I just fininsh a room in the attic and I want to put a baseboard electric heater. which is the best way to run the wire from the attice to basement? Thanks
  • 528 Answers
Wow - You're looking at quite the job!! The wire needs to be protected inside the walls or at the least inside conduit along the outside of the house - but that wouldn't be too pretty. I suggest getting yourself an Electricians fishtape ( if you don't already have one ) and choose a point either inside a closet or in a visually hidden location you can drill through the floors and the walls to fish your romex through. If all walls are sheetrock, you may have to literally cut a channel into the wall ( use a good metal detector to find existing electric and plumbing so you can miss those ) , bury the wire, and backfill with plaster or sheetrock mud. Either way, have patience - it is a long road you're going down. The easiest way ( not the prettiest, or necessarily legal in your area ) is to run some conduit vertically along the outside of the building and fish your wire into it. Get some wiresnot to help reduce friction and simplify the pulling of the wire in the conduit.Punch your hole through the basement and attic walls and make sure you seal those holes real good with silicone. Check first with your local city and or county building code enforcement office for the legality of externally mounted conduit / wire.
Hope this helps!
Posted on Nov 10, 2010
Testimonial: "Thanks again, Is it OK if I use the 10/3 outdoor wire so that I can hide along with the siding?"
  • George Hels
    George Hels Nov 10, 2010
    That depends on the current requirement of your baseboard heater and the distance traveled - remember there is an increase of resistance the farther you go, and the more resistance means more heat in the wire. If you can find 8/3 outdoor I think that would not only be safer but last longer.
    Hope this helps!!
Electric tank water heater is in attic. When outdoor temps are high it doesn't work. Why?
Hi Jan:
Really interesting............
A puzzle I've never encountered before.
I'm a retired Contractor and Building and Plumbing Inspector so can offer an answer based on experience.
- In hot weather, attics get REALLY hot.
- An attic is an unusual location for a hot water tank.
- A thermostat senses the temperature of the water in the tank and determines when it needs to be heated.
- I would be suspicious that in your installation, the temperature in your attic is higher than the "high limit" for your water heater.
To phrase it another way, since the attic temperature is really high, and the tank thermostat is in the attic, it "thinks" that the water is already at the required temperature.
The only real "fix" that I could suggest would be to locate the hot water tank in the moderated temperature area of the dwelling.
Hope this helps.
I would appreciate your letting me know by comment to this post if that is the problem.
Cheers, and thanks for the puzzle.
Apr 24, 2016 | Water Water Heaters
How large does the area of the space required to service an HVAC or water heating unit in the attic have to be?
There is no pat answer for that. There are many different sizes and the space requirements are usually included with the installation instructions, The seller should be able to provide the specifications to you so that you can compare different units.before you buy.
Nov 07, 2014 | Heating & Cooling
Had three 50-gal American Standard water heaters installed Dec. 2009 Two upstairs in attic, one downstairs at ground level. Attic location used because heaters being replaced were up there. Upstairs...
Plumber is right.
Problem is not amount of air in attic. Problem is how hot the air is.
Oxygen molecules separate apart in very hot air and pilot light goes out since there is not enough oxygen density to support combustion.
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
More ventilation is needed.
Plumber is not ventilating expert, and not responsible for attic ventilation that builder failed to install. Plumber should do a survey of location before installation to make sure gasoline vapors are not stored nearby, but summer attic ventilation is gray area until more general-public folks become aware of problem. Hotter summers temperatures will spread that information.
Hire local home center to install roof vents AND soffit vents.
Note: You also need soffit vents.
Remember a vent on the roof is like sucking air out of a coke bottle. The roof vent is no good unless air can also enter the attic from another vent located in the soffit.
Another solution is electric water heater for very hot locations.
Or install solar-assisted water heater.
http://www.hotwater.com/products/residential/cirrex_solar.html
Jul 28, 2011 | American Standard 40 G Natural Gas Water...
We have a gas water heater but no hot water. What happened? Our house was built in 1994. Don't know the make - It's in the attic. Do we need to replace the thing? Is it safe? Thanks
gas appliances in the attic are never safe.
a water heaters life is 7 to 10 years. if maintained, lifespan can be a lot longer.
would need to know what brand, and model number to help repair, but most likely the thermocouple needs to be replaced.
I would actually relocate out of your attic. the only water heaters I install in attics are electric.
Jun 25, 2010 | General Electric GE SmartWater Household...
No Attic
Sounds like your current heat source is not an option (I assume you don't have the option of coming from underneath). I'm thinking electric. Maybe baseboard (depends on space). Be sure it's ground fault protected though!
Apr 10, 2009 | Braun Heating & Cooling
How do you reduce an electric bill in a all electric house?
The biggest wasters of electrical energy are Heat and A/c, water heaters,dryers and ranges. The more you insulate the less you have to cool or heat. If you live in a warm climate, consider installing an attic fan that runs on a thermostat or timer. During the summer allow it to run, during winter turn it off. Ceiling fans in rooms that are occupied create the illusion of being cooler, allowing the thermostat to be turned up.I'm not sure of the exact numbers but any thermostat setting on your a/c below 78 is more inefficient so try kicking the a/c up and the heat down. I'm a Florida boy so I can't tell you much about baseboard heaters. I know that anything that heats things up cost a lot in energy.
Consider installing a hot water heater timer. Commonly called a "Little Grey Box". Whenever your water heater is not actually being used it is still heating the water. A big waster. Once installed set the timer to cycle the water heater off during times when you commonly don't use it. Overnight,when your at work etc....
Somewhat antiquated, but a clothesline always uses 100% less energy than a clothes dryer. :) Short of this, try to fill the dryer all the way and make sure your dryer vent and lint trap are clear.
Microwaves draw 1/3 the energy of a range and run for 1/10 of the time. Microwave as many things as you can. In our house we have started microwaving canned veggies and boxed side dishes and such.
These are the big ones I've done at my house. A lot of the other things seemed to be more work than they are worth. Some actually end up costing you more if you don't own the house for decades.
There are many sites you can visit such as your local power company and possibly your local government pages.
Good luck. I'm in the same boat with the high power bill.
Mar 24, 2009 | Fahrenheat F2543 Baseboard Heater
Electric baseboard heaters
measure the room, then multiply the length by the width to get the square feet you want to heat. multiply this by 10 and that is the watts you need to heat the room assuming you are using standard 220/240v baseboards.
Dec 25, 2008 | Marley Electric Hydronic Baseboard Heater,...
How to size a room for baseboard.
HERE YOU GO CALCULATE THE HEAT @ 10 WATTS PER SQUARE FOOT , TAKE THE LENGTH X WIDTH X 10 AND THIS WILL TELL YOU THE AMOUNT OF WATTAGE YOU NEED . MOST ALL BASEBOARD HEATERS ARE RATED @ 250 WATTS PER LEN FT AS TO SAY A EX. A 4FT HEATER IS 1000 WATTS , MOST OF THE THERMOSTATS ARE RATED @ 20 AMPS AS IS THE 12-2-WG WIRE TO RUN TO HEATERS AND THERMOSTAT DIVIDE THE TOTAL WATTAGE BY THE LINE VOLTAGE USUALLY 240VOLT IN US .AND THIS WILL TELL YOU THE CURRENT DRAW ----WHICH CANNOT EXCEED 20 AMPS ON 12-3-WG AND THAT IS THE LIMIT OF THE THERMOSTAT AS WELL THESE STATES APPLY 99% OF THE TIME I DO REALIZE THERE ARE EX BUT HAVE USED THESE FORMULAS FOR 35 YEARS OF DOING MY WORK AND THEY DO FINE
Dec 16, 2008 | Fahrenheat Electric Convector Baseboard...
Blower in Attic not running
inside unit has fan control relay , either on control board or can be separate ,except for the 24 volt transformer and the t-stat the units operate separately concentrate totally on the inside unit this is where the problem lies
Oct 23, 2007 | Ruud UAMB Air Conditioner
Heating & Cooling Logo
159 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
