Question about Brother MFC 420CN All-In-One InkJet Printer
How does my copy machine connect to my modem
How Does my brothers mrc 420 cn connect to my modem what kind of cord do i uses
  • wandawicker Jun 19, 2008
    I had to call brothers and ask them where the usb cable plug into printer from modem. It is where the ink is inside of the printer not on the outside like all the other printers that I have work with. I would have never found it until i change the ink. Thank you for trying...
  • 2,794 Answers
Here is the user manual:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
Page A-9 in the appendix section shows you how to plug standard telephone cords into the fax machine.
Posted on Jun 17, 2008
  • Tim Babcock
    Tim Babcock Jun 19, 2008
    The link I provided for you contains the owners manual. Once you have it up on the screen you can save it to disk.
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
Need the software for the brother 420 CN
Give this link a shot...
http://www.soft32.com/Download/Free/Brother_MFC420CN_USB/4-172312-1.html
Nov 07, 2009 | Brother MFC 420CN All-In-One InkJet...
OUT OF MEMORY
Go into the printer settings on the computer and change it from-send dirrectly to printer - to - Spooling. It will send a small portion of the print job at a time there for the printer mempry will not overload and report out of memory. Please rate this help if it works for you. Thanks!
Jan 28, 2009 | Brother IntelliFax-2920 Plain Paper Fax,...
Sublect:Problems With My MFC 420 CN / All In One Machine
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 13, 2009 | Brother MFC 420CN All-In-One InkJet...
NEED HELP NOW!
you can purchase the ink here: http://www.brother-usa.com/accessories/Accessories.aspx?Model=MFC420CN&ACASCID=30
you can download the software for your Brother MFC 420 CN printer here:
http://welcome.solutions.brother.com/BSC/Public/Templates/DownloadTop.aspx?NRMODE=Published&NRNODEGUID={2C7B4D65-D5B3-47BF-958E-322BE5EFDCA8}&NRORIGINALURL=/bsc/public/us/us/en/dlf/download_top.html%3freg%3dus%26c%3dus%26lang%3den%26prod%3dmfc420cn_us&NRCACHEHINT=NoModifyGuest∏=mfc420cn_us®=us&c=us〈=en
Oct 27, 2008 | Brother MFC 420CN All-In-One InkJet...
MFC 420-CN Printer
At the brother site. Click Product Support Then Your language, which for me was US English. Then click MFC then scroll down about 2/3rds the page you will find the MFC 420 CN Click that, than click downloads. The drivers , utilities and firmware for the MFC are all there.
Mar 22, 2008 | Brother MultiFunction Center MFC-440CN...
Brother mfc 420 cn does not print red color
do you use generic ink? If yes, the generic ink might have clogged the ph (valve stucks inside because of lack of additives!).
Anyway, do this:
(use near full level ink carts!)
make sure carts are placed well and are secured.
Press menue then start bk copy then fortimes arrow up. machine will be in maintenance mode. press 7 then 6 then 4 then start bk copy. machine will refresh ink in tubes and ph and do some cleaning cycles. when finished press 7 then 6 then 3 then start bk copy. ,achine runs a power purge. when fisihed press 9 then 9 to leave the mode. press ink etc. to run a quality test print.
If you still cant see any magenta, the ph is defective and needs replacing!
Dec 19, 2007 | Brother MFC 420CN All-In-One InkJet...
420 cn
go to www.brother.com. choose your country and afterwards your machine. donload the whole mfl-pro software.
Dec 17, 2007 | Brother MFC 420CN All-In-One InkJet...
Installation brother mfc 420 cn
You can try searching the web for the driver for that machine or call Brother directly at 1-800-284-4357 and order another cd
John
Dec 09, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
81 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
