play DVDs in Black and White
Onkyo DV-CP706B 6-Disc DVD Player (Black) - Amazon.com
www.amazon.com/Onkyo...Player-Black/.../B001AMS...
Amazon.com, Inc.Color: BlackChange .... It's quieter than it was before, and it plays ALL DVDs, even if you can see some visible damage ..... THere was no color-just black & white.
Onkyo dvd player no color only black white Questions ...
www.fixya.com > Forum > Tags > dvd player no color only black white
Onkyo dvd player no color only black white related problems. Ask your Onkyo dvd player no color only black white questions. Get free help, advice & support ...
Onkyo dvd player plays black white Questions & Answer
Dec 29, 2015 | Onkyo Dr-s2.2 5.1 Dvd Home Theater...
Onkyo HT-S6500 just shut itself off. Anything else I can do to try and fix it myself?
does it do anything when the power button is pressed? any relay clicks? front panel lights?
Oct 27, 2014 | Onkyo HT-S6500 Home Theater System 5.1...
Fix onkyo ts-sr313 turn on problem
If the relay clicks on and then off straight away then it might have detected an overload condition and so shuts down. Overloads can be caused by faulty speakers or wiring. But if the damage is done already then one of the main power amp transistors or other devices could be short circuited.
Oct 16, 2014 | Onkyo TX-SR313 Home Theater Receiver - 5.1...
Connected home theatre system but no sound sub woofer
If the system uses a remote control, you may need to adjust the subwoofer out signal setting or turn on the sub in a menu, and on many systems, you can only access those settings via a remote control (you should check the onkyo user manual on how to do it).
Now, this is just one suggestion, it may work, but then again, it may not.
These could also be connection problems or some internal trouble in the onkyo sub signal output section or in the subwoofer input section, but hopefuly, it's just a "turn on" or "signal level" setting in a menu.
Good luck
3rq8 (triarcuate)
Jul 23, 2009 | Onkyo HT-S780 System
Amp protection circuit has been activated
sometimes the protection circuit will enable because of a bad speaker i would suggest taking the load off of it by removing the speaker wires and turning it back on. if it stays on take an ohm meter and check the speakers should be between 2-4 ohms load.
May 01, 2009 | Onkyo A-9555 INTEGRATED DGTL AMPLIFIER...
Onkyo HT-SR800 won't turn on
If you call Onkyo directly, 201-785-2600, there is a procedure to "reset" the system, something like holding the power button on and holding down another button for a few seconds. Can't remember which, so I can't be sure, but try giving them a call.
Jan 02, 2009 | Onkyo HT-SR800 System
Onkyo receiver (HT-R430) cutting out after a few seconds
This problem is related totally to the remote control.Pres the CRL button rapidly during that 3 sec interval and get the nunmber down
Nov 12, 2007 | Onkyo HT-S680 System
Onkyo LS-V955 System Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
