Question about Delta Home
Just installed delta 13/14 series and the water wont shut off.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 135 Answers
The adjuster ring under the handle need to be loosened and moved to a new position. This allows you to set it to a "maximum" hot water setting, but if it's too far the other way it can prevent you from turning it all the way off.
The view of the valve at the link below shows the markings on the side of the valve insert. Placing the adjuster ring at these different marks allows you some control of where your "hot" setting is and are a good visual guide when making these adjustments.
http://www.deltafaucet.com/repairparts/details/RP46074.html
Posted on Nov 11, 2010
Hose assembly
Shut off main water to home. Then check if a clip is guarding the nut to nut threaded connection the use 2 wrenches to un screw.
Cover tools "teeth" with tape or thin rubber to prevent marking on chrome/etc finishes.
Jul 29, 2013 | Delta Model 470: Signature Kitchen...
Is there a way to reverse hot and cold?
Is it moen brand? if so all you have to do is take off the handle and remove the cartridge inside and flip it over 180deg and put it back in.
be sure to shut the water off first.
hope that helps you.
Dec 18, 2012 | Delta 144962-SS Mandara Monitor 14 Series...
Can't get both hot water running at the same time. Delta Shower faucet
  • The spool and sleeve, the part of the Scald-Guard pressure balance valve that blends the hot and cold water, is not working properly. This can is caused by mineral deposits that build up over time resulting from hard water. To fix this, follow the steps below based on your model.
  1. Shut off water supply.
  2. There are two types of valves. Choose one or the other below depending on your series.
  • 1300-1400 Series: Remove handle.
  • 1700-1800 Series: Remove temperature knob, cover and handle.
  1. Twist and pull sleeve to remove it.
  2. Unscrew brass bonnet nut.
  3. Remove cartridge.
  4. Soak cartridge in a 50/50 vinegar and water solution for 24 hours to remove any mineral deposits.
  • **NOTE** Unless both hot and cold water supplies are turned on, the pressure balance valve will allow only a dribble of water to flow through the valve.
  • I have put up a picture to make disassembling it just that much easier for you.
Regards, Tony
May 23, 2011 | Delta & Single Handle Shower Faucet
We have a Delta 172 single handle faucet. We had our hot water heater replaced. Now it takes longer for hot water to get to the faucet. Could debris (calcium build up, etc.) from the replacement get in...
Yes, debris from water heater replacements often breaks lose and gets stuck. The problem could potentially be anywhere between water heater and the faucet. The faucets shut off valves or the Delta faucet cartridge itself. Turn the hot and cold water valves off under the sink and disconnect the water supply lines from the faucet. aim the water supply lines into a bucket and turn the valves on one at a time. If there is a significant reduction in the water pressure and volume on the hot water side, you need to replace the shut off valve. If there is no reduction in water pressure, you need to clean and/or replace the Delta faucet cartridge. Contact Delta to receive free replacement parts.
Dec 11, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
Plumber installed a delta multichoice valve trim 17 two years ago. The water temperature knob is getting harder to turn again. It happened a year ago too and the plumber put in a new cartirdge saying...
not all that familiar with your particular faucet. but in my experience, most plumbers dont put grease on the valves when installing them . the factory just uses enough grease to get the valve in the faucet. if you have extremely hot water and use it . it wont take to long for it to cause this problem.. just an opinion. i cant imagine how the buildings shutoff could have anything to do with your problem.
Dec 10, 2010 | Delta & Single Handle Shower Faucet
Went to change the handle in my shower when putting it back together it wont shut off water runs even while turned off.
try taking handle off and shut off water from stem..nall inside body may have turned>>once off install handle at point where it goes in
Nov 22, 2010 | Delta Plumbing
I just installed a series 13/14 single valve tub/shower faucet. When I try to turn on just the tub spout, the shower comes on as well. What could be causing this?
most likely problem is to much pressure in water lines if u have shut off valves on to feed lines turn them down a little will decrease pressure to the valve other problem the spout {tub} diverted is partially engaged, loose,debris or defective if u can reremove the spout and observe the valve for proper function
Feb 13, 2010 | Delta Monitor 13 Series Chrome Trim...
Delta Faucet (Series 2467) Sprayer doesn't work
Yes, the diverter assembly is probably corroded or clogged shut. Garunteed its the problem on a 10 year old delta kitchn faucet.The diverter routes water from the spout to the sprayer when the sprayer is triggered.
Jun 02, 2009 | Delta Faucet Delta 2457 Orleans Two Handle...
Keeps running
Sounds like you need to replace the inner cartridge. You can shut your water off at the street meter if your whole house does not have its own external shut off. Be sure to relieve the pressure before popping out the cartridge.
Jan 16, 2009 | Delta T13420 Chrome Classic Single Handle...
Valve in Delta faucet closes as water warms up
Yes, you are on the right track, but Deltas use a fancier kit inside them. It is quite a bit pricier than an O ring, but will solve the problem. It is not hard to install at all.
Jan 10, 2009 | Delta Faucet Delta 156-WF Victorian Single...
Home Logo
346 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
