Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Cannot find input for sharp aqous tv - Sharp Aquos LC-42D62U 42 in. LCD HDTV
    President:
  • Sharp Master
  • 1,779 Answers
The input selection should be on your remote and also on the right side of the set. (I believe)
Posted on Nov 10, 2010
Half a screen on my sharp aqous
There's a circuit board under a metal cover that needs to be replaced. This board conrtols the picture.
Aug 28, 2012 | Sharp 60" Aquos LED Smart TV - LC60LE640U
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Sharp aqous on switch does not work
If it is the soft switch (optical) unplug the TV for 2-3 mins then plugin and retry. clean area arout the remote sensor on tv and remote with soft cloth.
Oct 20, 2011 | Sharp Televison & Video
Sharp dtv e202 error was received
Try just changing the channel to the one set up to receive broadcasts. That worked for me-- the TV was working great until I pressed Input and for some reason that changed the channel away from channel 60, which is the one programmed to receive broadcasts from Dish Network. When I entered 60, the message went away and I got my programming back.
Nov 07, 2010 | Sharp Aqous LC-26D5U Television
Can I hook up my Toshiba laptop to my Sharp Aqous TV, if so what connections do I need, ?S-video? I have an SGA connection on my laptop but not on the TV?
If this is the exact model Sharp Aquos television you have then you would have to have a laptop that has hdmi or dvi. You can try S Video on a laptop but the laptop's resolution would have to be so low that most laptops cannot accommodate this. You're right; this television does not have a VGA (RGB cable) input.
Nov 02, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp aqous lc 37 in tv power no picture,sound
Your control board seem's defective or the inverter board (associated circuits) are bad. This is common in most TFT-LCD Tv's.......
Nov 30, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
37 inch Sharp Aquos. "Failed to receive Broadcast [E202]"
This is basically a message for no signal on the tv, make sure the tv itself is on the correct input for the type of cable used. The inputs are labled by numbers on the back of the tv. The input can be changed by the button on the side panel of the tv.
Aug 13, 2008 | Sharp Aqous LC-26D5U Television
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
66 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
