Question about Bosch SHU9950 Dishwasher
Handle on my SHU 9950 is loose. I don't see a set screw or anyway to tighten it. How do I do it?
    Problem Solver:
  • 10 Answers
Sometimes you have to take the oven door apart to access the screws that hold the handle on. I have not looked at this model but most ovens have screws on the top of the door when you open it. Be careful though and pay close attention to how it goes together because they can be tricky.
Posted on Nov 10, 2010
How do I tighten door handle on whirlpool fridge how do I get to the screws model gb2fhdwq02
Hello Tim;
My name is Peter. I am a retired field service refrigeration technician.
You have one of two door attachments:
1.) There are two 3/32" K set screws (Allen Head) at the top and bottom of each handle. Back off these screws until the handle comes off. The is a stud with a screw - tighten and reattach the handle.
2.) There are two brackets mounted to each refrigerator door. One at the top and one at the bottom. At the top of each bracket is a oversize hole. On the back of the handle there are two screws. These screws fit into the oversize hole. Then you push down into a slot to secure the handle. To remove the handle you push up on the handle until the door handle screws are into the oversize holes.
The screws on the door bracket often become loose. Tighten these screws. Sometimes the mounting screws on the door handle become loose as well.
Be careful, if you tighten everything up too much you will not be able to remount the door handle. Adjust the screws for a tight fix
Oct 31, 2014 | Refrigerators
Sub-Zero 601R door handle is loose
My Sub is a 650S. Not sure your handle assy. is the same or not. But each of the 2 attachment points have a small 3/32" set screw on the bottom of each short piece between the vertical handle and the door. These set screws grab onto posts that are screwed into the door. There can be 3 points where the handle can work loose.
1. The set screw(s) have backed out and not holding tightly onto the door studs. 2. The studs in the door are loose and need to be tightened with a screw driver. 3. After loosening the handle via the set screws, when you look back into the cavity vacated by the studs from the door, (pivot handle clockwise past edge of door) you will see a Philips-head screw that secures the spacer to the handle. If the spacer is loose, tighten it with screw driver. Then mount back into door stud and tighten set screw. Problem Solved. Have a beer!!!
Nov 26, 2010 | Sub-Zero 601R
THE HANDLE WHICH LET YOU GO FORWARD AND BACK IS VER LOOSE - IS THERE ANYWAY TIGHTEN IT
hiplady yep you might have to remove the console on the tiller which is held on by phillip screws located under the console. After you have all the screws out maybe 4 -6 screws depending on the type scooter console cover you have. Carefully remove the plastic cover and you should be able to see the throttle handle. It is held in place by a nut that tightens against a plate that the post goes through. That nut is loose or check to make sure that the plate holding the throttle handle is not loose on the tiller itself(some are held on by screws some are welded to the tiller) If you can tighten the nut between the throttle handle and the plate. Hope this helps you
Oct 11, 2010 | Pride Mobility Products Health & Beauty
The handle of my side by side Kitchen Aid refrigerator is loose. The model number is KSCS25INSS00. It has circular open holes on the handle, no screws? How do I tighten it?
Use an allen wrench (hex) to remove loosen the set screws in the two handle holes. Once removed, tighten the mounting lug. Replace the handle and tighten the hex set screws.
May 21, 2010 | KitchenAid KSCS23INSS Stainless Steel Side...
The sink faucet handle is hanging loose. i need to keep the handle in place and probably tighten a set screw.
If it is a Delta, there is an allen screw on the underside of the handle. If it another brand, there is a cap in the center of the handle that you can pry off and tighten. If the cartridge is loose and leaking, tighten the packing nut with a channel lock wrench.
Sep 07, 2009 | Plumbing
On/off control button on top panel of door is
a service call is necessary.usually that button support from one side breaks and needs to be replaced.it is not a expensive fix.
Aug 20, 2009 | Dishwashers
Loose handle on frididaire gallery series dishwasher
Handle needs to be replaced part# 154537303 (blk). Un plug unit, take 4 screws from behind blk control panel out. Panel will fold down, remove two torx head screws from door latch, replace with new one and put it back together and your done.
Dec 12, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Bosch shu 9950
Take off the front panel (10 little screws, two shims will fall out) and you'll see the two handle bolts on the inside of the panel. Tighten 'em; reinstall the panel (good luck figuring out how the shims go back...)
Feb 17, 2008 | Bosch SHU9950 Dishwasher
Handle loose on Refrigerator
To fix this you will need an Allen wrench small one there are 2 set screws on the inside part of the handle (on side toward the center) you wil need to tighten these to fix your problem
Feb 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Door Handle repair
The fastner must be loose. Remove both set screws remove your handel. Then tighten the fastner. reinstall the handel and tighten your set screws. let me kniow if this helps
Aug 18, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Bosch SHU9950 Dishwasher Logo
154 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
