Question about Bernina Sewing Machines
I have a Bernina 1080. I absolutely love this machine! But...when I try free motion quilting the top looks perfect but the back looks awful. The upper thread is looping on the back. I have had the machine serviced several times just for this issue. I have worked with and adjusted both tensions until I finally get it 'just right' . In both cases it doesn't stay ritght.. It goes back to the looping. Is it my thread? What thread should I be using? I do thread through the 'eye' on the bobbin case. I have spent hours on this and have gotten no where....you are my last hope!! ;o) Char
    Genius:
  • 1,788 Answers
I know that you think that your are threaded right, but, try this old trick, with the presser foot up, pull on the top thread, it should feed smoothly, now put the presser foot down, and pull the thread, it should barely move. Sometimes, that is what will make the thread go into the tension discs in the threading path. Try a new needle, too. Good luck
Posted on Nov 10, 2010
I have a Janome Horison Memory Craft 8900 SpEd, thread looping on backing side for free motion. DO i NEED Part No. 200-445-007 Janome Bobbin Holder for Free Quilting and Hand-Look Quilt Stitch.
Free motion quilting is a finicky function, much more than most other sewing. Since you are getting loops on the back of the fabric, try increasing the upper thread tension. Tension causes the top and bobbin threads to pull against each other. If the pull is not equal, the threads will be pulled to one side or the other.
If you continue to experience looping under the fabric, it could be that the top thread is not fully seated in the tension disk. Try this:
Remove the top thread completely from the machine.
Be sure to install a brand new sharp needle.
ALWAYS RAISE the presser foot and rethread from the beginning.
Retest your machine.
However, if you don't find a fix, $25 for the special bobbin holder is probably a reasonable cost if it takes care of the problem. The reviews seem to be good:
http://www.sewvacdirect.com/janome-bobbin-case-for-free-motion-quilting-fits-models-mc14000-mc6500p-mc6600p-mc11000-mc7700-mc12000-and-more/
https://thequiltshow.com/forum/domestic-sewing-machines/120-janome-mc6600p
"Yesterday I bought a new free motion quilting foot and a bobbinholder (for free motion) for my MC Janome 6600P. I have been quilting all day, and belive you me it is a greate investment!!! :lol: :lol: Its like sewing on butter :lol: :shock:
Free motion Quilting Foot: part no.: 200-442-004 (MC6600P and MC11000)
Bobbin Holder (for free quilting and hand-look quiltstitch): part no.: 200-445-007 (MC 6600P, MC11000 and MC6500)
Bet you would love to have those too if you are doing a lot of free motion! The quiltfoot you can adjust so it works perfectly on your quilt!
:lol: :D :wink: I am sooooo happy!!!!"
https://www.getasquiltingstudio.com/2012/01/free-motion-quilting-tips-ii.html
LOOPS Tension or Speed
Free Motion Quilting Tension Problems
Mar 01, 2018 | Janome Sewing Machines
Can I add a BSR to a Bernina 1260?
Not really. The Bernina BSR units need to be attached electronically to the machine to activate the "electronic eye." Your 1260 is an earlier mechanical-electronic machine that does not have that electronic-attachment capability, ie there is no where to plug a BSR unit into your machine. However, with practice (both with pencil on paper and then transferring that muscle memory to the machine), you should be able to learn to free motion quilt on your 1260. It just takes practice and patience.
BERNINA Stitch Regulator BSR
https://www.qnntv.com/courses/improve-freehand-quilting-designs-using-muscle-memory
Apr 01, 2017 | Bernina Sewing Machines
How do I avoid breaking a needle on a 26 foot beginning a free motion project after programing the foot choice and lowering the foot?
#26 is an embroidery foot. Why are you using an embroidery foot for free motion quilting? A #24 free motion embroidery foot will work but not the #26. Try using a darning foot that is just a smidgen shorter so there is space between it and the needleplate for you to freely move the fabric. (Adding a Supreme Slider sheet to the work surface of your machine helps make the fabric glide much smoother.) A standard presser foot is made to press the fabric against the feed dogs so the feed dogs will move the fabric. When free motion quilting, you would drop the feed dogs and move the material with your hands.
Depends which model Bernina you have (new or old style presser feet), which will work on your machine. There are also many generic darning/FMQ feet available that will work on your machine.
12 BERNINA presser feet Darning foot 9 (old style)
Quilting foot 29C (new style)
Bernina 530 53 Free Motion Quilting
Top 5 Tips for Successful Free Motion Quilting WeAllSew BERNINA USAs blog...
Seven Steps to Free Motion Quilting
Dec 31, 2015 | Sewing Machines
I am trying to free-motion quilt using my Bernina 1530. Everything is fine until I quilt a curve or a circle. Then the thread on the back is too loose. I have tried adjusting the top tension, as well as...
I don't have the BSR (Bernina Stitch Regulator) and presume you don't either. I have found that I tend to move the fabric to quickly when sewing curves and circles. I did as you did and changed tension, stitch length...everything, but nothing worked. I finally found that the best solution was to SLOW DOWN on the curves. No problem ever since. I hope this helps you. If it does, please let Fixya know by rating my solution!
Nov 20, 2010 | Bernina Sewing Machines
Help setting Viking Designer I machine for free motion quilting
I assume you are doing free motion quilting? Use the V Menu, choose the first stitch. If you are using the Q Sensor foot or the spring free motion foot, go into the Set menu, hit "More" twice then turn On for either the Q Foot or Free motion. Make sure you have Needle Down turned on (top right-hand button on the left side above the needle). You might need to loosen the top tension by one or two clicks - first screen of the Set menu, under the picture that looks like DNA. A Size 90 needle is probably best and if the quilt is difficult to move about you might like to either use the Sewing Advisor to set for Heavy fabric or lessen the upper presser foot pressure - Set menu once again, next picture after the DNA. I have never had to do this with my D1 but I know some other people have. Get back if things are not working well for you.
Pam
Apr 29, 2009 | Bernina Activa 140
Unbalanced lower tension when using BSR free motion quilting
try using a straight stitch plate, this will help resolve some of the eye lash effect.
Apr 05, 2009 | Bernina Artista 180
Threadtension wrong when free motion quilting
If the thread under the fabric is loose you need to tighten the upper tension. If it's on 4, bring it to 5. If it's on 5, bring it to six and continue doing that and sewing till its perfect. You may need to decrease your lower tension if you can't get it just right.
Bernina Sewing Machine Parts
Jan 06, 2009 | Sewing Machines
Sewing Machines Logo
225 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Wayne Buss
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
