Question about Car Audio & Video
I have a nissan xtrail qr20 engine.diagnosis gives me p0120 throttle position sensor. ive checked the tps circuit and is ok.on trying another ecu from another vehicle,the fault goes,is it possibble to repair the ecu?
  • 316 Answers
SOURCE: pedal position malfunction
You can change the tps alone. You do not have to change the entire throttle body. It shouldn't be riveted in place, it should have screws or bolts on one side or the other. If it's riveted in place, use a dremmel and grind the rivets off. You can replace rivets with screws on the new unit.
Posted on May 25, 2009
dmsr63
  • 2050 Answers
SOURCE: I have a 2002 nissan x trail currently off the
If you can get a good scanner plugged into it, you can read the TPS as you slowly depress the throttle to see if it has a dead spot. This is the best way to view the TPS as well as the communication to the computer. You will see it "count" up on the scanner screen.
Posted on Oct 08, 2009
Testimonial: "Thanks will try it out"
  • 68 Answers
SOURCE: 1995 nissan pickup throttle position sensor
ok on a 2.4l on the black/green and white wires use ohm meter and there is no specific spec for that engine just make sure the the resistance changes and there is no dead spots. for the 3.0l black and white wires specs are 1.0-9.0k ohms im guessing the specs are the same either engine. close to full open
Posted on Jul 13, 2010
jayhawke
  • 338 Answers
SOURCE: I have a 1988 Nissan
does the engine rev higher when hot and not in gear? if it doesn't try changing fuel filter and spraying carb cleaner into intake when running
Posted on May 11, 2011
  • 1746 Answers
SOURCE: rover 75 vehicle starts but will not have acceleration
Hi, Check fuel filter and replace. Check and replace sparkplugs. Check ignition components. coil, wires, distributor for cracks. and then check for codes. Good luck.
Posted on Dec 22, 2011
Check engine soon. giving codes p0120, p1705, p0325
TPS sensor (RPM) po120,knock sensor po325.
Mar 25, 2015 | 2001 Nissan Xterra
Tip
Throttle Actuator Control - drive by wire
1.5) TAC - Throttle Actuator Control
What is it? Some vehicles have indirect throttle control "drive by wire". Instead of the accelerator pedal position being conveyed directly to the throttle plate by cable linkage, it is detected by an electrical sensor and this is fed to the ECU. The ECU in turn sets the position of the throttle plate appropriate to the sensed position using an electric motor. The throttle plate position is, in turn, checked by the throttle position sensor and this signal is sent to the ECU to confirm that the requested throttle plate setting and its recorded position are in agreement.
Where is it located? The first part of the TAC is located on the inner wing/fender and consists of rotary device to which the accelerator cable is attached; the degree of rotation (pedal depression) is detected electrically and this is signalled to the ECU. The second part of the TAC is located on the throttle body and acts on the throttle plate shaft.
Symptoms of a faulty TAC
Associated OBD2 error codes DTCs: P0120, P0124, P1516; P2102, P2103;P2111 - P2118
  • Sudden power loss/limp home: If the ECU detects any fault with the throttle actuator control directly or with the position feedback via the TPS it engages an immediate engine shut-down to either idle speed or limp-home speed.
How to fix? The TAC is part of complex systemand the failure of the TPS has to be eliminated first as a possible source of error. A simple electrical connection failure can also give rise to the shutdown so all associated connections should be checked to ensure that they are clean and bright to allow electrical continuity.
NEXT 1.6) EGR Exhaust Gas Recirculation valve
on Jul 15, 2011 | Mercedes-Benz E-Class Cars & Trucks
The nissan xtrail after connect the battery cable to the terminal head light,parking light,fog light and dashbord light are on st ill the key position is off after check the dtc come...
Something might be wrong with the electrical circuit to the solenoid. Maybe it will help if you go to this site and study the OBDII codes:
http://www.wallpaperama.com/forums/nissan-altima-obdii-trouble-codes-dtc-troubleshooting-list-guide-t425.html
https://www.youtube.com/watch?v=p1DNBthuRM0
P0605 - ECM/ECCS Module, P0740 - TCC Solenoid Valve
, P0745 - Line Pressure Solenoid Valve, P0120 - TP Sensor,
Feb 28, 2015 | Nissan XTrail Cars & Trucks
I need to know the code po120
Throttle Position Sensor/Switch (TPS) A Circuit Malfunction
The TPS (Throttle Position Sensor) is a potentiometer that is mounted to the throttle body. It detects the throttle blade angle. As the throttle blade moves, the TPS sends a signal to the PCM (Powertrain Control Module). Usually a three wire sensor: A 5 volt reference from the PCM to the TPS, a ground from the PCM to the TPS, and a signal return from the TPS to the PCM. The TPS sends the throttle position information back to the PCM on this signal wire. When the throttle is closed the signal is near .45 volts. At WOT (Wide Open Throttle) the TPS signal voltage will approach a full 5 volts. When the PCM sees a voltage that is outside of normal operating range, P0120 will set. NOTE: The PCM knows that any large change in throttle position means a cooresponding change in manifold pressure (MAP). On some models the PCM will monitor MAP and TPS operation for comparison. Meaning that if the PCM sees a large percentage change in throttle position, it expects to see a cooresponding change in manifold pressure and vice versa. If it doesn't see this comparitive change, P0120 may set.
Dec 11, 2014 | 2001 Toyota Sienna
Codes 32 75 12 22 on a check engine light
first code it's P0320 Possible causes
- Faulty Ignition/Distributor engine speed sensor
- Faulty Crankshaft Position sensor
- Ignition/Distributor engine speed sensor harness is open or shorted
- Ignition/Distributor engine speed sensor circuit poor electrical connection
- Low battery charge
- Faulty Engine Control Module (ECM)
Read more: http://engine-codes.com/p0320_ford.html#ixzz3DcwddSlp
2- P0750 Possible causes
- Low transmission fluid level
- Dirty transmission fluid
- Faulty shift solenoid 1 valve
- Shift solenoid 1 valve harness or connectors
- Shift solenoid 1 valve circuit is open or shorted
Read more: http://engine-codes.com/p0750_ford.html#ixzz3DcwoXS73
3- P0120 Possible causes
- Faulty Throttle Position Sensor
- Throttle Position Sensor circuit is open or shorted
- Throttle Position Sensor poor electrical connection
Read more: http://engine-codes.com/p0120.html#ixzz3Dcx3VCPs
4- P0220 Possible causes
- Throttle Position Sensor (TPS) harness is open or shorted
- Throttle Position Sensor (TPS) circuit poor electrical connection
- Faulty Throttle Position Sensor (TPS)
- Fault Electric Throttle Control Actuator (or Throttle Body Motor)
- Accelerator Pedal Position Sensor (APP)
Read more: http://engine-codes.com/p0220.html#ixzz3DcxGUMl4
Sep 11, 2014 | 1991 Ford F150
Reset engine light for nissan xtrail qr20 2004 model
undo battery terminals for count of ten
reconnect
if engine light returns there are fault codes to be read
from the ECU
Nov 08, 2013 | Nissan Altima Cars & Trucks
What does code p0120 mean on an 2005 monte carlo
P0120 - Throttle/Pedal Position Sensor/Switch 'A' Circuit
Possible causes- Throttle Position Sensor may be faulty
Read more: http://engine-codes.com/p0120.html#ixzz26UJQOULD
Sep 14, 2012 | 2005 Chevrolet Monte Carlo
P0120 intermitant fault on nissan xtrail 2002
P0020 Camshaft Position Actuator Circuit (Bank 2)
This sounds to me like a problem with the electrical connections in the multiplug sockets ,the previous problems were 3 yrs ago but check out that you do not have a siemans coumpter these are prone to weird and wonderfull faults .Normally once you start getting cam sensors and crank sensors then misfire 1/4 and so on this is a prelude to a faulty computer .
Apr 16, 2012 | Nissan Cars & Trucks
96 nissan quest code p0120 p1705 the O/D flushes after startup. TPS was replaced but code still exists. Rough idle, loss of power and fuel economy.
this is an obd2 trouble code table, it can help you understand the meaning of code.
and for p0120
the Causes:
Sticking throttle return spring
MAP or TPS connector corrosion
Misrouted harness causing chafing
Bad TPS
Bad PCM
Possible Solutions:
If you have access to a scan tool, with KOEO (Key on engine off) observe the TPS voltage. With throttle closed, voltage should be about .45 volts. It should gradually sweep upwards to approximately 4.5 to 5 volts as you depress the throttle. Sometimes only a scope can capture an intermittent glitch in the TPS signal voltage. If you notice a glitch in the TPS sweep voltage, replace the TPS.
NOTE: Some TPS sensors require fine adjustment. If you aren't comfortable with using a DVOM (Digital Volt Ohm meter) to adjust the new TPS, then it's best to take the vehicle to a shop. If the voltage is not .45 volts (+or- .3 volts or so) with the throttle closed or if the reading is "stuck" then unplug the TPS connector. With KOEO check for 5 volts reference voltage present at the connector and a good ground. You can check the signal circuit for continuity by jumping a fused wire between the ground circuit of the TPS connector and the signal circuit. If the TPS reading on the scan tool now reads zero, then replace the TPS. However if that doesn't change the reading to zero, then check for an open or a short on the signal wire and if none is found, suspect a bad PCM. If manipulating the TPS wiring harness causes any change in idle, then suspect bad TPS.
Jul 11, 2011 | Nissan Quest Cars & Trucks
The reduce engine light comes on at 50 mph what could the problem be
DTC P0120 P0220 P1516 P2135 these should be the problem codes.
2003-2006 Chevrolet Avalanche, Corvette, Express, Monte Carlo, Silverado, SSR, Suburban, Tahoe, Trailblazer. for reduced engine power. p0120 is throttle position sensor, ( tps ). p0220 is relates to tps, p1516 tps is out of range. p2135 is a throttle body code, the throttle body needs replaced. but before you do it replace tps first to see if it takes care of the other codes. have a good day !!
Feb 18, 2011 | 2003 Chevrolet TrailBlazer
Car Audio & Video Logo
242 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
