Question about Casio FX-115ES Scientific Calculator
On casion Scientific fx-300MS, how do i switch a decimal answer into fraction form?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
Press the S--D key to switch between decimal and fraction forms.
Posted on Nov 10, 2010
  • Casio Master
  • 8,081 Answers
I have to supply this answer taken directly from the manual for this calculator. The calculator Casio FX300MS does not have a S<>D key so I do not see how a solution calling for an inexistent key caould be implemented. Anyway I will let the screen capture give the answer
Posted on Nov 18, 2010
Decimal mode casio
Your problem is not with the scientific display, rather it is with decimal representation (approximate) or fraction/radical (exact). representation.
If your results are in fraction/radical form press the [S<>D] key to switch from one to the other.
The calculator is by default in the MATHIO t output mode: results are in fraction/radical form.
If you don't like to work with this mode just change the IO mode to LineIO. To do so, press [SHIFT][Mode](Setup) and selct 2:LineIO
Oct 07, 2013 | Casio fx-300ES Calculator
Change decimals to radical form?
hi emily, most scientific calculators have a feature to switch between deg-rad-grad. lookout for a switch DRG or so on the keypad, this feature might also be activated via a "second function" operation. check out your user manual for further in depth help.
May 23, 2012 | Casio FX-300MS Calculator
I am using my Casio fx-300MS and have somehow gotten into the display where it puts my answers in exponential form; 5+5 = 1.0 exp10 to the 1. How do I return to getting my answers in standard form?
Display Format
To change the exponential display format, press the [MODE] key 3 times.
Fixed number of decimal places:
Press 1: Scientific Notation: 0
Press 2: SCI: 0
Press 3: NORM
You will then be prompted for NORM 1 or NORM 2. CHOOSE NORM 1
To return the calculation mode and setup to the initial defaults, press [SHIFT] [CLR] [2]
[=]. This will return the calculator to the following settings:
Calculation mode COMP
Angle unit Deg
Exponential display format Norm 1
Fraction display format a b/c
Decimal point character Dot
Percentage Calculations
Apr 13, 2011 | Casio FX-300MS Calculator
Anytime I enter a problem I always get a fraction as the answer..
To convert a single result from symbolic (fractional) form to decimal, press S--D. To have all results come out in decimal, press SHIFT MODE 2 to switch to the LineIO mode.
Apr 05, 2011 | Casio FX-115ES Scientific Calculator
Dividing fractions are not calculating correctly, I have to manually get the answer I need
Press the S--D key located above the DEL key to convert between symbolic and decimal forms. To have all answers come out in decimal form, press SHIFT MODE 2 to switch to LineIO mode.
Dec 13, 2010 | Casio FX-115ES Scientific Calculator
I want to get an answer in decimal form but it only gives me them in fraction form. What should I do in order to change the settings to give me answers in decimal form?
To convert a single result to decimal, press S--D. To have all results come out in decimal, press SHIFT MODE 2 to switch to the LineIO mode.
Nov 14, 2010 | Casio FX-115ES Scientific Calculator
How do i get out of fraction form? -Whenever i try to do division, the answer is always in fraction form and i want it in decimal form
To convert a single value from fraction to decimal, press SD. To have all results come out in decimal, press SHIFT MODE 2 to select LineIO mode.
Sep 15, 2010 | Casio FX-115ES Scientific Calculator
Can you convert a decimal to a fration on the fx-300MS scientific calculator? If so how?
To convert a fraction to a decimal or a decimal to fraction you use the [a b/c] key.
While converting a fraction to a decimal number is always possible, converting a decimal to a fraction may, at times, not be possible.
Sep 10, 2010 | Casio FX-300MS Calculator
I can't get the answer to display in decimals only fractions.
For converting answers in decimal to fraction or fraction to decimal there is a S<->D key above delete key.If the answers is in fractional form press this key and it will be converted to decimal form.
Jun 04, 2010 | Casio FX-115ES Scientific Calculator
How to convert fraction to decimal
You can convert between Standard Form (with fractions and pi) or Decimal form by using the "S<->D" button. Use Mode 1 if you mostly prefer fraction answers and you can use the SD button to convert to decimal or use Mode 2 if you mostly prefer decimal answers and use the SD button to see the fraction.
I hope this helps and good luck!
Please remember to vote 51218db.jpg Thanks.
Oct 31, 2009 | Casio FX-115ES Scientific Calculator
Casio FX-115ES Scientific Calculator Logo
243 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
