Question about Apple iTunes
When I try to burn tracks to a CD itunes says that there is no burn software.
That is probably because the cd is already used or somebody canceled the process of burning the cd, also once you have started a burning process with the cd you can not use the cd over again so basically you need a blank cd make sure you check to see if the cd is blank before trying to burn the cd.
Posted on Nov 11, 2010
Any way to remove the DRM from iTunes Apple Music?
Here's one way:
1. Using iTunes, burn a music CD with the songs you want.
2. Import the CD you just created. Use the iTunes > Preferences > Import Settings to set the type of audio file you want iTunes to create when importing the songs.
3. iTunes will import the tracks as "Track 1", "Track 2", etc. You can rename the tracks to the original song titles.
Dec 03, 2015 | Apple Audio Players & Recorders
Tip
How to Play iTunes Music on Windows Media Player
There's a good chance when you buy music from the iTunes Store that the files that you download will be copy protected by Apple's FairPlay DRM system. It's a great system that protects the rights of the artist and publisher by making it difficult for the consumer to distribute copyrighted material. However, DRM can also be very restrictive by stopping you playing legally purchased music on your MP3 compatible hardware. So, what happens if you want to play your DRM'ed music on a non-iPod?
This tutorial will show you a way to produce DRM-free music that doesn't require any special software that you would normally need to buy. All you'll need is the iTunes software, and a blank CD (preferably a rewritable (CD-RW)).
Before we begin, check for any updates that are available for your iTunes installation, or download the latest version from the iTunes website。
Configuring iTunes to burn and rip an audio CD
CD Burner Settings: In order to set up the iTunes software to burn an audio CD, you first need to go into the settings menu and select the correct disc format. To do this, click on the Edit tab on the main menu and select Preferences from the menu list. On the preferences screen, select the Advanced tab, followed by the Burning tab. First, make sure your CD burner is selected from the drop-down menu alongside the CD Burner option. Next, Select audio CD as the disc format that is to be written by your CD drive.
CD Import Settings: While you are still in the preferences menu, click on the Importing tab to access the CD ripping settings. Verify that the On CD Insert option is set to Ask to Import CD. Next, set the Import Using option to a format of your choice; the MP3 Encoder is your best choice if you want to import audio CDs as MP3 files that play on virtually all compatible devices. Choose an encoding bitrate from the Setting option; 128Kbps is the normal setting that is good enough for the average listener. And finally, make sure the Automatically Retrieve CD Track Names From Internet and Create File Names With Track Numbers and both checked. Click the OK button to save your settings.
Making a custom playlist
To be able to burn your DRM copy protected songs to audio CD you will need to make a custom playlist (File > New Playlist). You can add music tracks to a playlist easily by dragging and dropping them from your music library to your newly created playlist. For instructions on how to achieve this, why not follow our tutorial on How to Create a Custom Playlist Using iTunes.
While creating a playlist, make sure that the total playing time (displayed at the bottom of the screen) doesn't exceed the capacity of the CD-R or CD-RW you are using; typically, the total playing time of a 700Mb CD is 80 minutes.
Burning an Audio CD Using a Playlist
Once you have created a playlist, simply left-click it (located under the playlists section in the left pane), and then click on the File tab on the main menu, followed by Burn Playlist to Disc. The CD drive tray should now automatically eject so you can insert a blank disc; ideally use a rewriteable disc ( CD-RW) so you can reuse it multiple times. Before iTunes starts burning the DRM protected songs, it will remind you that creating an audio CD is for your own personal use only; once you have read this notice, click on the Proceed button to start burning.
Ripping an audio CD
The final step in this tutorial is to import (rip) the songs that you burned onto audio CD, back to digital music files. We have already configured iTunes (step 1) to encode any audio CD that is inserted into the CD drive as MP3 files and so this stage of the process will be mostly automatic. To start ripping your audio CD, simply insert it into your CD drive and click the Yes button to start. For a more in-depth look at this process, read the tutorial on How to Import CD Tracks Using iTunes.
Once this stage is complete, all the files that have been imported into your music library will be free from DRM; you will be able to transfer them to any device that supports MP3 playback.
Note:The only downside in using this method is that if you have a lot of files that you need to convert, then it ends up a slow and tedious process. With this in mind, use a legal drm removal tool if you have a large quantity that you need to convert.
on Aug 25, 2010 | Computers & Internet
Laptop cd burning issues
You may try this disc creator, I always use it to burn music and video to CD/DVD, it works pretty well for me all the time.
May 18, 2013 | Audio Players & Recorders
When I try to burn a disk it tells me I have to check each song individually. This is crazy. Isn't there another way. Select all doesn't do it.
What to do is to create a new playlist. Then go to your music library and from here you can drag the tracks that you want to record onto the playlist. Once you have select all your tracks you can then burn that playlist to CD. Hope this helps.
Nov 13, 2010 | Apple iTunes
Hi. If I try and burn a CD from Apple itunes it freezes my computer. Initialization starts, but it sticks on the first track. I've downloaded the most recent update to see if that helps but the problem...
well change this stupid software with ashampoo burning studio and you will be free of this problems
if you want the link just email me
dont forget to rate
Jun 15, 2010 | Apple iTunes
Burning using Tape2PC
if you are using itunes and you have a cd burner on the laptop...you just pick approx 10-15 tracks from itunes (it also depends on how big the mp3/4 tracks are) place your correct (cd +/-, 16x or 8x) type of blank cd in laptop and burn ...
Sep 25, 2009 | ION Audio TAPE2PC Single Cassette Deck
ITunes not able to burn CD's
you already have other cd / dvd burner software on pc / laptop...use it...(can i suggest a better software than itunes for burning..unless you have this already..nero, ashampoo and / or burn4free cd / dvd)...nero has much more to place on the menu of dvd...cd (u can get creative)....this way your new version of itunes will just keep your ipod up to date (no more regs problems)
Jan 04, 2009 | Toshiba Satellite A105 Notebook
BURNING ITUNES MUSIC TO CD
Itunes does have digital rights management, which restricts the number of times you can burn the tracks you've downloaded. It's one reason I prefer sites like mp3fiesta.com who don't believe that if you've paid for the track you should be restricted in using it.
To burn music from Itunes you first have to make a playlist of the tracks you want to burn. Select New Playlist on the left, and drag the tracks you want to burn into this new playlist. When you've done that, right click the playlist name and select "burn playlist to disk."
This will ONLY work a finite number of times (I believe currently it's either 3 or 5) after which burning will be disabled for a track, and if that track appears on a playlist you won't be able to burn that playlist either.
May 12, 2008 | Dell Inspiron 1501 Notebook
Problem finding tracks
Try bunring a cd at the slowest possible speed and see if it helps. Also I would try a different burning software than what you are using now. (Even if it is iTunes or Media Player and if your already using these try roxio or nero instead).
Dec 26, 2007 | American Audio DCD-PRO310
How can I burn mp3 CD-R ?
MP3 pro?! Have you tried using a 3rd party writer like roxio and just chose data disc option, or import them into a conversion software even import into itunes (insuring mp3 is your selected format) and write the mp3 files created.
Oct 10, 2006 | Panasonic SC-DK10 System
Apple iTunes Logo
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
