Question about Homeland Security Cameras 810 Color DayNight Security Camera
I applied 24vdc to cameras that were 12vdc only. They do not work. What needs to be repaired to make these cameras work again?
Can l use a garmin sat nav on 24volt
Garmin GPS products operate on +5VDC and require an adapter to convert +12VDC to +5VDC. The internal battery is 3.7VDC and is charged by the +5VDC.
If you want to use +24VDC, you will need to find an adapter that converts +24VDC to +5VDC @ 1AMP and has the right connector to mate with the unit. Connecting +24VDC directly to the unit will damage the GPS.
Some motorcyclists connect the GPS directly to the +12VDC battery and damage the GPS.
Jun 03, 2016 | Garmin GPS
Rca l26hd31 no sound no picture
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
Nov 02, 2012 | RCA L26HD31 26 in. LCD HDTV
No picture but have sound
It can be caused by many circuits, bottom line is that the circuits have gone out and need to be repair or repalced.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Jun 27, 2011 | Televison & Video
Black screen
Please read below to see if you will want to repair it yourself or have it repaired.
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
May 02, 2011 | Insignia IS-LCDTV32 32 in. Television
Power supply is OK (indicator light does go on) but we have no picture; Can you tell us what connector cables we need for this model (PLTV 32; Model LU32A1A3) Thank you
PLTV-32 or 32C?
PLTV-32 uses AC adapter that puts out 12vdc (for sound and logic) and 24vdc for the backlights inverter board. Do you get sound?
PLTV-32C uses built-in power supply that usually has 24vdc failure due to bad caps or bad circuits.
Try this first:
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Please post back what you find.
Dec 25, 2010 | Protron PLTV-32 Television
Samsung LCD TV liquid crystal panel is not turning on. Backlight is working OK. Which circuit board would be the problem? Or is it something else?
Power supply? Need troubleshooting first.
The T-CON board fuse will be the first place to look, you need to find out if the T-CON board is receiving the 12vdc from the main board first.
See example of dead T-CON board.
Please see my basic troubleshooting guide here:
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Nov 30, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
Momentary picture only when turning set on this NO picture at all. Is there a back lighting system that makes the picture visible & is it repairable
Yes, the problem can be caused by failed 24vdc power supply, backlight inverter boards, T-CON board, main board.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 20, 2010 | Westinghouse SK-32H240S Television
I turn on my tv and then acouple of min later the screen goes black perfect sound no picture and power button lights up with a sun like looking symbol in red
hartbriqitte, Internal ac to dc power supply printed circuit board failure. The +12vdc source may be in shutdown mode and can not supply dc to the inverter circuit that produces ac voltage to light-up the cold cathode fluorescent lamps that produce WHITE light so you can see what is on the lcd panel!! 12fixlouie
Sep 24, 2010 | Televison & Video
I get sound but no picture on any connection
It can be the 24vdc is dead, shorted out backlight inverter board, bad T-CON board.
Please read my guide so you will understand what are needed for the LCD TV to operate and then you can decide if you want to DIY repair.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make a kit for you.
Aug 14, 2010 | Element Electronics FLX3210 32 in. LCD TV
I have a polaroid 32 inch tv have sound but no pitcher what worng it
Unplug it for about an hour first to let it reset itself and try again, if it is still not working then:
Aug 06, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Homeland Security Cameras 810 Color DayNight Security Camera Logo
48 people viewed this question
Top Homeland Security Cameras Home Security Experts
Lawrence Oravetz
Are you a Homeland Security Cameras Home Security Expert? Answer questions, earn points and help others
