Question about Milwaukee Tool Weller Pyropen Jr Cordless Butane Soldering Iron WST2
I try to light my Weller Pryopen Jr, whenever I have the spring open The flame is sustained but when I let the chamber down the flame goes out. HELP!
Hi i have an old weller soldering iron and it wont light up, do i have to have the 2 slide controls in a certain position
A soldering iron is composed of a heated metal tip and an insulated handle. Heating is often achieved electrically, by passing an electric current (supplied through an electrical cord or battery cables) through the resistive material of a heating element. Another heating method includes combustion of a suitable gas, which can either be delivered through a tank mounted on the iron (flameless), or through an external flame.
Mar 24, 2011 | Milwaukee Tool Weller Pyropen Jr Cordless...
Cant light the thing !!
the one i have, first see if you have fuel in it, if it is full, then check to see that the switch is in the on position, when i put mine in on, it clicks, then it gets hot, also check to see if you have it wide open
Mar 03, 2011 | Milwaukee Tool Weller Pyropen Jr Cordless...
Fires and runs for a few minutes then shuts off tries to re fire a few times then goes to 2 blinks=cannot sustain or detect flame.
There is a flame sensor located in the last burner that lights up. It is either not seeing flame or not getting flame to it within a certain time. Check the wire that comes from it and goes to the circuit board for a bad connection. Check any ground wire connections for a bad connection. Pull out flame rod (sensor) and polish it with a scrub pad or soft wire brush. If none of these recommendations help, replace the flame sensor. Make sure the flame travels to the last burner, if not, clean the flame tray that allows the flame to go from one burner to another.
Feb 13, 2011 | Mr. Heater MHU75NG
Pilot burnes yellow and stays lighted when I turn the may burner on its on for about 30 sec. then goes out pilot and burner
You may be low on gas in the tank and there's not enough pressure and/or volume of gas to sustain it. Also, try carefully cleaning the burner elements.
Jan 19, 2011 | Blue Rhino ES200209 Open Flame Gas Patio...
Williams 3003622 Wall Mounted 30,000 BTU The pilot light goes out when the main flame shuts down. The pilot light will stay lit for days when heat is not called for but when heat is called for the furnace...
I'm having the same exact problem... At first we thought was the vent... but the way the flames goes out... it seems that there is "not enough oxygen" more than "blown out by the wind"... right after both main & pilot goes out, I can't even light any external flame inside the chamber... and it doesn't feel like the outside cold air coming in... it just feel like there is some sort of gas in the chamber that's so strong, it prevents flame... and the only thing I can think of is that it doesn't have enough oxygen, but too much natural gas, and flame can't sustain.
Nov 02, 2010 | Williams 3003622 Ceramic Wall Mounted...
WE HAVE A BERNZOMATIC ST200 MICRO TORCH AND MY HUSBAND IS TRYING TO SAUDER HIS GUITAR HE CAN'T SEEM TO GET IT HOT ENOUGH TO MELT THE SAUDER. THIS IS ONE THAT IS A TORCH SAUDER COMBO THING. IS THERE A...
with the solder tip attached push upward on the little black knob on the tip, its spring loaded and on one side reveals a small little chamber where you can see a small flame once you turn the gas on and apply a spark/match to the little opening. keep the knob still pushed up all this time. let the fire inside keep going, if you let the knob down and the window to the chamber closes before it gets hot enough the iron wont work but if you wait for a bit with the fire inside, then right below the tip you'll start to see that area glow red, once its glowing red your good to go, you can close the chamber and the catalyst will "burn" the gas in the area and make heat instead of the fire heating the tip. once you close the chamber you're holding open with your thunmb then the fire goes out, if its hot enough you're set to go, otherwise rinse repeat.
Oct 30, 2010 | Garden
WILL NOT OPERATE ON GAS, TURN KNOB AND LIGHT LITES UP FOR SPLIT SECOND THEN GOES OUT
the flame goes up a combustion chamber on the right hand side of the fridge (facing the back) check for any obsticals in that chamber there is also a flame detector in that chamber could be dead (split second is pretty quick ) those fridges usual think for a minute before doing anything might be board level if you have to replace the board don't laugh but buy the dinasour board http://www.rvstuffusa.com/controlboardsfordometicrefrigeratorsbydinosaurelectronics.html
Good Luck
Oct 12, 2009 | Dometic Refrigerators
Brand new Weller Mcm Magna Lite butane torch does not light
If this is an itty ***** torch, The fuel is very sensitive . Too much screws up the air fuel ratio so try turning it way down and after the tip has heated up, you can increase your flame. Good Luck, Ned
Aug 27, 2009 | Weller Mcm Magna Lite Butane Table To
Milwaukee Tool Weller Pyropen Jr Cordless Butane Soldering Iron WST2 Logo
90 people viewed this question
Top Milwaukee Tool Welding Tools Experts
Bill Boyd
Are you a Milwaukee Tool Welding Tool Expert? Answer questions, earn points and help others
