Question about Vacuums
I bought a Hampton Bay Hawkins 44 " ceiling fan (117 391) and would like a remote that I can control the speeds with not just the on and off. I have a pull chain for the speeds but would like to use a remote instead. Is this possible? I have a Hampton Bay Redington IV and love the remote. I'm looking for something like that. Thanks Madeline Lepisto
  • 14 Answers
SOURCE: Change direction of rotation?
Some fans have switch on the side or on the top by the ceiling.Steve
Posted on Jun 07, 2010
heatman101
  • 43501 Answers
SOURCE: How to remove a Hampton
Hi.
Take the screws out of the sides of the top cover plate...drop it down, then unhook the wires and remove the screws holding the mounting plate...
heatman101
Posted on Aug 29, 2010
  • 377 Answers
SOURCE: My Hampton Bay ceiling remote
First, be sure you did not change one of the dip switches in the hand held unit while changing batteries. You would have to see if the switches in the hand held unit match the switch positions in the fan receiver.
This is one of the many sites you can go to for remotes:
http://www.lightinguniverse.com/fan-accessories_84.html
Hampton Bay fans are sold exclusively by Home Depot. I would check on line or stop by one of their stores to see if you can pick up a HB remote. Once you get a new remote you have to again make sure the dip switches are in the same position. Paul
Posted on Oct 11, 2010
GodBlessU
  • 3513 Answers
SOURCE: Receiver on Hampton bay the
First you need to check the housing mounted to the ceiling as the transmitter is there. Next you have to try and match it to a new remote or look for some number on the transmitter. However you can usually buy a new remote and transmitter for 30 bucks and just swap out the transmitter. This will be helpful in case you cannot match the numbers. They come labelled and r pretty easy to install. Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Oct 31, 2010
GBELECT
  • 23 Answers
SOURCE: I need to replace the
You can buy a fan remote at Home Depot, Lowe's,or Menard's basically any one of the big box stores. If they do not have the one used with your fan,you buy a universal remote. Follow the instructions in the box make sure you shut the power off as you may get shocked or burn up he control
Posted on Feb 01, 2011
Testimonial: "."
Changing frequency on a remotely operated Hampton Bay Celing fan
Remove battery from remote and you should see 4 small switches. Write down the pattern they are in now. Then move them to a new pattern. Then take the bezel off of the fan (where the fan connects to the ceiling). Turn the bezel counterclockwise if you don't see any screws holding it on. Now look for a set of switches that look the same as the switches in the remote. Write down their current pattern. Now Set the switches to a similar pattern as you set on the remote. If the remote doesn't work after adjusting, set them back to original positions from the notes you kept. Good luck
Jul 18, 2011 | Vacuums
I need to replace the remote control (UC7083T) of my Hampton Bay Sidewinder 54 Ceiling fan. Could you pls tell me where to buy one? Thanks
Feb 01, 2011 | Vacuums
My Hampton Bay ceiling remote model no. UC7030T does not work. How can I get another one. My fan will not work without it.
Oct 11, 2010 | Vacuums
How to remove a Hampton Bay Cameron Plus Blue Ceiling Fan?
Hi.
heatman101
Aug 29, 2010 | Vacuums
Jun 06, 2010 | Vacuums
I have a Hampton Bay Midili fan which I just installed about a month ago and it was working fine. A few days ago when I flipped the switch on the light flickered on and off consistently until I turned the...
in many of these remote controlled lamps you cant use the new spiral light bulbs .. you can only use standard incandescent lights .. if thats not the trouble then you may indeed have a bad controller (in the fan) .. there is probably at least a 90 day warranty maybe as much as 3 years .. make sure the wire nut power connections are secure inside the fan.. if one of the the wires in the fan are not making contact then you will see a similar problem .. once in a while i have seen strong external RF signals interfere with the controller but thats rare and usually doesnt last long ..
i would : 1. check all the connections .. 2. replace the light bulb to make sure its not flakey or the wrong type .. 3. try to get the fan replaced in warranty ..
Vacuums Logo
97 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
