Question about Coleman Mach III Air Conditioner
Wiring diagram needed RV rooftop coleman
Wires burned in RV fire. Wires are good about one foot from unit. One wiring harness with six wires, green, black, white, purple, yellow, red. I need a diagram for wiring and am going back with a hunter thermostat that will handle both heat and air.
  • 1 more comment
  • Anonymous Mar 24, 2009
    i need a wiring diagram for a coleman rooftop AC unit i dont know where the thermostat wires hook up to
  • Dalton Jones Apr 28, 2009
    I need the wiring schematic for my thermostat also, I can hear it clicking but doesn't turn on. How do the wires connect to the thermostat?
  • Mike Butler
    Mike Butler May 11, 2010
    Make & model of AC unit?
Motor1258,
Thanks for the response, to be more specific, the nine pin connector was damaged, but I was able to connect the wires back to main unit panel. I am ready to hook to the hunter thermostat and do not know which wires to connect to. This is my problem and I do not want to short something out. Hope this helps, I want to get it installed again. Thanks again for caring....Jerry
Posted on Aug 16, 2008
All of the engine wires in my 1987 e 350 RV burned up 460 motor
Hi David:
That is a really bad experience to have had happen. Serious sympathies to you.
I'm hoping/assuming that the fire did not destroy the entire unit and perhaps was restricted to electrical components.
I've a couple of suggestions that may be helpful.
First, I'd see if I could find a Haynes manual for the vehicle.
If I were to be faced with your situation I would probably sip a beer and ponder the engine compartment for a while. I'd try to determine if major components had been damaged, and then replace any that had been overcooked.
Most wiring harnesses have plug connections and I would try to get as complete a harness as possible from an auto salvage company.
Then, as each component was replaced or confirmed undamaged, I would try to splice or plug in the appropriate section of harness.
Reply as a COMMENT to this post if you wish to discuss more.
All the best.
May 29, 2016 | Cars & Trucks
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
Wiring from coleman rv ac unit has 6 wires and duotherm rv ac unit has 10--what do you do with other wires
you need a wiring diagram of each to see what they are for. heat pump, auxillary heat, inside sensor, outside sensor, electric heat, gas heat there are many different applications.
Aug 20, 2015 | Coleman Heating & Cooling
Why did my RV rooftop a/c shut off when I unplugged the furnace?
Yes you do so it only runs on ac ,but when you said rooftop unit do you mean condenser or does unit have evaporator fan too
Jan 20, 2018 | Coleman Mach III Air Conditioner
My rooftop coleman AC main wires are burnt
Either the power supply wiring is too long - i.e. a 150 foot extension cord used to power it with poor plug blades?
Or the capacitor is shot, (more likely)
Disconnect Power supply, wait 5 minutes, try to start the unit WITH POWER DISCONNECTED. (will drain capacitor). Short capacitor with well insulated screwdriver, get the new capacitor replaced on ebay or local electrical supply or appliance store (not home depot)
Aug 30, 2009 | Coleman Mach III Air Conditioner
REPPLACING FAN AND COMPRESSOR CAPACITORS WITH A SINGLE UNIT
Well, it sounds as if you have a Coleman rooftop unit. If you have a start capacitor with a PTCR (Postive Temperature Coefficient Resistor) then it is different than if you have a Potential Motor Starting Relay. Why are you replacing the run and the fan capacitor?
Here is a link to the documentation that you need. If you do not have a Coleman and it is in fact a Duo-Therm, let me know the model number and I will be able to pull up the wiring schematic.
Thanks,
Jeff
Rate this please!!
Jun 26, 2009 | Dometic Rooftop RV Air Conditioner
Wires not connected on mod# 6759c707
If you google Coleman rooftop air conditioners on your computer, it will give you some dealers that sell that air conditioner and they should be able to help you or tell you where you can get the help.
Apr 03, 2009 | Dometic Rooftop RV Air Conditioner
Wiring Diagram Coleman Electra Heat Mach EL
I need the motor for a mach EL air conditioner. I can not get a model number of the unit or a number off of the motor. Can someone help me. Its about a 1980 built unit.
Mar 29, 2008 | Dometic Rooftop RV Air Conditioner
Coleman Mach III Air Conditioner Logo
4,300 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
