Question about Oster OGB61101 Microwave Oven
How do I set the microwave to 50% power? I press the power button but all it does is beep at me. I also don't see a setting for low or medium temp.
How do I set the microwave for 50% power?
Hello, Linda -
Without knowing the make and model of microwave oven you are asking about I can only give general instructions. You can add the make and model of microwave by choosing Comment and adding the information there.
Generally, after placing whatever you want to heat or cook in a microwave save dish or on a microwave safe plate and place the food and dish inside the microwave and closing the door, you follow these steps:
- Using the key pad / number pad, press in the time you want the microwave to run
- Assuming there is a POWER button on the key pad, press that button
- Most likely a P will display
- On the keypad, press 50 (for 50 %) or maybe just 5
- Press START
This web page provides detailed instructions:
https://www.leaf.tv/articles/how-to-adjust-a-microwaves-cooking-power/
Best wishes.
Feb 24, 2018 | Microwave Ovens
Power it stays at 100% want 50%
Most microwave ovens I am familiar with have adjustable power levels.
Sep 11, 2016 | Panasonic NN-H765BF 1250 Watt Microwave...
Can't determine high or low on power control
put a cup of water in the cavity and set for 1 minute, after which time you can feel the temperature. Switch to the other power setting and repeat with a fresh cup of water. This will either be hotter than the first or much cooler. Most microwaves use 100% power for full and 30% power for defrost, with 50% usually being lower or medium power. Straight-forward physics. The more power the hotter the water becomes. Hope that helps.
Dec 19, 2013 | Sharp R-303CW Convection / Microwave Oven
I have never used the power feature and now I need to and cant find manual. How does the power feature work. I need to operate the microwave on medium power for one minute.
1 Use the number buttons to set a cooking
time. You can set a time from one second to
99 minutes, 99 seconds. To set a time over
one minute, enter the seconds too. For
example, to set 20 minutes, enter 2, 0, 0, 0 .
2 If you want to set the power level to
something other than High, press the Power
Level button, then use the number buttons
to enter a power level.
Power Levels:
Level Cooking PL
1Warm10
2Low20
3 Defrost 30
4Medium Low40
5Medium50
6 Simmer 60
7 Medium High 70
8 Reheat 80
9 Saute 90
10 High Hi
Hope that helps.
Mar 01, 2011 | Emerson MW8107WA Microwave Oven
I have SUNBEAM microwave, model SM0701A7E--how do I set the power to MEDIUM? Thank you.
After a long search and reading I finally got it. To adjust power level follow these instructions:
1. Set timer for amount of minutes you want.
2. Hit "power" button"
3. Change the power from 100% to another percentage by hitting numbers 1-9
4. Press Start
Dec 22, 2010 | Sunbeam Microwave Ovens
I inherited a 1986 J.C. Penney Microwave and can't figure out how to program most of the features. I need an operating manual or a gnome.
The clock must be set before you can use the microwave. When you plug it in, it should read all zeros. Enter the time, and press "Clock Set." Time is in 12-hour format. There is no daylight saving time.
For basic microwave use:
1. Press "Power."
2. Press the keypad corresponding to the desired amount of power, e.g., "High," or "Defrost." (The numbers on the keypad have little words on them, like "Warm," "Med," and "High".)
3. Press "Time."
4. Enter the desired cooking time, e.g., "1-0-0" will be 1 minute; you could also do "6-0" for 60 seconds. You can do as little as 1 second, up to 99 hours 59 minutes. "1-0-0-0" would be 10 minutes. "2-0-1-2" would be 20 minutes 12 seconds.
5. Press "Start."
NEVER operate the microwave when it is empty. Put at least a glass of water in it. Never put a glass in it empty; make sure the glass has something in it, like water. Be careful when taking out a glass of water that's been heated; the water has been known, in rare instances, to "explode" and severely scald people.
It is okay to use the approved metal rack (it's coated with ceramic to prevent arcing) when using the microwave in microwave mode. Of course, the metal rack is also fine for use in the convection/combination mode.
"Defrost" cycles between microwave and nothing, microwave and nothing, microwave and nothing. You can hear the cycles. If defrost takes too long, try "Low." Try to avoid using "High," as it kills most nutrients in the food. Opt for "Medium" for slightly longer time; it'll be more evenly heated and healthier. Some things, like popcorn, require "high" power.
To stop the microwave in the middle of cooking, simply open the door. (There's no such thing as microwaves escaping the oven and bouncing around the kitchen and zapping you. I have a microwave tester, and the moment you open the door, all microwaves dissipate; the reading at the door is "Zero" once it's opened.) Or, press "Cancel." If you open the door, you may test the food, and if it needs further cooking, you may close the door and press "Start," and it will resume where it left off. If you're all done, just press "Cancel."
There is no way to disable the 5 beeps at the end of the cycle. If the baby is sleeping and you don't want to hear the beeps, simply open the door right before the beeps when the countdown is at zero. Pressing "Cancel" will give you one beep.
If you have the Combination feature, that cycles between microwave and convection heat, giving the best of both worlds (cooking inside with microwaves and outside with convection), for things such as a whole meats.
To use Combination:
1. Press "Combination."
2. Consult the chart on the microwave (below the keypad) and choose a number from 1 to 4, depending on what type of food you're preparing (i.e., lamb, pork, etc.).
3. Press "Time."
4. Enter the desired time, using the method described above.
5. Press "Start."
The Convection feature simply blows hot air across the food, at the temperature and duration that you set. It's a great way to toast slices of bread for the whole family at once, or bake a pizza.
To use the Convection feature:
1. Press "Convection."
2. Choose the temperature (the degrees are printed on the keypad, such as "350 degrees."
3. Press "Time."
4. Enter the length of cook time, using the method described above.
5. Press "Start."
Be sure to cover foods (with a paper towel or suitable plastic cover) that are prone to splattering. Don't let foods explode and get up into the motor. Clean the inside regularly with a soft sponge and mild detergent, NOT harsh or abrasive chemicals like Comet. Then rinse the soap off with a clean sponge.
Be sure to close the door firmly before cooking, but don't slam it. Slamming it will wear out the latching part, but being too gentle in closing the door may cause the safety switch to not engage, and the microwave won't work (it'll count down and the light will turn on but the motor won't run).
Note: the Convection feature uses more wattage than the microwave counterpart. The volts and amps are listed in the door jamb; multiply them together and you get total watts (although the actual amount will vary depending on your "power" settings).
Aug 07, 2010 | Microwave Ovens
Power Setting
It depends on the brand and model, but usually it's something like:
Cook Time > 2 > 0 > 0 > Power > 4 > Start, where 4 is 40%, 5 is 50%, etc.
May 28, 2010 | Emerson MW8107WA Microwave Oven
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Sep 08, 2009 | Emerson Microwave Ovens
How do I set the power to 50%?
If you have "Power" botton on m/w
1. set time for time cook
2. press power botton
3.set 50 and hit start
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Nov 30, 2008 | Microwave Ovens
The beeps have become inaudible.
The beeper sound level can be adjusted. Press the BEEPER VOLUME button, then choose 0–3 for mute, medium or loud.
If that doesn't work, unplug the oven a few minutes, plug it back in, then try again.
If you don't have your owner's manual you can find and download one here:
http://www.geappliances.com/service_and_support/literature/
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 22, 2008 | GE JVM1651 Microwave Oven
Oster OGB61101 Microwave Oven Logo
405 people viewed this question
Top Oster Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
ray gallant
Are you an Oster Microwave Oven Expert? Answer questions, earn points and help others
