Question about Microsoft Xbox 360 Console
I jsut bought my xbox. every time i go to play a game the menu options go up and down as like you were holding the controller knob down. but i am not even touching my controller and when i guessed and got it to a game mode, all i did was walk or run backwards i had no control over anything, i have no red rings on either system or controller. what is the problem?
  • 122 Answers
I think u have some problem with the controller so the ps3 control by itself..this type of problem can be easily solved by viewing this site..check this
Posted on Nov 10, 2010
While playing call of duty on xbox 360 my controller when i look up and down is working in reverse
Your control settings have likely somehow become inverted. While in-game, go to the pause menu and select options. Make sure that Look Inversion is DISABLED.
Apr 20, 2011 | Microsoft Xbox 360 Wireless Controller
How do i get my xbox to play movies from the flash drive
  • 1
    Plug the flash drive into the Xbox 360 USB port in the front of the machine. Hold the middle button on the Xbox 360 controller to boot the console.
  • 2
    Scroll to the "My Xbox" screen with the d-pad. Move right to the media option you want to access. For example, the "Video," "music" or "Picture" options are available.
  • 3
    Select the type of media by pressing the "A" button. The next menu is the same for all three options. Highlight "Portable Device" and then press the "A" button again.
  • 4
    Choose the content from the next menu. On the right side, pick the file or folder of the media you want to display with the d-pad. Press "A" again to select the folder or to play the media file.
  • Mar 06, 2011 | Microsoft Xbox 360 Console
    Controls reversed
    Some how you have inverted the controls, on the menu of the game you are playing, look for options, then controller, then reverse the inversion.
    Mar 20, 2010 | Microsoft Xbox 360 Console
    Wireless controller up and down moves in opposite
    To fix your controller , go to the "Options" menu in C.O.D. and select "Controller," then click on "Normal". It should be set on "Invert" right now. You want to change it to "Normal"
    Oct 12, 2009 | Microsoft Xbox 360 Controller
    Any game i play disk arcade or demos xbox freezes
    Try the following:
    1. Hold disc by the edges without touching the surface with your fingers. Clean the disc with a soft cloth, lightly wiping from the center outwards. Do not use solvents or chemicals to clean the disc. Examine the disc for any visible signs of damage.
    2. Verify whether the Xbox console clock is set correctly.
      • Turn on the Xbox console without a disc in the drive.
      • Press the directional pad up or down to select Main Menu, and then press A.
      • Press the directional pad up or down to select Settings, and then press A.
      • Press the directional pad up or down to select Clock, and then press A.
      You can see the date and time from this screen. Correct the date and time as neccessary.
    3. Try to play the game again. If this does not work, you can try to clear the game cache on the Xbox hard disk. If you have a Xbox Memory Unit available, copy the game cache for this game from the Xbox hard disk to a memory unit:
      1. Insert a memory unit into a controller connected to your Xbox console.
      2. Open the disc tray and remove any disc, if present.
      3. Close the disc tray and re-start your Xbox console.
      4. Select Memory from the main Xbox Dashboard, and then press the A button.
      5. Select Xbox Hard Disk, and then press the A button.
      6. Locate and select the game you want to back up in the list of games.
      7. Select the appropriate save game icon. The Save game icons are located to the right of the game icon. Each save game is identified with a name, date, time, and size.
      8. Press the A button to display the Copy/Delete menu for the save game.
        Note: If Copy is not available, you have not chosen a save game file.
      9. Select Save, and then press the A button.
      10. Press the A button again to save to the appropriate memory unit.
      11. As soon as the copy is complete, press the B button to return to the list of save games.
      12. Repeat these steps as needed to back up your other saved games for this game.
      If you do not have a memory unit, deleting the game cache removes your progress in the game, high scores, and other information. To find the game cache, follow these steps:
      1. Open the disc tray and remove the any disk, if present.
      2. Close the disc tray and re-start your Xbox console.
      3. Select the Memory option from the Dashboard.
      4. Select the Xbox Hard Disk.
      5. Locate and select the game in the list of games.
    4. Select the large game icon to the left of the list and press the A button.
    5. Press the Abutton again to delete the game cache file.
      Note: Delete should be the only available option. If Copy is available, you have chosen a game save file and not the game cache file. Press the B button to return to the list, and then select the leftmost icon.
    6. Select Yes to permanently delete the game cache, and then press the A button.
    7. Confirm that the icon is no longer listed, and then re-start your Xbox console.
    8. Insert the game disc, and then either load your latest saved game from the memory unit, or play the game from the beginning.
    Sep 19, 2009 | Microsoft Xbox 360 Console
    My xbox 360 controller just started freaking out in the middle of playing today. Everytime I fire my gun (causing the vibration) my character will start looking down and then my controller shuts off. I...
    Turn the vibration off in the options menu of a game that allows it, if the game play is fine then you may have to ask Santa for a new controller, as that one sounds like it is starting to fail.
    Aug 23, 2009 | Microsoft Xbox 360 Controller
    Syncing problem? Xbox 360
    Is your TV a HD TV? Be sure to go to options and synchronize the game. There are delays with HD TV's and the GH/Rock Band games.
    Also, try using a wired guitar to see if there is a problem with the wireless guitar you are using.
    Hope this helps!
    Apr 04, 2009 | Activision Guitar Hero III: Legends of...
    Xbox 360 doesn't respond when I select an option in the dashboard
    first open the "System" blade in the Xbox 360 dashboard, then go to memory, and press Y on the hard drive to open the "Device Options" menu. Then press the following sequence of buttons: X, X, LB, RB, X, X. You will be asked if you want to perform maintenance on your hard drive and delete all patches. Choose yes. Then restart your xbox To later reinstall the patch, just get on Xbox Live again.
    please rate me =]
    Dec 08, 2008 | Microsoft Xbox 360 Console
    Console freezes
    hey there, I would open the Xbox 360 dashboard, then go to memory, and press Y on the hard drive to open the "Device Options" menu. Then press the following sequence of buttons: X, X, LB, RB, X, X. You will be asked if you want to perform maintenance on your hard drive and delete all patches.select yes I hope this helps
    Dec 07, 2008 | Microsoft Xbox 360 Console
    Call of duty 4, xbox 360
    just reset your options [controller options]
    May 23, 2008 | Microsoft Xbox 360 Controller
    Microsoft Xbox 360 Console Logo
    13 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    marley mcelhinney
    Tre Elkins
    Martin Murray
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
