Question about Whirlpool ACM184XP Air Conditioner
I have problem with my whirlpool air conditioner. It will not operate, I checked the fuse, the timer, and power switch they seems having no problem. What will I do next?
  • 320 Answers
Unplug the unit and dismantle the off and on timer and remove the plastic back cover until you see the 4 way switch. Using an air compressor clean the terminals of all the contact points. Assemble again and operte.
Posted on Nov 10, 2010
Testimonial: "Guro dhonskie2 helped me fix my problem with my whirlpool air conditioner. He is knowledgeable with it and guided me in the step by step process. "
Whirlpool dryer model LER4634EQ0 won't hear up Cheked the voltage to the dryer, wires to the hearing element and fuses, the hearing element, thermal fuse, thermal cutoff, internal bias thermostat, high...
You seem to have checked everything. Did you check there is voltage to the elements, and have you checked amp usage on elements? Sometimes things check out ok but the problems shows when power is passed through the element itself.
Jan 13, 2018 | Whirlpool Dryers
My 12000btu spliter air condition start and stop in 5 seconds
24
EN
TROUBLESHOOTING
CAUTION
If any of the following conditions occur, stop the air conditioner immediately, turn off the main power switch and contact the
dealer.
• The indicators flash at short intervals (5 Hz). Reset the circuit breaker 2 to 3 minutes after the power main switch is turned
off.
Despite the resetting operation, the indicators still continue turning on and off.
• The main power fuse often blows, or the circuit breaker is often activated.
• Foreign matter or water has fallen inside the air conditioner.
• Any other unusual conditions are observed.
Before asking for servicing or repairs, check the following points.
Recheck
Inoperative
• The power main switch is turned off.
• The circuit breaker is activated to cut off the power supply.
• The main power fuse has blown.
• The electric current has stopped.
• The batteries in the remote controller used up.
• The ON timer is set.
• As a protective mechanism for the air conditioner, it does not operate for 3 minutes
immediately after restarting operation or turning on the main power.
Poor cooling or heating performance
• The air inlet or outlet of the outdoor unit is blocked.
• Doors or windows are opened.
• The air filter is clogged with dust.
• The louver is not at the correct position.
• The fan speed is set to low.
• The air conditioner is set
to the DRY or SLEEP MODE.
• The temperature setting is too high (during cooling operation).
• The temperature setting is too low (during heating operation). (heat pump models)
Feb 01, 2015 | Samsung AS18A6RB Air Conditioner
My lg air conditioner power and timer light blinks 2 time on each light (power 2 times and timer 2 times) I have no idea what this means. I know its an error code. But is it serious ?
It appears to be an error 22. According to the LG bible, it means an overcurrent protection has activated. In most cases, unplug the machine or switch off from power supply for at least 15 minutes, it should reset the main control board. If this doesn't work , it may have damaged the board. Alternatively, if your machine is on 3 phase, check that all fuses / circuit breakers in your meter box are OK and switched on. You may have a weak or disconnected power supply.
Dec 25, 2013 | LG Heating & Cooling
Panasonic air conditioner with seral nr. A75C2616
Have you checked your remote
control if you have accidentally set the
timer off to turn off one hour after
turning it on? Seems like the problem because the
timer LED is lighting up means that the
unit has shut off via the timer. Verify the remote if there is a timer
setting on it. If you would not
recognize it, try to remove the battery
for about 5 minutes, return the
battery, then just press the on and off
switch and put it in cooling mode and observe if it did correct the problem.
Jul 15, 2013 | Heating & Cooling
ModelAOT24RNEL Fujitsu Wont start. The fuse
Look at the fuse board in the indoor unit and then check the transformer is over the motor's internal fan.
Aug 18, 2011 | Fujitsu 24C1 Air Conditioner
When we turn on the unit with the remote after about 3 minutes it switches off and the timer light flashers then nothing happens
Remove battery from remote for resetting timer. Now you can operate with remote. And also reset your unit power isolating power and re plug it. Thanks.
Dec 30, 2010 | Panasonic CW-1406BU Air Conditioner
Whirlpool Dryer blows cold air when starting no heat
Did the fuse blow out? If so then the heating element is shorted out. This happens frequently when they fail. If the fuse is blown check the condition of or change out the heating element.
Dec 29, 2008 | Weather King 12AJA4801AH Air Conditioner
Fijutsui air conditoner
We had a similar problem. The timer light would blink 3 times, pause, then blink 3 times again, pause, and so on. The fan was blowing lots of air out, but the air was not cold. The operation light was off.
The technician came and fixed it for free, since it's actually easy to fix. He went to our circuit-breaker box, and cut power (from the box) to the air conditioners for 30 seconds. Then, he restored power - problem fixed!
It's apparently because the air con goes into a "safety" mode when there's a power surge.
Jul 06, 2008 | Heating & Cooling
Whirlpool ACM184XP Air Conditioner Logo
121 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
