Question about Westinghouse LTV-32w3 HD Television
My ltv-32w3-hd tv shows mostly blue jumps around n everything looks animated. please help ! thanks
  • 11,361 Answers
I would suspect bad T-CON board, see my pictures here: http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Nov 10, 2010
We have a westinghouse lcd 32w3 hd and when we hooked up a hdmi for the first time the screen went black and no picture or sound, how do we fix this?
If everything but the HDMI is working, its a possibility that the source has a compatibility issue or your TV needs a software/firmware update needed
Aug 01, 2011 | Westinghouse LTV-32w3 HD Television
I have a Westinghouse ltv-32w3 hd, i got scammed when i bought it, the guy who sold it to me showed me the TV, i turned it on when i bought it watched it for awhile and everything was great... Until after...
If you have identified the section or part that is overheating then it relates to an OVERDRIVEN SECTION due to faulty electronics..
In most cases the deterioration of the component value and in this case it can be critical capacitors to the drive that does not train the circuit.
So if you see that a section of the circuit can be instantly cooled using a FREEZE - IT SPRAY, then it will pin point to the faulty device.
Also increasing the heat sink area of a driver can improve but it is better to change the weak components. Also this can be acasecading efffect due to weakness of the components and so change all the suspected components.
Jul 29, 2011 | Westinghouse LTV-32w3 HD Television
I have Westinghouse LTV-32w3 and the power wont turn. The blue light next to the power button on the side just keeps blinking so it seems to be getting power but nothing is happening. If anybody has any...
there is a blown capacitor in the power supply board the cap looks like a can and will have a domed top or puffed up on the top where it vented the vlaue of the part is printed on the side you cna , or have someone replace the cap or caps
and you should be good to go
Dec 10, 2009 | Westinghouse LTV-32w3 HD Television
Problems with ltv-32w3 hd After TV is on for 15 to 30 minutes the picture looks fuzzy and looks like a picture negative but still has color
You need to replace the LCD controller board, there are two versions (V320B1-C, 35D003848) you need to open up the tv and remove the shield cover to get to the LCD controller board, this is a common problem with this model. Look here parts (make sure to get the part number of the LCD panel sticker to match wit the LCD controller): http://www.shopjimmy.com/catalogsearch/result/index/?q=LTV-32W3HD&stock=all
You cam see the one I fixed here: http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Notes: be real careful when you remove the back cover, the side switch assembly is attached to the back panel, so do not pull it off too far, or you will damage the switch assembly!
Nov 28, 2009 | Westinghouse LTV-32w3 HD Television
I am having problems with my Westinghouse LTV-32w3 HD TV. If flickers and rolls kind of like the old tube tv used to roll and you would have to adjust it in the back by turning the nob. I have a 37 inch...
The LCD controller is bad, after about on for 30 minutes, see sample here: http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Notee: my pix show the board with the cover removed. You can run the TV with the back open and have s small fan blowing in the back to keep it cool.
You need new LCD controller (there are more than one version, you need to match with the LCD panel): http://www.shopjimmy.com/catalogsearch/result/index/?q=ltv-32w3hd&stock=all
Nov 25, 2009 | Westinghouse LTV-32w3 HD Television
My westinghouse lcd tv ltv-32w3 hd
my tv says no signal, and everything is just blank. my tv is a samsung 27, and it doesn't say anything. we tried everything like rebooth, and all that stuff. but it doesn't work plzzzz help!!!
May 31, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Frozen picture and no button response
Hi John.
Try unplugging the TV for about 30 minutes to an hour (reset TV) to see if this fixes your issue. If it does not, leave the TV unplugged all night and see if it will operate normally. Hope this helps.
May 22, 2017 | Westinghouse LTV-32w3 HD Television
Picture blurry on my Westing house LTV-32w3 HD Television
hi possably is the fan in the back make shour it is working all the time that there is no dust bild up on it stops it from spining it may need a cleen ,or it is a transister heeting up and cooling down the transister is on its way out it will be a hard fix for a tech to fined thay will fined it but it will cost you a heep ,its best to whate till its gon completly .cheers peter
Apr 05, 2009 | Westinghouse LTV-32w3 HD Television
Televison & Video Logo
115 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
